3" sports CAT's - D-series.org
Old 11-18-2008, 12:03 PM   #1 (permalink)
clinchy's Avatar
Rep Power: 12 clinchy is learning the way of the Dclinchy is learning the way of the D
Send a message via MSN to clinchy
Default 3" sports CAT's
hey people.
looking for a 3" sports cat or 2.5" at minimum for my D16Z6. im looking to import from the states as they are 230 over here and ive heard you can get them for $90 in the states.
so any brands or links would be really helpful.
cheers.
luke.
high compression Z6 build
clinchy is offline   Reply With Quote Quick reply to this message
Old 11-18-2008, 12:06 PM   #2 (permalink)
99EJ6T's Avatar
Rep Power: 45 99EJ6T is on a level you can only DREAM about! ! !99EJ6T is on a level you can only DREAM about! ! !99EJ6T is on a level you can only DREAM about! ! !
iTrader Score: 32 reviews
why are you looking at adding a cat? and i would just try to get one from something with a 3 inch cat stock..
Old 11-18-2008, 12:35 PM   #3 (permalink)
Rep Power: 0 1_bad_sol is nobody
Originally Posted by clinchy View Post
hey people.
cheers.
luke.
magnaflow hi-flow cat... $85 plus shipping
www.procivic.com
1_bad_sol is offline   Reply With Quote Quick reply to this message
Old 11-18-2008, 12:53 PM   #4 (permalink)
Restricted account
Rep Power: 0 brizzle is  EVIL !!!!!!!!
You don't need a 3' inch unless you are boosted dude
brizzle is offline   Reply With Quote Quick reply to this message
Old 11-18-2008, 12:56 PM   #5 (permalink)
99EJ6T's Avatar
Cool
wow newblet... you need to read.
from his sig:
EG5 D16Z6 UKDM
Mini ram turbo manifold
T3/T40E
3" downpipe
Tial 50mm BOV
Tila 38mm W/G
Tuned on crome
222.2 BHP / 173.3 LBFT @ 8.4 PSI
seems like he is boosted to me
Old 11-18-2008, 01:43 PM   #6 (permalink)
clinchy's Avatar
just for emmision reasons here in the UK.
atm the plan is to go from my 3" DP to a 3" CAT and then down to my 2.5" buddyclub system, im having the exhaust place fab up a straight through center section while they move the O2 bungs slightly.
will this work? http://www.procivic.com/pages-produc...916/index.html
i could have the new straight through center section extended to the DP and this CAT welded into it.
Old 11-18-2008, 01:47 PM   #7 (permalink)
99EJ6T's Avatar
well here is the issue. "high flow" cats are normally just resonators or weld ons that look like a cat. there are a few on the market that are actually catalytic converters. these are often listed with the cell count of the cat listed.
Old 11-18-2008, 02:51 PM   #8 (permalink)
cool title
egriffith45's Avatar
Rep Power: 15 egriffith45 is approaching greatnessegriffith45 is approaching greatnessegriffith45 is approaching greatnessegriffith45 is approaching greatnessegriffith45 is approaching greatnessegriffith45 is approaching greatnessegriffith45 is approaching greatnessegriffith45 is approaching greatnessegriffith45 is approaching greatnessegriffith45 is approaching greatnessegriffith45 is approaching greatnessegriffith45 is approaching greatnessegriffith45 is approaching greatness
iTrader Score: 22 reviews
Send a message via AIM to egriffith45
says it's epa compliant so it should work.
egriffith45 is offline   Reply With Quote Quick reply to this message
Old 11-18-2008, 04:19 PM   #9 (permalink)
Well?
1.5Slowmatic's Avatar
Rep Power: 33 1.5Slowmatic is on a level you can only DREAM about! ! !1.5Slowmatic is on a level you can only DREAM about! ! !1.5Slowmatic is on a level you can only DREAM about! ! !
1.5Slowmatic is on a level you can only DREAM about! ! !1.5Slowmatic is on a level you can only DREAM about! ! !1.5Slowmatic is on a level you can only DREAM about! ! !1.5Slowmatic is on a level you can only DREAM about! ! !1.5Slowmatic is on a level you can only DREAM about! ! !1.5Slowmatic is on a level you can only DREAM about! ! !1.5Slowmatic is on a level you can only DREAM about! ! !1.5Slowmatic is on a level you can only DREAM about! ! !1.5Slowmatic is on a level you can only DREAM about! ! !1.5Slowmatic is on a level you can only DREAM about! ! !1.5Slowmatic is on a level you can only DREAM about! ! !1.5Slowmatic is on a level you can only DREAM about! ! !
iTrader Score: 38 reviews
Send a message via AIM to 1.5Slowmatic
ill be using a magnaflow cat on my boosted setup, either that or like pat is sayin get one from a diesel truck like he did and use that
lol at everyone talking shit about Fords .. they must of never owned a chevy
Nate is seriously one of those angry white men you read about all the time.
Headlight Harness DIY Upgrade
DIY Ice Box Intake
Resident D-series.org metalhead Alliance member #7
1.5Slowmatic is offline   Reply With Quote Quick reply to this message
Old 11-20-2008, 03:24 AM   #10 (permalink)
clinchy's Avatar
i jus found a UK dealer for the spun CAT, should come in at under 80.
does anyone know the diameter of the buddyclub pro spec center section?
iconAll times are GMT -8. The time now is 05:05 AM. | Welcome to Forum, please register to access all of our features.
