V-AFC With Turbo - D-series.org
Old 01-29-2005, 06:51 AM   #1 (permalink)
SleepingCRX88's Avatar
Rep Power: 15 SleepingCRX88 will become famous soon enoughSleepingCRX88 will become famous soon enoughSleepingCRX88 will become famous soon enough
Send a message via AIM to SleepingCRX88
Default V-AFC With Turbo
K i have been reading and i was wondering is it not good to run a V-AFC with a turbo. Have been tossed around read that some ppl say its perfectly fine and others not? Whats some opions and facts?
SleepingCRX88 is offline   Reply With Quote Quick reply to this message
Old 01-29-2005, 07:09 AM   #2 (permalink)
13g-crx's Avatar
Rep Power: 17 13g-crx It's a JDM Star Bitches....
13g-crx It's a JDM Star Bitches....13g-crx It's a JDM Star Bitches....13g-crx It's a JDM Star Bitches....13g-crx It's a JDM Star Bitches....13g-crx It's a JDM Star Bitches....
At one point a rising rate FPR was the way to go untill the AFC came along. Now things have advanced again and we have ecu chipping. To make a long story short, the afc hack doesn't continually adjust your timing per lbs of boost like a chipped ECU will. It just keeps your timing stock.
13g-crx is offline   Reply With Quote Quick reply to this message
Old 01-29-2005, 10:26 AM   #3 (permalink)
HMT.com GOD
Dr.Boost's Avatar
Rep Power: 16 Dr.Boost is learning the way of the DDr.Boost is learning the way of the D
Incorrect. The AFC when used with larger injectors advances your timing, which is what makes it bad for forced induction.
Obviously a chipped ECU running TurboEdit/Uberdata/Crome/yada yada...is better, but you can do it. I wouldn't suggest running over ~10psi with it, but it can be safe. I would also suggest retarding your base timing or using a BTM to retard timing per psi.
Dr.Boost is offline   Reply With Quote Quick reply to this message
Old 02-01-2005, 12:10 PM   #4 (permalink)
rotory20's Avatar
Rep Power: 0 rotory20 is hot as a volcano
rotory20 is hot as a volcanorotory20 is hot as a volcanorotory20 is hot as a volcanorotory20 is hot as a volcanorotory20 is hot as a volcanorotory20 is hot as a volcanorotory20 is hot as a volcanorotory20 is hot as a volcanorotory20 is hot as a volcanorotory20 is hot as a volcanorotory20 is hot as a volcanorotory20 is hot as a volcano
With the technology and cost of it the AFC aint worth shit imo
rotory20 is offline   Reply With Quote Quick reply to this message
Old 02-01-2005, 04:34 PM   #5 (permalink)
konigcivic's Avatar
Rep Power: 17 konigcivic is a name known to allkonigcivic is a name known to allkonigcivic is a name known to allkonigcivic is a name known to allkonigcivic is a name known to allkonigcivic is a name known to allkonigcivic is a name known to allkonigcivic is a name known to allkonigcivic is a name known to allkonigcivic is a name known to all
since im going by your screen name you have a 88crx... go with turboedit.. its cheap and a shit load better then the afc hack.. i ran the hack on my car only cause i have obd2 and its easier for me than to swap to obd1.. if anyones car is obd1 or obd0 do the turboedit or uberdata thing, its so much better...
konigcivic is offline   Reply With Quote Quick reply to this message
Old 02-01-2005, 04:53 PM   #6 (permalink)
the hard-parker
Sonny7730's Avatar
Rep Power: 26 Sonny7730 is the fucking MAN!!!!Sonny7730 is the fucking MAN!!!!Sonny7730 is the fucking MAN!!!!Sonny7730 is the fucking MAN!!!!
Sonny7730 is the fucking MAN!!!!Sonny7730 is the fucking MAN!!!!Sonny7730 is the fucking MAN!!!!Sonny7730 is the fucking MAN!!!!Sonny7730 is the fucking MAN!!!!
iTrader Score: 16 reviews
but if you do, make sure you have someone to help teach you the tuning techniques...we don't want you blowing up your car.
D is in my heart for life
1998 honda civic ex coupe
1998 jeep cherokee sport 4x4
2004 subaru impreza wrx wagon
2002 honda accord v6 coupe
Sonny7730 is offline   Reply With Quote Quick reply to this message
Old 02-07-2005, 02:19 PM   #7 (permalink)
mark7901's Avatar
Rep Power: 16 mark7901 is da #1 stunnamark7901 is da #1 stunnamark7901 is da #1 stunnamark7901 is da #1 stunnamark7901 is da #1 stunnamark7901 is da #1 stunnamark7901 is da #1 stunna
Send a message via AIM to mark7901
With the AFC hack, you need 450cc injectors, VAFC, upgraded fuel pump. Do you still need the resistors? If so, do you need to solder the resistors into BOTH f.i. wires? (both yellow and black) or just one of the wires?
mark7901 is offline   Reply With Quote Quick reply to this message
Old 02-15-2005, 03:19 PM   #8 (permalink)
HMT.com GOD
Dr.Boost's Avatar
Originally Posted by mark7901
Its both wires...just found out.
Ummm...no it's not. You use the yellow with a black stripe and don't touch the other wire.
Old 02-15-2005, 03:22 PM   #9 (permalink)
mark7901's Avatar
According to this its both wires...is this wrong?
http://www.beesandgoats.com/boostfaq...tml#Management
EDIT, nevermind...thats one wire with a black stripe! LOL, got ya...sorry...Im an idiot.
