5 bolt downpipe - D-series.org
Old 03-01-2011, 04:17 PM   #1 (permalink)
TurbodHatchy's Avatar
Rep Power: 0 TurbodHatchy is nobody
Default 5 bolt downpipe
are all 2.5" 5 bolt downpipes the same? because ive seen on some made for b16 and b18 and some for d16 and d15 are they all the same ? because they look the same to me just different price. Im lookinf for a down for my d16z6 i just want to know if any 5 bolt pattern would fit?
TurbodHatchy is offline   Reply With Quote Quick reply to this message
Old 03-01-2011, 05:11 PM   #2 (permalink)
D2ZBOY's Avatar
Rep Power: 11 D2ZBOY is da #1 stunnaD2ZBOY is da #1 stunnaD2ZBOY is da #1 stunnaD2ZBOY is da #1 stunnaD2ZBOY is da #1 stunnaD2ZBOY is da #1 stunnaD2ZBOY is da #1 stunna
They should be the same.
D2ZBOY is offline   Reply With Quote Quick reply to this message
Old 03-01-2011, 05:33 PM   #3 (permalink)
boostfreak0885's Avatar
Rep Power: 20 boostfreak0885 is hot as a volcanoboostfreak0885 is hot as a volcano
boostfreak0885 is hot as a volcanoboostfreak0885 is hot as a volcanoboostfreak0885 is hot as a volcanoboostfreak0885 is hot as a volcanoboostfreak0885 is hot as a volcanoboostfreak0885 is hot as a volcanoboostfreak0885 is hot as a volcanoboostfreak0885 is hot as a volcanoboostfreak0885 is hot as a volcanoboostfreak0885 is hot as a volcanoboostfreak0885 is hot as a volcanoboostfreak0885 is hot as a volcano
Send a message via AIM to boostfreak0885
ebay right...??? some of the bolt holes dont line up
my new and improved build... check it out
best time so far
11.201 at 128mph with a 1.79 60 foot.. damn i need traction, best trap speed is 129mph. 26psi h1c
NEW best 60' 1.56!!!
boostfreak0885 is offline   Reply With Quote Quick reply to this message
Old 03-01-2011, 05:35 PM   #4 (permalink)
boostedsohc's Avatar
Rep Power: 21 boostedsohc is the fucking MAN!!!!boostedsohc is the fucking MAN!!!!boostedsohc is the fucking MAN!!!!
boostedsohc is the fucking MAN!!!!boostedsohc is the fucking MAN!!!!boostedsohc is the fucking MAN!!!!boostedsohc is the fucking MAN!!!!boostedsohc is the fucking MAN!!!!boostedsohc is the fucking MAN!!!!boostedsohc is the fucking MAN!!!!boostedsohc is the fucking MAN!!!!boostedsohc is the fucking MAN!!!!boostedsohc is the fucking MAN!!!!
iTrader Score: 55 reviews
Send a message via AIM to boostedsohc
this is true.
but they will still work if you drill out the wholes a bit. and yes they should all be the same.
My boost lag gives your V8 a chance
best times
11.01 @ 129mph 1.8 60ft
11.2 @121mph 1.9 60ft missing 4th
1.77 is the best 60ft so far
Cheap, Fast, Reliable
You may only pick two!
bottles are for babies.... boost gets you laid
boostedsohc is offline   Reply With Quote Quick reply to this message
Old 03-01-2011, 05:48 PM   #5 (permalink)
no not ebay godspeed.net check it out 2.25" turbo downpipe for Honda Civic (b16 b18 motor)
Old 03-01-2011, 05:49 PM   #6 (permalink)
it says b16 b18 motor but would it fit my d16z6? its kinda confusing
Old 03-01-2011, 05:58 PM   #7 (permalink)
chances are that the flange will not line up.
you need to cut and reweld the flange im betting.
the motor on it has nothing to do with it. but there a million different ways it can not fit. every turbo on every manifold will put the flange and downpipe in a different position.
understand what im saying?
best times
Old 03-01-2011, 06:11 PM   #8 (permalink)
yea i get it
Old 03-01-2011, 06:13 PM   #9 (permalink)
should i buy this one anyways and if it doesnt fit cut and reweld? the price is not that bad
Old 03-01-2011, 06:14 PM   #10 (permalink)
its not ebay, but its still ebay/chinese junk.. just saying.
best time so far
Old 03-01-2011, 06:22 PM   #11 (permalink)
any suggestions?
Old 03-01-2011, 06:35 PM   #12 (permalink)
Well.......
