Vaccuum lines on z6 swap - D-series.org
Old 01-29-2017, 04:41 PM   #1 (permalink)
ef89hatch28's Avatar
Rep Power: 3 ef89hatch28 will become famous soon enoughef89hatch28 will become famous soon enoughef89hatch28 will become famous soon enough
Default Vaccuum lines on z6 swap
89 hatch, d16a/z6 swap.
Since I'm using the z6 throttle body and map sensor, can I just get rid of these vaccuum lines?
Also what goes on the bottom nipple on the pcv? And the nipple on the throttle body?
ID:	116881   Click image for larger version
ID:	116889   Click image for larger version
ef89hatch28 is offline   Reply With Quote Quick reply to this message
Old 01-30-2017, 06:17 AM   #2 (permalink)
I got it all figured out except the one on the purge valve.
Unrelated question that someone may know, which fuel line to use from filter to fuel rail? I've read some things that say use an si one and some say the z6 one will bolt up to the filter fine. My local junk yard has a z6 one but no ef parts.
Old 01-30-2017, 06:27 AM   #3 (permalink)
Pyro336's Avatar
Rep Power: 16 Pyro336 It's a JDM Star Bitches....
Pyro336 It's a JDM Star Bitches....Pyro336 It's a JDM Star Bitches....Pyro336 It's a JDM Star Bitches....
Purge
Pyro336 is offline   Reply With Quote Quick reply to this message
Old 01-30-2017, 06:48 AM   #4 (permalink)
Originally Posted by Pyro336 View Post
Purge
That one on the bottom of the purge that curves toward the driver side is the one in question.
Old 01-30-2017, 07:23 AM   #5 (permalink)
Pyro336's Avatar
It goes to a nipple on the back driver side of the intake manifold.
Just remember that if the women don't find you handsome, they should at least find you handy!
You Rep Me, and I'll Rep You Back!!!!!
Old 01-30-2017, 07:33 AM   #6 (permalink)
Oh ok thank you. Any idea on the fuel line question?
Old 01-30-2017, 07:39 AM   #7 (permalink)
Pyro336's Avatar
As far as the fuel line, I just used my stock one I believe.
Old 01-30-2017, 07:49 AM   #8 (permalink)
Thanks for that pic. Unfortunately my stock fuel line is a dpfi one which is different.
Old 01-30-2017, 07:53 AM   #9 (permalink)
Weird, my intake mani doesn't have that nipple
Old 01-30-2017, 07:56 AM   #10 (permalink)
yEaH tHaT gUy!!!
Onatop's Avatar
Rep Power: 32 Onatop is on a level you can only DREAM about! ! !Onatop is on a level you can only DREAM about! ! !Onatop is on a level you can only DREAM about! ! !Onatop is on a level you can only DREAM about! ! !
Onatop is on a level you can only DREAM about! ! !Onatop is on a level you can only DREAM about! ! !Onatop is on a level you can only DREAM about! ! !Onatop is on a level you can only DREAM about! ! !Onatop is on a level you can only DREAM about! ! !Onatop is on a level you can only DREAM about! ! !Onatop is on a level you can only DREAM about! ! !Onatop is on a level you can only DREAM about! ! !Onatop is on a level you can only DREAM about! ! !Onatop is on a level you can only DREAM about! ! !Onatop is on a level you can only DREAM about! ! !Onatop is on a level you can only DREAM about! ! !Onatop is on a level you can only DREAM about! ! !
iTrader Score: 58 reviews
Send a message via AIM to Onatop Send a message via Yahoo to Onatop
Just tee off one of the intake vacuum ports if you don't have that nipple.
Often replicated but never DUPLICATED & NEVER done like D&M Tuning
Onatop is offline   Reply With Quote Quick reply to this message
Old 01-30-2017, 08:25 AM   #11 (permalink)
Pyro336's Avatar
If that's the case I switch mine too. When i got my z6 head it was complete with intake,dizzy and all. Must have came with the fuel line too.
Old 01-30-2017, 08:33 AM   #12 (permalink)
Oh ok thanks
Old 01-30-2017, 09:18 AM   #13 (permalink)
Ok thanks
Old 01-30-2017, 10:47 AM   #14 (permalink)
Pyro336's Avatar
honda part numbers for the fuel hose.
16722-p07-003
16722-p05-a01
Old 01-30-2017, 11:11 AM   #15 (permalink)
Maybe this line will work. Seems to fit?
Old 01-30-2017, 01:08 PM   #16 (permalink)
Pyro336's Avatar
That's the way mine sits. I did think I switched it out but it's been 7 or 8 years since I did mine.
Old 01-30-2017, 03:38 PM   #17 (permalink)
Turns out the stock ef fuel line does work. I got one off a y8 at the junk yard, tried both and no difference.
Not sure why all the write ups say you need a different one.
iconAll times are GMT -8. The time now is 12:43 PM. | Welcome to Forum, please register to access all of our features.
