91 civic+ turbo= problems - D-series.org
Old 10-21-2008, 11:06 AM   #1 (permalink)
I got a promoted! And I'm PINK!!
Green 91's Avatar
Rep Power: 13 Green 91 is obviously a regularGreen 91 is obviously a regularGreen 91 is obviously a regularGreen 91 is obviously a regularGreen 91 is obviously a regularGreen 91 is obviously a regularGreen 91 is obviously a regularGreen 91 is obviously a regular
Send a message via AIM to Green 91 Send a message via Yahoo to Green 91
Default 91 civic+ turbo= problems
ok, well i am mocking up my turbo, get the manifold and turbo and wastegate altogether, bolt it in the car, and wow. a super tight fit.
i have a Mini ram manifold
t3/t4 turbo
JGS precision turbo 40mm wastegate(older version, still one of the slimmist ones on the market)
one main problem i see, is the wastegate dump tube.
their is NO room that i can see to mount it.
so i am asking, what do you guys with 88-91's do?
i have a delsol dual core half rad.
here are some photos to show you what i mean when i say no clearance.
the manifold, turbo and wastegate.
cant turn the wastegate and mount it this way, the 90* bend schedule 40 i have wont clear.
and turn it the otehr way, have about a 1" gapo between wastegate exit and rad.
so wtf?
any help/input appreciated, larger/more photos avaliable if needed.
i also will be using a slim fan mounted on the otherside of the rad, so that clears up room for the downpipe, but still have issues with the wastegate.
B18c1 CRX
Green 91 is offline   Reply With Quote Quick reply to this message
Old 10-21-2008, 12:02 PM   #2 (permalink)
Green 91's Avatar
no one.
i dont really want to cut the WG flange off and turn it 90* but i think im going to have to.
any idea on how much a shop would charge to TIG it back on.
i can MIG it, but it wont look like the rest of the welds.
B18c1 CRX
Old 10-21-2008, 12:10 PM   #3 (permalink)
Rep Power: 16 ghettoturbo is almost a somebodyghettoturbo is almost a somebodyghettoturbo is almost a somebodyghettoturbo is almost a somebody
is there a reason you cant turn it away from the rad and then clock the compressor housing down?
ghettoturbo is offline   Reply With Quote Quick reply to this message
Old 10-21-2008, 12:11 PM   #4 (permalink)
Green 91's Avatar
i cant clock the turbo down, it will hit my crossmeber.
B18c1 CRX
Old 10-21-2008, 01:18 PM   #5 (permalink)
relocate the rad and provide adequate air to it with shrouding.
since that is not the stock rad for that car, you shouldnt have problems doing this :P
Old 10-21-2008, 01:28 PM   #6 (permalink)
crazymx6's Avatar
Rep Power: 19 crazymx6 is the fucking MAN!!!!crazymx6 is the fucking MAN!!!!
crazymx6 is the fucking MAN!!!!crazymx6 is the fucking MAN!!!!crazymx6 is the fucking MAN!!!!crazymx6 is the fucking MAN!!!!crazymx6 is the fucking MAN!!!!crazymx6 is the fucking MAN!!!!crazymx6 is the fucking MAN!!!!crazymx6 is the fucking MAN!!!!crazymx6 is the fucking MAN!!!!crazymx6 is the fucking MAN!!!!crazymx6 is the fucking MAN!!!!crazymx6 is the fucking MAN!!!!crazymx6 is the fucking MAN!!!!crazymx6 is the fucking MAN!!!!
Send a message via AIM to crazymx6
either that or your gonna have to cut it and turn it 90 deg.....as far as price for re tig should be pretty cheap maybe like 20 bux..
"Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well-armed lamb contesting the vote!"
~Benjamin Franklin~
crazymx6 is offline   Reply With Quote Quick reply to this message
Old 10-21-2008, 01:46 PM   #7 (permalink)
Green 91's Avatar
the rad is located as far to the pass side as it can be. there is no where else to relocate it to.
B18c1 CRX
Old 10-21-2008, 02:28 PM   #8 (permalink)
Lifes short, drive fast!
