3" electronic exhaust butterfly valve - D-series.org
Old 01-15-2016, 01:40 AM   #1 (permalink)
Rep Power: 14 Lyle_57IAL smells like BoratLyle_57IAL smells like BoratLyle_57IAL smells like BoratLyle_57IAL smells like BoratLyle_57IAL smells like Borat
Send a message via MSN to Lyle_57IAL
Default 3" electronic exhaust butterfly valve
Hey guys,
Considering running a inline 3" exhaust butterfly valve. The goes is to reduce idle noise and partial throttle / highway drone. To be triggered by an auxiliary output by my hondata based on TPS and / or RPM
Would like something that is high quality, Fail open and voltage to close design. ideally have the butterfly slightly smaller then the exhaust ID so its not completely restrictive
Ideas anyone?
Lyle
Lyle_57IAL is offline   Reply With Quote Quick reply to this message
Old 01-15-2016, 05:37 AM   #2 (permalink)
CandyRedRC46's Avatar
Rep Power: 5 CandyRedRC46  is accepted as part of the communityCandyRedRC46  is accepted as part of the communityCandyRedRC46  is accepted as part of the communityCandyRedRC46  is accepted as part of the community
so an exhaust cut out, y pipe? or just the butterfly valve section it self?
CandyRedRC46 is offline   Reply With Quote Quick reply to this message
Old 01-15-2016, 05:45 AM   #3 (permalink)
Honestly I would just get a Varex muffler, before messing with cutouts.
Varex Mufflers
Old 01-15-2016, 06:36 AM   #4 (permalink)
Rep Power: 14 grayzee is almost a somebodygrayzee is almost a somebodygrayzee is almost a somebodygrayzee is almost a somebody
Varex Mufflers
How come you didn't post that in the VT muffler thread?
I will buy a American car when the fucking Japanese build one!
automatic Crx [email protected]
grayzee is offline   Reply With Quote Quick reply to this message
Old 01-15-2016, 07:31 AM   #5 (permalink)
Rep Power: 0 jbreaks is nobody
I've got something similar to that. Just a butterfly valve about 10 inches from the exhaust housing but will a 2psi actuator on it that swings open on boost. It's glorious.
jbreaks is offline   Reply With Quote Quick reply to this message
Old 01-15-2016, 08:57 AM   #6 (permalink)
Apples to oranges... $360 vs $90, I figured it would be struck down pretty quickly as too expensive and not readily available at your local pepboyz store.
Old 01-15-2016, 11:18 AM   #7 (permalink)
TheToaster's Avatar
Rep Power: 16 TheToaster is the fucking MAN!!!!TheToaster is the fucking MAN!!!!TheToaster is the fucking MAN!!!!
TheToaster is the fucking MAN!!!!TheToaster is the fucking MAN!!!!TheToaster is the fucking MAN!!!!TheToaster is the fucking MAN!!!!TheToaster is the fucking MAN!!!!TheToaster is the fucking MAN!!!!TheToaster is the fucking MAN!!!!TheToaster is the fucking MAN!!!!
Magnaflows and J pipe(s)
TheToaster is offline   Reply With Quote Quick reply to this message
Old 01-15-2016, 06:00 PM   #8 (permalink)
shoebox_civic's Avatar
Originally Posted by Lyle_57IAL View Post
Hey guys,
Ideas anyone?
Lyle
You could put an inline electric cutout between two flanges. Usually theyre done on a Y but you could easily do it inline
99 CRV
17 Q50 2.0T
07 350Z touring
Old 01-15-2016, 06:01 PM   #9 (permalink)
Theyre lock in last failure mode though
99 CRV
17 Q50 2.0T
07 350Z touring
Old 01-15-2016, 06:24 PM   #10 (permalink)
Why not a simple stepped down exhaust system????
No power loss, less drone, better EGV/scavenging.
Old 01-16-2016, 08:12 AM   #11 (permalink)
I am running a full mandrel bent 2.5 inch exhaust with a bisi header, vibrant 12 inch resonator, magnaflow 18 in resonator and magnaflow 5x8 oval end muffler and honestly its one the quite side when youre putting around, but it gets loud when you get on it and has that typical resonance at 4000 rpm and heavy loads. If I could do it again I would probably have traded the tiny vibrant 12 incher for a second 18 inch magnaflow, but I'll probably just deal with it until I go turbo, then go full 3inch mandrel and get a 3.5 inch varex rear muffler and a 22 inch magnaflow resonator, which on a turbo build should sound great.
Old 01-16-2016, 03:57 PM   #12 (permalink)
Anyone ever used the jegs electric cutout
iconAll times are GMT -8. The time now is 03:41 AM. | Welcome to Forum, please register to access all of our features.
