91 ex engine to 96-00 ex engine? - D-series.org
Go Back   D-series.org Ľ D-series Knowledge Factory Ľ General Tech
Old 08-01-2018, 02:56 AM   #1 (permalink)
Rep Power: 0 Andrew916 is nobody
Default 91 ex engine to 96-00 ex engine?
I just picked up this 91 civic ex sedan and I was wondering if the d16y8 Vtec engine is a compatible direct bolt in swap to the 91 d16a6 auto trans? I plan to stay d series but I wanted to update the engine to an obd2 option So it is easier to find replacement parts and to diag CELís. This is going to be my dailydriver, want to keep it clean and simple. Also, curious about what is required to convert to the d16y8 5speed trans if itís compatible with the 91 sedan?
Andrew916 is offline   Reply With Quote Quick reply to this message
Old 08-01-2018, 04:26 PM   #2 (permalink)
that's not how it works, youll still need a jumper harness for the obd 0 sensors to plug into the obd2 ecu.....the trans will bolt on just fine.
slo_eg8 is online now   Reply With Quote Quick reply to this message
Old 08-01-2018, 05:14 PM   #3 (permalink)
Thanks for the info slo_eg8.
I was actually researching about the jumper harness today for obd0-obd2. I havenít found too much yet due to minimal free time at work but I will figure that part out. Also, curious if the trans mounts are the same or slightly different in shape or position, and if the automatic driveshafts will work with the standard trans (same spline count?)... Iím about to look into that online now as well. Iím just not too familiar with the efís yet, I had a 97 ex back in high school/college and loved it. I got to know the 96-00 civicís fairly well.
Old 08-01-2018, 05:18 PM   #4 (permalink)
if the trans stays the same, then nothing else should change other than engine and ecu.....
if youre going to drop in a y8 trans, then yes, Im fairly certain the axles are different lengths from autos....but Im not 100%
Old 08-01-2018, 05:50 PM   #5 (permalink)
Ok cool thanks again. Ya I will probably try and just do the engine, jumper harness, Ecu and keep the auto trans for now and see how things go from there. Main goal for now is to get her running reliable for daily driving so I can take my time working on refreshing the rest of the car as they me and $ come together.
Old 08-01-2018, 05:51 PM   #6 (permalink)
*as time and $ come together
iconAll times are GMT -8. The time now is 12:25 PM. | Welcome to Forum, please register to access all of our features.