Max713's Avatar
Rep Power: 19 Max713 is the fucking MAN!!!!Max713 is the fucking MAN!!!!Max713 is the fucking MAN!!!!
iTrader Score: 25 reviews
id say cutting the wastegate flange off is ur best bet...
GO-AUTOWORKS.COM - The one and only, best of the Honda world!
713
No longer a D owner, but forever a D member
Max713 is offline   Reply With Quote Quick reply to this message
Old 10-21-2008, 02:30 PM   #9 (permalink)
Green 91's Avatar
yeah, i might have found another way, not sure yet.
ran into another problem, the oil drain, the turbo hangs so low its going to be a bitch to make the oil drain line.
B18c1 CRX
Old 10-21-2008, 03:07 PM   #10 (permalink)
Rep Power: 0 eicivic is trying to make new friends
use 2 wg flanges and i see you have a steel elbow on the valvecover... weld that elbow to the flange and weld the other to the end of the elbow. then you can bolt the wg to the elbow.
eicivic is offline   Reply With Quote Quick reply to this message
Old 10-21-2008, 08:02 PM   #11 (permalink)
Rep Power: 0 txdohczc will become famous soon enoughtxdohczc will become famous soon enoughtxdohczc will become famous soon enough
if your turbo is too low to get a good drain then you need to get a pump setup going. thats why i stick to log manis
txdohczc is offline   Reply With Quote Quick reply to this message
Old 10-21-2008, 08:43 PM   #12 (permalink)
get a different 90* off the WG outlet. something with a sharper bend. cheap and will be easy to do
[email protected]
Old 10-22-2008, 05:51 AM   #13 (permalink)
Rep Power: 0 frenshawas is nobody
we had this problem boosting a b20 in an ef hatch. we took the 90 and cut it short so it would be alot closer to the wastegate. it looked funny but it worked
frenshawas is offline   Reply With Quote Quick reply to this message
Old 10-22-2008, 06:25 AM   #14 (permalink)
Green 91's Avatar
i have a really sharp 90 pipe. but tits still not sharp enough.
im looking to trade for a log manifold.
B18c1 CRX
Old 10-22-2008, 08:00 AM   #15 (permalink)
racist-bigot-sexist-homophob
mindless's Avatar
Rep Power: 43 mindless is on a level you can only DREAM about! ! !mindless is on a level you can only DREAM about! ! !
iTrader Score: 43 reviews
Cut the wg flange off and rotate it 90* so the dump is facing up...then you can fab a dump pipe to work around your constraints.
edit: My oil drain was also really low so I used some 45* fittings on the turbo and oil pan, works fine.
Old 10-22-2008, 08:18 AM   #16 (permalink)
Green 91's Avatar
yeah i think im do that.
here is what i have for oil line fittings
Function7 -10an adapter
summit -10 an to hose fitting
summit 45* -10an to hose fitting
and a -10 weld on fitting
and i dont think they will fit, the turbo center housing has to be turned 45* to clear the crossmember, and it sits something like this:
thats another reason i want to trade for a log manifold.
B18c1 CRX
Old 10-22-2008, 08:22 AM   #17 (permalink)
mindless's Avatar
How long are those AN fittings? The 45* fitting I used on my oil pan is about 2.5" long.
Old 10-22-2008, 08:24 AM   #18 (permalink)
Green 91's Avatar
4" without the weld bung on it.
i want to use this manifold, but i am thinking about just going with a log.
B18c1 CRX
Old 10-22-2008, 08:28 AM   #19 (permalink)
mindless's Avatar
Just change your fittings dude. You might have to do without the baller AN fittings but that would be easier IMO than going through the hassle of swapping manifolds.
Old 10-22-2008, 08:31 AM   #20 (permalink)
Green 91's Avatar
its not just the oil line, the wastegate is also a issue.
so what other kind of oil drain can i use? smaller fittings?
B18c1 CRX
iconAll times are GMT -8. The time now is 02:59 PM. | Welcome to Forum, please register to access all of our features.
