Suspected fuel line leak. What's it called? (photo). Wet injectors? (photo) - D-series.org
Old 05-16-2017, 05:29 PM   #1 (permalink)
curlybandit's Avatar
Rep Power: 15 curlybandit is a name known to allcurlybandit is a name known to allcurlybandit is a name known to allcurlybandit is a name known to allcurlybandit is a name known to allcurlybandit is a name known to allcurlybandit is a name known to allcurlybandit is a name known to allcurlybandit is a name known to allcurlybandit is a name known to all
Default Suspected fuel line leak. What's it called? (photo). Wet injectors? (photo)
Hey everyone.
I took my car (1993 del Sol Si - built NA d16z6) for a little spin this evening and I thought I could smell fuel through the vents. I popped the hood and sure enough I found that the rubber fuel line that is on the right side of the fuel rail (when facing the motor) which connects to the metal fuel line and to the fuel rail is leaking. I recently had some work done on the motor and it appears that the tech has used a screw clamp to connect the rubber and metal hoses. What's this one called? Is it the return line?
I also took a peak at the injectors. They would have been pulled out of the y8 IM I was using to be installed in the Skunk2 IM I'm now using. I painted the body of the IM a flat black. It appears to be slightly "wet" around the injectors on the IM. I'm not sure if that's simply because of the flat black paint and is otherwise normal (I don't expect to see it on a silver IM) or does it appear to be leaking as well.
Thanks!
1993 Honda Civic del Sol Si.
The old: NA d16z6 - 158whp - RIP May 22, 2017 (dropped exhaust valve)
The new: OBD1 JDM GSR 1.8L DOHC VTEC - 198whp, 138wtrq, Integra Type-R S80 LSD transmission.
curlybandit is offline   Reply With Quote Quick reply to this message
Old 05-16-2017, 06:28 PM   #2 (permalink)
I figured it out.
The wetness where the injectors are is the silicon lube used when the injectors were installed. It hasn't dried like fuel would therefore I'm certain that it's the lube.
The hose is the return fuel line. I'm pretty sure it's 5/16". The hard line looks a little worse for wear but still works. I think I'll try cutting the end of the hose where the suspected leak is and move the new end up the hard line. Hopefully this works for the track event I'm going to this weekend. Then I'll work on replacing the hard line and hose.
Old 05-17-2017, 03:07 AM   #3 (permalink)
n00b forum?!
That's cold admin...
Old 05-17-2017, 04:59 AM   #4 (permalink)
\/Your Mom Was Here\/
BeerDrinkin's Avatar
Originally Posted by curlybandit View Post
n00b forum?!
Seriously slo... come on dude.
Anyways the fuel leak on that return line I would do like you are thinking and cutting the end and moving it up, looks like enough slack to do it. The hard line has some rust but probably not under the hose end. Also use a better clamp, and make sure there is a barb at the end of that line and put the clamp right behind it.
2005 Civic EX Sedan (ES2)
Old 05-17-2017, 09:09 AM   #5 (permalink)
n00b forum?!
slo_eg8 is online now   Reply With Quote Quick reply to this message
Old 05-17-2017, 10:05 AM   #6 (permalink)
Right!?
Thanks for the advice.
[quote=slo_eg8;5082177]
Pass the Sriracha.
Old 05-17-2017, 11:21 AM   #7 (permalink)
Certified O.G.
Staypuff578's Avatar
Rep Power: 27 Staypuff578 is on a level you can only DREAM about! ! !Staypuff578 is on a level you can only DREAM about! ! !
Staypuff578 is on a level you can only DREAM about! ! !Staypuff578 is on a level you can only DREAM about! ! !Staypuff578 is on a level you can only DREAM about! ! !Staypuff578 is on a level you can only DREAM about! ! !Staypuff578 is on a level you can only DREAM about! ! !Staypuff578 is on a level you can only DREAM about! ! !Staypuff578 is on a level you can only DREAM about! ! !Staypuff578 is on a level you can only DREAM about! ! !Staypuff578 is on a level you can only DREAM about! ! !Staypuff578 is on a level you can only DREAM about! ! !Staypuff578 is on a level you can only DREAM about! ! !Staypuff578 is on a level you can only DREAM about! ! !Staypuff578 is on a level you can only DREAM about! ! !
iTrader Score: 58 reviews
Send a message via AIM to Staypuff578
For the record, anyone with the name Will (Slo) is an asshole.
Sincerely,
William.
Staypuff's ECU/Wiring services- PM me for OBD0/OBD1 ECU Chipping/Conversions, and all ECU Jumpers.
almost as badass as my mustache, like a mustache with tits
Instagram- Spoolin_Larry
Staypuff578 is offline   Reply With Quote Quick reply to this message
Old 05-17-2017, 11:27 AM   #8 (permalink)
Infamous Kanjozoku hatch
dougshatch's Avatar
Rep Power: 34 dougshatch is on a level you can only DREAM about! ! !dougshatch is on a level you can only DREAM about! ! !dougshatch is on a level you can only DREAM about! ! !dougshatch is on a level you can only DREAM about! ! !
dougshatch is on a level you can only DREAM about! ! !dougshatch is on a level you can only DREAM about! ! !dougshatch is on a level you can only DREAM about! ! !dougshatch is on a level you can only DREAM about! ! !dougshatch is on a level you can only DREAM about! ! !dougshatch is on a level you can only DREAM about! ! !dougshatch is on a level you can only DREAM about! ! !dougshatch is on a level you can only DREAM about! ! !dougshatch is on a level you can only DREAM about! ! !dougshatch is on a level you can only DREAM about! ! !dougshatch is on a level you can only DREAM about! ! !
