2.5 map w/stock ecu - D-series.org
Old 11-24-2008, 12:40 PM   #1 (permalink)
Slowhatch's Avatar
Rep Power: 14 Slowhatch is starting to learn the ropesSlowhatch is starting to learn the ropesSlowhatch is starting to learn the ropesSlowhatch is starting to learn the ropesSlowhatch is starting to learn the ropesSlowhatch is starting to learn the ropes
Default 2.5 map w/stock ecu
Just wondering if my car will run alright when I install the 2.5bar Motorola map sensor?
I'm finally getting it tuned this Friday and I'm going to prep my car on Thursday. I'm waay excited oh and I did use the search button.
D16z6
Vitaras + FJT I-beams
Rock Rod bearings
OEM Main bearings
RC Autoworks ramhorn
T3 .42/.48
Precision 780's
Delta 272-2
Supertech valve springs
ARP Headstuds
Street tuned on a s300 by eee-jay-ate
Old tune: 240whp/204tq
Slowhatch is offline   Reply With Quote Quick reply to this message
Old 11-24-2008, 01:18 PM   #2 (permalink)
Friend of the D
Aragorn's Avatar
Rep Power: 26 Aragorn Still a JDM Star....Aragorn Still a JDM Star....
Aragorn Still a JDM Star....Aragorn Still a JDM Star....Aragorn Still a JDM Star....Aragorn Still a JDM Star....
Nope, you need the settings in the .bin changed so everything works correctly. It'll have to go in at the shop unless you have the ability to make the change and burn a new chip.
Aragorn is offline   Reply With Quote Quick reply to this message
Old 11-24-2008, 01:20 PM   #3 (permalink)
99EJ6T's Avatar
Rep Power: 45 99EJ6T is on a level you can only DREAM about! ! !99EJ6T is on a level you can only DREAM about! ! !99EJ6T is on a level you can only DREAM about! ! !
iTrader Score: 32 reviews
correct. if you install it, the ecu will not know whats going on with the engine.
Old 11-24-2008, 01:27 PM   #4 (permalink)
formerly Kit88
Hugo Boost's Avatar
Rep Power: 29 Hugo Boost Still a JDM Star....
Hugo Boost Still a JDM Star....Hugo Boost Still a JDM Star....Hugo Boost Still a JDM Star....Hugo Boost Still a JDM Star....Hugo Boost Still a JDM Star....Hugo Boost Still a JDM Star....Hugo Boost Still a JDM Star....Hugo Boost Still a JDM Star....Hugo Boost Still a JDM Star....
iTrader Score: 76 reviews
Send a message via MSN to Hugo Boost
You can split the map wires to hook the 2.5 bar map sensor, but keep connected the oem map, then when you are on the shop, connect the 2.5 and disconnect the oem.
11.07 at 118 mph
Thanks to my sponsors:
FJ Distributors, Special Project Motorsports (Kiwi) ,Performance Porting,Transzex, Alexracing, RSM motorsports, Go-Autoworks, D-series.org, SpeedFactory, Bisimoto
Hugo Boost is offline   Reply With Quote Quick reply to this message
Old 11-24-2008, 01:44 PM   #5 (permalink)
boostfreak0885's Avatar
Rep Power: 20 boostfreak0885 is hot as a volcanoboostfreak0885 is hot as a volcano
boostfreak0885 is hot as a volcanoboostfreak0885 is hot as a volcanoboostfreak0885 is hot as a volcanoboostfreak0885 is hot as a volcanoboostfreak0885 is hot as a volcanoboostfreak0885 is hot as a volcanoboostfreak0885 is hot as a volcanoboostfreak0885 is hot as a volcanoboostfreak0885 is hot as a volcanoboostfreak0885 is hot as a volcanoboostfreak0885 is hot as a volcanoboostfreak0885 is hot as a volcano
Send a message via AIM to boostfreak0885
bingo, mount everything, run the wires, and just unplug the stock map and plug the new one in.
my new and improved build... check it out
best time so far
11.201 at 128mph with a 1.79 60 foot.. damn i need traction, best trap speed is 129mph. 26psi h1c
NEW best 60' 1.56!!!
boostfreak0885 is offline   Reply With Quote Quick reply to this message
Old 11-24-2008, 02:29 PM   #6 (permalink)
racist-bigot-sexist-homophob
mindless's Avatar
Rep Power: 43 mindless is on a level you can only DREAM about! ! !mindless is on a level you can only DREAM about! ! !
iTrader Score: 43 reviews
Yup, I have my 3 bar spliced in. If you do this just be sure not to have more than one map sensor plugged in at the same time.
