If your not boosting can u slowly being the rpm above 5k?
It could be a few things. Boost cut. Spark blowing out because gap is 2 big. Bad tune. Dizzy.
Post some more specs. Ur motor , turbo, fuel mangment, spark plug gap, rev over 5k when not bossting?
yes it will go past 5000rpm with out boost. got new plug today going it pit them in. the motor is a6/z6 with y8 cam tuned on turbo edit with no boost cut and on 10psi in wastegate. stock map and 240 inj .
the ecu is pm6 with vtec wired in to a auto relay. i am useing turbo edit with vtec. i got it from xenocron.com that were i got all my ecu chipping parts from.
SO I PUT NEW PLUG IN IT AND IT RUN GREAT AND IT GO PAST 5000 rpm all i need was new NGK IN IT at .044. the old plug are number 1 at .058 and 2 at .052 and 3 at .051 and 4 at .052.