Send a message via AIM to dougshatch
Sincerely,
William.
Because Batman give ZERO fucks.
R.I.P. Carlos, Milo, PatPrimmer, Cesrea, Ryan, Ian, John
You might be gone but never forgotten
My kanjozoku project
dougshatch is offline   Reply With Quote Quick reply to this message
Old 05-17-2017, 11:36 AM   #9 (permalink)
Asshole
Chrisfrom1986's Avatar
Rep Power: 53 Chrisfrom1986 is on a level you can only DREAM about! ! !Chrisfrom1986 is on a level you can only DREAM about! ! !Chrisfrom1986 is on a level you can only DREAM about! ! !Chrisfrom1986 is on a level you can only DREAM about! ! !
iTrader Score: 42 reviews
That's what happens when you pay someone to work on your car instead of doing the work yourself. Why is there a screw clamp on there when the stock one is right next to it? Guessing because it looks like they ruined it.
99 ej8 ex b20z2 Taffeta White
Old 05-17-2017, 11:36 AM   #10 (permalink)
see, these guys get it.
Old 05-17-2017, 11:49 AM   #11 (permalink)
1. He's a good friend and exceptionally good licensed mechanic.
2. I don't have the time necessary to dedicate to every aspect of my favourite hobby.
3. Because I can.
I respect the honesty.
Old 05-17-2017, 04:25 PM   #12 (permalink)
the tech who put that clamp on your fuel line is a RE RE
go to the partsstore and buyy a fuel line clamp. its smooth all around, to provide even and complete clamping force. regular worm clamps like that cause leaks more often than fixing them
heres a google pic of a fuel clamp
Old 05-17-2017, 04:37 PM   #13 (permalink)
Already purchased.
Thank you!
Old 05-17-2017, 08:31 PM   #14 (permalink)
Asshole
Glad you got it fixed. Sometimes it's best to take the time for yourself.
Old 05-18-2017, 03:02 AM   #15 (permalink)
Rep Power: 21 robscrx is the fucking MAN!!!!robscrx is the fucking MAN!!!!robscrx is the fucking MAN!!!!
robscrx is the fucking MAN!!!!robscrx is the fucking MAN!!!!robscrx is the fucking MAN!!!!robscrx is the fucking MAN!!!!robscrx is the fucking MAN!!!!robscrx is the fucking MAN!!!!robscrx is the fucking MAN!!!!robscrx is the fucking MAN!!!!robscrx is the fucking MAN!!!!robscrx is the fucking MAN!!!!robscrx is the fucking MAN!!!!robscrx is the fucking MAN!!!!robscrx is the fucking MAN!!!!
at least it was a easy fix
robscrx is offline   Reply With Quote Quick reply to this message
Old 05-18-2017, 08:36 AM   #16 (permalink)
Thankfully. I'm taking it to the track for the first time this year on Monday (May 22). Would have been pissed if it were worse...
In fairness to Slo, I did hit the panic button a little early in making this thread. I think a few more minutes of investigation and I could have sorted this out without the need to ask for help.
But this forum has been integral in my never-ending build. What better place to ask for help when you're afraid you're going to miss track day!!!
Old 05-18-2017, 11:45 AM   #17 (permalink)
hence why it was sent to the noob forum. you figured it out with time and corrected the issue yourself......there is a method to my madness.
so, if yall don't mind, can I send it back to the noob graveyard?
Old 05-18-2017, 12:15 PM   #18 (permalink)
Why, is this not techie enough for the tech post?
Old 05-18-2017, 12:22 PM   #19 (permalink)
Old 05-18-2017, 01:22 PM   #20 (permalink)
Sac*HXy5's Avatar
Rep Power: 7 Sac*HXy5 is about to blow upSac*HXy5 is about to blow upSac*HXy5 is about to blow upSac*HXy5 is about to blow upSac*HXy5 is about to blow upSac*HXy5 is about to blow upSac*HXy5 is about to blow upSac*HXy5 is about to blow upSac*HXy5 is about to blow upSac*HXy5 is about to blow upSac*HXy5 is about to blow upSac*HXy5 is about to blow upSac*HXy5 is about to blow upSac*HXy5 is about to blow upSac*HXy5 is about to blow up
Proper fuel clamp selection is pretty technical.
Sac*HXy5 is offline   Reply With Quote Quick reply to this message
iconAll times are GMT -8. The time now is 12:28 PM. | Welcome to Forum, please register to access all of our features.
