6.0l powerstoke diesel turbos, i has questions - D-series.org
Old 01-12-2012, 02:54 PM   #1 (permalink)
Rep Power: 11 MEERVINCENT is learning the way of the DMEERVINCENT is learning the way of the D
Default 6.0l powerstoke diesel turbos, i has questions
i found a 6.0 VGTurbo for 100$ but have no idea if i could use it on a honda or not.
here's a cut-away
http://www.fordtechservice.dealercon...6lvgtguide.pdf
and a bunch more info
VGT turbo ABC's - Ford Truck Enthusiasts Forums
more info*
here's a guy using one on a 7.3l diesel, sounds like the vgt can be manually controlled and oil issues can be resolved with a small electric oil pump
http://www.powerstroke.org/forum/99-...wd-launch.html
it has an electronically controlled solenoid that controls oil pressure being fed to the turbo changing the vein position. considering the size of the engine its coming from i would imagine having them locked in the "smallest" position would be just fine. I don't think I've ever seen one of these turbos used on a Honda, or anything other then a ford truck. any of you turbo guru's have an idea's as to if this turbo would be even usable?
MEERVINCENT is offline   Reply With Quote Quick reply to this message
Old 01-12-2012, 02:58 PM   #2 (permalink)
Rep Power: 0 dan-lee is nobody
you run into probleme whit that turbo simply buy a knock off from ebay and run it and when that clone die rebuilt it whit garret rebuilt kit
dan-lee is offline   Reply With Quote Quick reply to this message
Old 01-12-2012, 03:02 PM   #3 (permalink)
HB turbo-->'s Avatar
Rep Power: 9 HB turbo--> smells like BoratHB turbo--> smells like BoratHB turbo--> smells like BoratHB turbo--> smells like BoratHB turbo--> smells like Borat
It's a awsome idea that they use on it, but its going to be a pita to adapt to the D.
If its not too big, go for it!
( I was actually just looking at one similar to that we were puting on a diesel rebuild this last weekend)
HB turbo--> is offline   Reply With Quote Quick reply to this message
Old 01-12-2012, 03:07 PM   #4 (permalink)
i was actually panning on using it with a stroked gs-r (ls crank) likely punched over at least a mm or 2. if the bigger holsets work with a built d spinning this thing should be no problem. in one of the threads i was reading on them a guy got a rebuild kit from garret so i think I'm gonna start looking there.
Old 01-12-2012, 03:27 PM   #5 (permalink)
turboprelude95's Avatar
Rep Power: 28 turboprelude95 Still a JDM Star....
turboprelude95 Still a JDM Star....turboprelude95 Still a JDM Star....turboprelude95 Still a JDM Star....turboprelude95 Still a JDM Star....turboprelude95 Still a JDM Star....turboprelude95 Still a JDM Star....
GTFO!!!! FUCK cdm junk!!!
Seen a guy control it using a internal WG.
Crx
Jswap 4dr
Boost 4dr
Twin scrol
F2B
turboprelude95 is offline   Reply With Quote Quick reply to this message
Old 01-12-2012, 03:30 PM   #6 (permalink)
got any links?
Old 01-12-2012, 04:22 PM   #7 (permalink)
Rep Power: 9 spadesEG is nobody
Idk its a bitch to control the vgt on those turbo motor and in my opinion not a reliable way too keep boost in check... I did a bunch oh reaserch because I was going to use a vgt holset from 6.7
spadesEG is offline   Reply With Quote Quick reply to this message
Old 01-12-2012, 04:24 PM   #8 (permalink)
in the last link on my first post there is a guy that claimed to have manual control of the vgt, im thinking if that's the can why wouldn't you be able to simply set it to one position and leave it there
Old 01-12-2012, 04:38 PM   #9 (permalink)
Ill find a link for you
Old 01-12-2012, 04:43 PM   #10 (permalink)
I don't know if it will work the same on garrett turbo... either way the vgt it there to help the turbo spool faster so I think it would take a lot of tinkering to find the perfect adjustment for your application
Holset he351 VGT is goin on my car - DSM Forums
Old 01-12-2012, 08:09 PM   #11 (permalink)
Login
Crx
Jswap 4dr
Boost 4dr
Twin scrol
F2B
Old 01-12-2012, 09:18 PM   #12 (permalink)
turboprelude95 to big for fast spool like t28/18g for your vgt is another break possibility
i see my friend ek hatch whit ebay kit run 3 year the turbo fail due to cheap oil pass
in my book i see t3t4 on ebay at 200$ take that and when it fail rebuilt it and have better powerband and fast spool !
Old 01-12-2012, 09:55 PM   #13 (permalink)
cervan's Avatar
Rep Power: 25 cervan is the fucking MAN!!!!cervan is the fucking MAN!!!!cervan is the fucking MAN!!!!cervan is the fucking MAN!!!!
Its alot of trouble for not a whole lot of gain. And ive also heard of the vanes melting because they get too hot.
1990 crx - 12.2 @ 119mph Sold
Old 01-14-2012, 07:38 AM   #14 (permalink)
13g-crx's Avatar
Rep Power: 17 13g-crx It's a JDM Star Bitches....
13g-crx It's a JDM Star Bitches....13g-crx It's a JDM Star Bitches....13g-crx It's a JDM Star Bitches....13g-crx It's a JDM Star Bitches....13g-crx It's a JDM Star Bitches....
I've always wondered if you could control it with an old internal wastegate and a mac valve/s300 the same way you would do boost by gear.
13g-crx is offline   Reply With Quote Quick reply to this message
Old 01-14-2012, 07:49 AM   #15 (permalink)
AutoXCivic's Avatar
Rep Power: 25 AutoXCivic Still a JDM Star....
AutoXCivic Still a JDM Star....AutoXCivic Still a JDM Star....AutoXCivic Still a JDM Star....AutoXCivic Still a JDM Star....AutoXCivic Still a JDM Star....AutoXCivic Still a JDM Star....AutoXCivic Still a JDM Star....AutoXCivic Still a JDM Star....AutoXCivic Still a JDM Star....AutoXCivic Still a JDM Star....
Send a message via AIM to AutoXCivic Send a message via MSN to AutoXCivic Send a message via Yahoo to AutoXCivic
I've heard that the AEM EMS can be used to control VGT. But I just found this on a DSM forum which goes into a bit of the logistics of actually getting one to work.
Straight lines are for sissies.
<--- Stolen
<--- Sold.
barrel roll in airplane > barrel roll in nsx
AutoXCivic is offline   Reply With Quote Quick reply to this message
Old 01-16-2012, 09:49 PM   #16 (permalink)
blackstar_1's Avatar
Rep Power: 8 blackstar_1 is learning the way of the Dblackstar_1 is learning the way of the D
If You choose to buy a chines turbo have it rebuilt before you put it on most turbo repair shops charge extra for cleaning
blackstar_1 is offline   Reply With Quote Quick reply to this message
iconAll times are GMT -8. The time now is 09:17 AM. | Welcome to Forum, please register to access all of our features.
