95 civic coupe DX Fuel tank - D-series.org
Old 03-19-2019, 07:52 AM   #1 (permalink)
Evil1_4real's Avatar
Rep Power: 0 Evil1_4real is nobody
Default 95 civic coupe DX Fuel tank
Hi I have a 95 civic DX coupe. From what I have read and know it should have a 11.9 gallon tank. But I can drive the car till the fuel gauge is on the E. The most I have been able to put in the car is a little less than 9 gallons. Is it possible the car came with a 10 gallon tank? The car was built in Canada if that makes any difference. I thought it may be the signal sending unit, but after testing it seems to be working.
Evil1_4real is offline   Reply With Quote Quick reply to this message
Old 03-19-2019, 08:56 AM   #2 (permalink)
Replacement gas tank for 92 VX?! - Fuelly Forums
the joys of google lol.
"These 3 tank of 92-95 civic can be swap without any fitting or part needed.
10 gallons/35 litres USDM CX/VX
11.9 gallons / 45 litres DX/SI/Canadian CX
13.5 gallons / 51 litres "
Old 03-19-2019, 10:21 AM   #3 (permalink)
\/Your Mom Was Here\/
BeerDrinkin's Avatar
There is a drain plug on these tanks you could jack the one side up and drain it all out and measure how much is needed to make it full again. Of course do this with the tank as empty as possible.
2005 Civic EX Sedan (ES2)
Old 03-19-2019, 10:33 AM   #4 (permalink)
You can get 12.2 gallons in a 11.9 gallon tank if you try. The needle goers below E, and you have the right fuel pump that is properly mounted.
Do you feel lucky, well do ya?
Old 03-19-2019, 12:29 PM   #5 (permalink)
I do know the tank is the original tank for the car. I am the second owner and know the 1st owner very well. This spring I am going to install and new fuel pump. But till then is there a visible difference in the tanks that would tell me what tank I have? I just want to know if I really have 12 gallons worth of fuel.
Old 03-19-2019, 12:49 PM   #6 (permalink)
run it empty,
drain it
fill it with 1 gallon
go fill it up the rest of the way and see where it stops
Old 03-19-2019, 03:16 PM   #7 (permalink)
you nearly always see 88-00 civics with the ability to grab an extra 2-3 gallons at the "E" mark.
Ive ran my 97 civic to fumes, backfiring up a steep hill, and fully out, rolling into a gas station, and put over 13 gallons into it.
Usually when gauge reads at E, I can only put 9.5 to 10.5 gallons in, depending if I add a little extra after the "click off" point.
My point being, on flat level ground without heavy acceleration or braking, you can usually get an extra 1-3 gallons of use out of your car, regardless the model.
No idea if honda did that on purpose, or just a result of their preferred tank design.
Old 03-19-2019, 05:00 PM   #8 (permalink)
I have run it till it is on the E and it normally takes 8 or 8.5 gallons. But I have not run the car till it cuts out. Before I put a fuel pump in I will carry an extra gallon of fuel in the trunk and run it out.
Similar Threads
Thread Thread Starter Forum Replies Last Post
Fuel Issue 1989 Civic HF McD Engine Management 7 04-29-2015 12:51 PM
Fuel tank capacity of a 92 civic sedan? flatfourfan General Tech 6 02-16-2005 11:22 PM
iconAll times are GMT -8. The time now is 02:13 AM. | Welcome to Forum, please register to access all of our features.