Old 11-24-2008, 02:30 PM   #7 (permalink)
Slowhatch's Avatar
Good idea! Wouldn't the ecu wig out because it is receiving two signals?
Ninja edit: Oh wait, I think I know what you mean. Just don't hook up a vacuum hose right?
D16z6
Rock Rod bearings
OEM Main bearings
T3 .42/.48
Precision 780's
Delta 272-2
ARP Headstuds
Old 11-24-2008, 02:30 PM   #8 (permalink)
mindless's Avatar
see my post.
Old 11-24-2008, 02:33 PM   #9 (permalink)
Slowhatch's Avatar
Originally Posted by mindless View Post
see my post.
I ninja edited
D16z6
Rock Rod bearings
OEM Main bearings
T3 .42/.48
Precision 780's
Delta 272-2
ARP Headstuds
Old 11-24-2008, 02:35 PM   #10 (permalink)
mindless's Avatar
No, don't have more than one map sensor physically plugged in at one time. I spliced mine in and tried to start the car with both the 3 bar and stock sensor plugged into the harness and the car wouldn't start / ran like ass when it did start.
Old 11-24-2008, 02:41 PM   #11 (permalink)
Slowhatch's Avatar
Ooooh. Maybe I should just solder it in at the shop. Lol I'm not really pickin' up what your puttin' down. I didn't want to be that awkward guy trying to do a shitty solder on his map sensor with pink heat shrink lol.
D16z6
Rock Rod bearings
OEM Main bearings
T3 .42/.48
Precision 780's
Delta 272-2
ARP Headstuds
Old 11-24-2008, 02:47 PM   #12 (permalink)
Rep Power: 0 Lude-icious!  is slowly gaining respectLude-icious!  is slowly gaining respectLude-icious!  is slowly gaining respectLude-icious!  is slowly gaining respectLude-icious!  is slowly gaining respect
solder on spade connectors, you can always re-solder it after your done at the shop.
Lude-icious! is offline   Reply With Quote Quick reply to this message
Old 11-24-2008, 02:50 PM   #13 (permalink)
mindless's Avatar
Ok, you have two options when it comes to your map sensor:
1. Snip the oem plug off and solder in the plug for the 2.5 bar
or
2. Splice into the OEM harness so that you are able to run either then stock or 3 bar map sensor.
What I was saying is that if you do splice into the OEM harness for the 2.5 bar just be sure not to have both map sensors hooked up at one time. For example, I spliced the plug for my 3 bar into the OEM harness. Right now, on my car, the stock map sensor is hooked up and the plug for the the bar is sitting there waiting. Once I do plug the actual three bar sensor back into its plug (which again is already soldered into the OEM harness) then I need to unplug the OEM map sensor.
Your car is obd1 correct? If so, you have a TB mounted map sensor correct? If so, same principal applies but you will have to swap the map sensor on the TB itself.
Make sense?
Old 11-24-2008, 04:00 PM   #14 (permalink)
very easy dude
Name:	map sensor.jpg
best time so far
Old 11-25-2008, 11:32 AM   #15 (permalink)
Slowhatch's Avatar
or
Make sense?
Ahhh I see what you're saying. I got confused because the Motorola's don't have plugs, just 4 wires coming out of the sensor.
D16z6
Rock Rod bearings
OEM Main bearings
T3 .42/.48
Precision 780's
Delta 272-2
ARP Headstuds
Old 11-25-2008, 12:01 PM   #16 (permalink)
Rep Power: 16 ghettoturbo is almost a somebodyghettoturbo is almost a somebodyghettoturbo is almost a somebodyghettoturbo is almost a somebody
Where did you get it from? We use a plug on our motorola 2.5 bar sensors that you can pull off, just be sure to put it back on the same way
ghettoturbo is offline   Reply With Quote Quick reply to this message
Old 11-25-2008, 06:41 PM   #17 (permalink)
Slowhatch's Avatar
I got it from phearable.com
D16z6
Rock Rod bearings
OEM Main bearings
T3 .42/.48
Precision 780's
Delta 272-2
ARP Headstuds
Old 11-25-2008, 08:02 PM   #18 (permalink)
and the wires are soldered on or do they lead into a little black plug?
Old 11-25-2008, 08:21 PM   #19 (permalink)
Slowhatch's Avatar
They look soldered on. There is black heat shrink around where the wires connect to the sensor and I don't want to pull hard enough to break it or something.
D16z6
Rock Rod bearings
OEM Main bearings
T3 .42/.48
Precision 780's
Delta 272-2
ARP Headstuds
iconAll times are GMT -8. The time now is 12:18 PM. | Welcome to Forum, please register to access all of our features.