Old 02-16-2005, 07:59 AM   #10 (permalink)
mark7901's Avatar
So what if I modded JUST my ignition tables and burned them to a chip. Then used the AFC hack for the real time fuel adjustment? Does that make sence? It would be BOTH chipped and hacked. Or would it just be easier to use a BTM? I like the idea of the real time fuel adjustment with the AFC, I dont like how it advances the timing. In saying that, couldn't I just modify the ignition tables on my .bin map (for the timing issues) and leave the fuel tables alone. Then use the AFC to control fuel curves on the fly?
Old 02-16-2005, 04:37 PM   #11 (permalink)
HMT.com GOD
Dr.Boost's Avatar
AFC is a hack. Period. If you're going to run a rom editor, run a rom editor. I was using an AFC along with TurboEdit for a while, but then I got smart and realized how lame that was. That's like matorbating with no lube instead of fucking a hot college girl on birth control.
Old 02-16-2005, 04:59 PM   #12 (permalink)
average joe
S Q A D's Avatar
Rep Power: 22 S Q A D is about to kiss the sky
S Q A D is about to kiss the skyS Q A D is about to kiss the skyS Q A D is about to kiss the skyS Q A D is about to kiss the skyS Q A D is about to kiss the skyS Q A D is about to kiss the skyS Q A D is about to kiss the sky
dr. boost > *
S Q A D is offline   Reply With Quote Quick reply to this message
Old 02-16-2005, 05:33 PM   #13 (permalink)
mark7901's Avatar
Belive me, I completly agree. I know the hack will never replace a true rom. The only advantage I gain by doing both is that I can change fuel tables on the fly. Nothing more or less. I think that is the only apealing idea in the whole situation. In your opinion, cause belive me it counts to me, would it be that bad of an idea?
Old 02-16-2005, 06:21 PM   #14 (permalink)
No more Honda's :-(
FMYStreetRacer's Avatar
Rep Power: 17 FMYStreetRacer is a name known to allFMYStreetRacer is a name known to allFMYStreetRacer is a name known to allFMYStreetRacer is a name known to allFMYStreetRacer is a name known to allFMYStreetRacer is a name known to allFMYStreetRacer is a name known to allFMYStreetRacer is a name known to allFMYStreetRacer is a name known to allFMYStreetRacer is a name known to all
Send a message via MSN to FMYStreetRacer
tune it with turbo edit and leave it alone. or just tune it on turbo edit and keep the afc hooked up and you will still be bale to make changes. if you are still stuck on useing the hack just get a BTM and use the hack and call it a day.
97 Cherokee SE, 3" Lift, 31x10.50's on soft 8's
83 RX-7 Wide Body, 4-port 13B street-ported, Cartech turbo system with blow through carbs
03 Kawasaki KLX400R tagged
FMYStreetRacer is offline   Reply With Quote Quick reply to this message
Old 02-16-2005, 07:46 PM   #15 (permalink)
HMT.com GOD
Dr.Boost's Avatar
It's not that it's such a bad idea, it's just that it defeats the purpose of having a fully tuneable engine management system. With TurboEdit you have complete control over your entire fuel/ignition maps. When you start changing settings with the AFC you start throwing those maps all off. A good tune on TurboEdit shouldn't need any adjustments. I've used basemaps that required little to no tuning, and even an untuned basemap is better than a "tuned" AFC. You can't really "tune" with an AFC anyways.
I dunno, if you can come up with a good tune on TurboEdit, you shouldn't need to change anything with an AFC. I understand not everybody has wideband setups and laptops and chip burners, but if you're going to be messing around with turbos on your motor and you want it to last, you need to bite the bullet and make an investment. I think that was the best purchase I have ever made for my car.
Old 02-16-2005, 09:21 PM   #16 (permalink)
the MAD scientist
mikeD16Z6's Avatar
Rep Power: 19 mikeD16Z6 is a Top Aussie
mikeD16Z6 is a Top AussiemikeD16Z6 is a Top AussiemikeD16Z6 is a Top AussiemikeD16Z6 is a Top AussiemikeD16Z6 is a Top AussiemikeD16Z6 is a Top AussiemikeD16Z6 is a Top AussiemikeD16Z6 is a Top AussiemikeD16Z6 is a Top AussiemikeD16Z6 is a Top AussiemikeD16Z6 is a Top Aussie
iTrader Score: 25 reviews
If you want real time programing you dont need the hack...you can get one of these
http://www.moates.net/product_info.p...products_id=57
People are using them and they work.
All you need is a laptop
mikeD16Z6 is offline   Reply With Quote Quick reply to this message
Old 02-17-2005, 07:30 AM   #17 (permalink)
mark7901's Avatar
A good tune on TurboEdit shouldn't need any adjustments. I've used basemaps that required little to no tuning, and even an untuned basemap is better than a "tuned" AFC. You can't really "tune" with an AFC anyways. .
I didnt know that.
I have all of this except a wideband.
Well, I would use Uberdata. After messing around with it agian last night, I see your point. It was all quite new to me since that last time I used Uber, when I went to the datalogging tab, I had nothing. I could never set my COM port (part of the reason I gave up). Last night I downloaded it to a new pc, and I coud see all that info. Even saw the A/F charts, could that be used as a wideband?
So you are saying that I can burn a base map that can be so close, that I wouldnt need any fine tuning? I didnt know that either.
iconAll times are GMT -8. The time now is 09:23 PM. | Welcome to Forum, please register to access all of our features.