2drz6's Avatar
Rep Power: 31 2drz6 is on a level you can only DREAM about! ! !2drz6 is on a level you can only DREAM about! ! !2drz6 is on a level you can only DREAM about! ! !2drz6 is on a level you can only DREAM about! ! !
2drz6 is on a level you can only DREAM about! ! !2drz6 is on a level you can only DREAM about! ! !2drz6 is on a level you can only DREAM about! ! !2drz6 is on a level you can only DREAM about! ! !2drz6 is on a level you can only DREAM about! ! !2drz6 is on a level you can only DREAM about! ! !2drz6 is on a level you can only DREAM about! ! !2drz6 is on a level you can only DREAM about! ! !2drz6 is on a level you can only DREAM about! ! !2drz6 is on a level you can only DREAM about! ! !2drz6 is on a level you can only DREAM about! ! !2drz6 is on a level you can only DREAM about! ! !2drz6 is on a level you can only DREAM about! ! !
iTrader Score: 18 reviews
go autoworks or rc autoworks
Fucking sweet! your last names sweet!
your mother should spank your butt and put you in time out.
2drz6 is offline   Reply With Quote Quick reply to this message
Old 03-01-2011, 06:40 PM   #13 (permalink)
Anonymoussquid's Avatar
Rep Power: 14 Anonymoussquid is about to blow upAnonymoussquid is about to blow upAnonymoussquid is about to blow upAnonymoussquid is about to blow upAnonymoussquid is about to blow upAnonymoussquid is about to blow upAnonymoussquid is about to blow upAnonymoussquid is about to blow upAnonymoussquid is about to blow upAnonymoussquid is about to blow upAnonymoussquid is about to blow upAnonymoussquid is about to blow upAnonymoussquid is about to blow upAnonymoussquid is about to blow up
iTrader Score: 27 reviews
yea just order from go autoworks.. let greg know your setup, he has a lot of manifolds etc he should be able to hook you up.
what manifold are you running? passagner or driverside dump? ac?
271 WHP/ 235tq 14 psi.
other DD 1995 Toyota Tacoma 3 inch lift 33x12.5 toyo M/T tires
On my way to my AA in Diesel technology
Anonymoussquid is offline   Reply With Quote Quick reply to this message
Old 03-01-2011, 06:46 PM   #14 (permalink)
i have a manifold with driver side dump and with downpipe on passenger side
Old 03-01-2011, 06:56 PM   #15 (permalink)
I say its always best to make ur own downpipe . That way it fits just right. But yea u might have to cut and rotate the pipe then weld might even have to add a picese.
Old 03-01-2011, 07:04 PM   #16 (permalink)
i have a cast iron manifold
Old 03-01-2011, 07:16 PM   #17 (permalink)
Well.......
2drz6's Avatar
post pics..... greg will square you away
Old 03-01-2011, 07:17 PM   #18 (permalink)
DCRX's Avatar
Rep Power: 9 DCRX is starting to learn the ropesDCRX is starting to learn the ropesDCRX is starting to learn the ropesDCRX is starting to learn the ropesDCRX is starting to learn the ropesDCRX is starting to learn the ropesDCRX is starting to learn the ropes
I have never found an eBay downpipe that fits right
88 CRX D16Z6
Daily Driven Vitara making [email protected]
Tuned by Kaizenspeed
DCRX is offline   Reply With Quote Quick reply to this message
Old 03-02-2011, 07:39 AM   #19 (permalink)
Sentry's Avatar
Rep Power: 18 Sentry is the fucking MAN!!!!Sentry is the fucking MAN!!!!Sentry is the fucking MAN!!!!
Sentry is the fucking MAN!!!!Sentry is the fucking MAN!!!!Sentry is the fucking MAN!!!!Sentry is the fucking MAN!!!!Sentry is the fucking MAN!!!!
I've never had any mail order downpipe fit right, even from a good shop (Kteller 15g downpipe). It's going to need tweaking anyway if you want a nice fit, so you may as well grab an ebay one for a basis for a custom dp and have an exhaust shop finish it up.
Sentry is offline   Reply With Quote Quick reply to this message
Old 03-02-2011, 07:57 AM   #20 (permalink)
Rep Power: 0 Tacous is nobody
Since adding a turbo to a car that was not turbo from the factory is considered custom, even a bought downpipe will have to be pulled, pushed, or welded. Seems like a pain, but it really is not most muffler shops can fix it up real quick. I've even used hangers to hold my pipes together so I could drive it to the shop lol.
Tacous is offline   Reply With Quote Quick reply to this message
iconAll times are GMT -8. The time now is 09:32 PM. | Welcome to Forum, please register to access all of our features.
