140,000 miles - D-series.org
Old 04-06-2008, 04:52 PM   #1 (permalink)
Rep Power: 0 goldex420 is nobody
Default 140,000 miles
is this a safe number to turbo on ? it seems to run ok and iam babying it until i put the boost on
goldex420 is offline   Reply With Quote Quick reply to this message
Old 04-06-2008, 04:54 PM   #2 (permalink)
99EJ6T's Avatar
Rep Power: 45 99EJ6T is on a level you can only DREAM about! ! !99EJ6T is on a level you can only DREAM about! ! !99EJ6T is on a level you can only DREAM about! ! !
iTrader Score: 32 reviews
perform the following:
compression test
leak down test
if both pass, boost it. if it fails even slightly, better hold off cause boosting will make things much worse.
Old 04-06-2008, 05:02 PM   #3 (permalink)
Tibby's Avatar
Rep Power: 21 Tibby is the fucking MAN!!!!Tibby is the fucking MAN!!!!Tibby is the fucking MAN!!!!
Tibby is the fucking MAN!!!!Tibby is the fucking MAN!!!!Tibby is the fucking MAN!!!!Tibby is the fucking MAN!!!!Tibby is the fucking MAN!!!!Tibby is the fucking MAN!!!!Tibby is the fucking MAN!!!!Tibby is the fucking MAN!!!!Tibby is the fucking MAN!!!!
compression test
leak down test
how does one go about doing this
ak riding shotgun literally
autox/ touge ej1
Built 12.5 d., ac, pic selects, itr sway, wide wheels, more bracing than a dentist office lol
09 Chevy 3500hd crew cab long bed 4x4 just because I felt like it
Tibby is offline   Reply With Quote Quick reply to this message
Old 04-06-2008, 05:05 PM   #4 (permalink)
99EJ6T's Avatar
seriously? if you can't perform these two test or know how to search on how to do them, you should not mod cars.
Old 04-06-2008, 05:15 PM   #5 (permalink)
hahah wow i thought i was ill informed. yea iam cheep and was just kinda wanting a " yea its good" but i probly should get the test but aftter that more miles will be on her and a couple of months will go by. i dont know i guess u cant rush boost.
Old 04-07-2008, 04:57 PM   #6 (permalink)
AJxr's Avatar
Rep Power: 14 AJxr is obviously a regularAJxr is obviously a regularAJxr is obviously a regularAJxr is obviously a regularAJxr is obviously a regularAJxr is obviously a regularAJxr is obviously a regularAJxr is obviously a regular
Send a message via AIM to AJxr
my first turbo setup was on a d15b7 with 265k. 9psi for 3 months 7000 miles, motor still runs today unboosted though. nearing 300k... a little smokey lol.
- Racer
d16, eagle/vitara 19psi, 12.27 @ 110.6mph, 1.795 60ft - retired
b18b1, holset, 14psi, 11.75 @ 114.75, 1.765 60ft - BONE STOCK ENGINE - retired
forged ls-vtec, itr cams, holset cranked. 1?.?? @ 1??.??
AJxr is offline   Reply With Quote Quick reply to this message
Old 04-07-2008, 05:00 PM   #7 (permalink)
Rep Power: 13 statiK will become famous soon enoughstatiK will become famous soon enoughstatiK will become famous soon enough
lol i bet it's not a little smokey... i bet it's more like a lot smokey. but 140 is pretty low for a motor that has been taken care of. if i were you i'd just pick up a cheap d15b7 or b2 long block and rebuild it for boost. that's your best bet and it's still inexpensive.
statiK is offline   Reply With Quote Quick reply to this message
Old 04-07-2008, 05:04 PM   #8 (permalink)
Rep Power: 0 tepco will become famous soon enoughtepco will become famous soon enoughtepco will become famous soon enough
I would have to agree, read up on all of it a bit more and maybe make some Mechanic friends that can guide you on how to work on cars and start small.
I love turbos and have worked on motorcycles for years and i feel that i need to know more before i mess with them.
tepco is offline   Reply With Quote Quick reply to this message
Old 04-09-2008, 05:12 AM   #9 (permalink)
w8lifter21's Avatar
Rep Power: 14 w8lifter21 is nobody
Send a message via AIM to w8lifter21
Should be ok if all tests check out. I know a few guys who have close to 175k and boosting just fine.
Red 1992 Civic Cx
w8lifter21 is offline   Reply With Quote Quick reply to this message
Old 04-09-2008, 03:55 PM   #10 (permalink)
Mr Mobsta Man's Avatar
Rep Power: 13 Mr Mobsta Man is almost a somebodyMr Mobsta Man is almost a somebodyMr Mobsta Man is almost a somebodyMr Mobsta Man is almost a somebody
Send a message via MSN to Mr Mobsta Man
Assuming you pass a compression and leakdown test you can boost it no problem, if it fails the test boost will only make it worse.
1997 Coupe EX: I/H/E +55 shot Dry -> R.I.P.
2000 Coupe EX: Tein Susp./Vitara/I-Beams/GT3076R/Hondata s300/E-85
2009 CBR600RR Phoenix Edition: Stock(ish)
2011 Toyota Tacoma TRD Off-Road 4x4: 3" Lift/255-85R16 KM2 Mud Terrains
2011 Sea-Doo RXT-X 260: Removed Speed Limiter/Solas Prop/Thru-Hull Exhaust
I Rep Back!
Mr Mobsta Man is offline   Reply With Quote Quick reply to this message
Old 04-12-2008, 07:26 PM   #11 (permalink)
it passed. hell yea turbo should be in on tue if the credit card wasnt declined hah
Old 04-12-2008, 07:43 PM   #12 (permalink)
OMG TOTALLY COOL TITLE!!!!
si-hatch86's Avatar
Rep Power: 32 si-hatch86 is on a level you can only DREAM about! ! !si-hatch86 is on a level you can only DREAM about! ! !si-hatch86 is on a level you can only DREAM about! ! !
iTrader Score: 15 reviews
Send a message via AIM to si-hatch86 Send a message via MSN to si-hatch86 Send a message via Yahoo to si-hatch86
boost till it goes then rebuild/build it
RIP Pat Primmer
RIP MILO
si-hatch86 is offline   Reply With Quote Quick reply to this message
Old 04-13-2008, 09:18 AM   #13 (permalink)
shocker911's Avatar
Rep Power: 15 shocker911 is about to kiss the sky
shocker911 is about to kiss the skyshocker911 is about to kiss the skyshocker911 is about to kiss the skyshocker911 is about to kiss the skyshocker911 is about to kiss the skyshocker911 is about to kiss the sky
iTrader Score: 21 reviews
Send a message via AIM to shocker911
find another just in case.....boost it blow it re do it repeat lol
67mm of grocery getting goodness...
my build
add to the list
shocker911 is offline   Reply With Quote Quick reply to this message
iconAll times are GMT -8. The time now is 06:11 AM. | Welcome to Forum, please register to access all of our features.
