P28 D16y8 - D-series.org
Go Back   D-series.org Ľ Motor Mayhem & Suspension Satisfaction Ľ Engine Management
Old 02-16-2006, 05:11 AM   #1 (permalink)
gimmezell's Avatar
Rep Power: 14 gimmezell is trying to make new friends
Send a message via AIM to gimmezell
Default P28 D16y8
Iíve searched many of forums, but couldnít find an exact answer. Iím going to boost my D16Y8 in a year or so. Because I donít have the funds right now, my plan is to ďcollectĒ the parts I need for the boost project over the next year and install some of the parts as I get them, but only if I can use them without hurting my current setup (basic I/H/E). For my first purchase I was thinking of an ECU, maybe a P28 or the P06 with an OBD2B to OBD1 harness. Kenji211.com is recommended over at Honda-tech as a place to purchase them from.
So my question is, can I use one of these ECUís in my current setup, just plug it in and go? Will I be hurting my performance with one of these ECUís with the current setup? Is it recommended to have a custom VTEC engagement or just leave it? Obviously in the beginning I would like to ďcollectĒ parts that I could use now. Iím open to suggestions.
Thanks for your patience,
Jeremy
gimmezell is offline   Reply With Quote Quick reply to this message
Old 02-16-2006, 05:22 AM   #2 (permalink)
D-Series Post Be-itch... gimme gimme gimme
Rep Power: 19 Richie_A_19 is hot as a volcano
Richie_A_19 is hot as a volcanoRichie_A_19 is hot as a volcanoRichie_A_19 is hot as a volcanoRichie_A_19 is hot as a volcanoRichie_A_19 is hot as a volcanoRichie_A_19 is hot as a volcanoRichie_A_19 is hot as a volcanoRichie_A_19 is hot as a volcanoRichie_A_19 is hot as a volcanoRichie_A_19 is hot as a volcanoRichie_A_19 is hot as a volcanoRichie_A_19 is hot as a volcanoRichie_A_19 is hot as a volcanoRichie_A_19 is hot as a volcanoRichie_A_19 is hot as a volcano
Yes, you would... The P28's fuel and ignition maps are a LOT different... There was a thread not too long ago about this... Here it is Read that and it should answer your ??'s.
Edit: You would have the complete opposite problem...
Richie_A_19 is offline   Reply With Quote Quick reply to this message
Old 02-16-2006, 05:42 AM   #3 (permalink)
Neighborhood Asshole is Back!
00kickercivic's Avatar
Rep Power: 18 00kickercivic is about to kiss the sky
00kickercivic is about to kiss the sky00kickercivic is about to kiss the sky00kickercivic is about to kiss the sky00kickercivic is about to kiss the sky00kickercivic is about to kiss the sky00kickercivic is about to kiss the sky
Send a message via AIM to 00kickercivic
it will run... most likely with a cel... but i wouldnt run it too long as is. I would get it tuned to meet your needs at the time if you wanna do it. If you dont have the time/money for tuning, do the ecu as one of the last things when you are getting your setup finalized.
93 Toyota Supra TT
13 Hyundai Genesis 2.0T
05 SeaDoo RXT
00kickercivic is offline   Reply With Quote Quick reply to this message
Old 02-16-2006, 07:07 AM   #4 (permalink)
gimmezell's Avatar
Thanks for the fast replies. Here's the reply email I received from Kenji at kenji211.com
Jeremy,
You can install my harness and ECU without tuning. I have some
good programs for the SOHC VTEC engines. It is plug and play.
A chipped P28 is $180 shipped or a chipped VTEC P06 ECU is
$150 shipped. They both work EXACTLY the same and even share the same
motherboard.
Please let me know if you have any questions. Thanks.
-kenji
So, what he says is incorrect?
Keep the replies coming!
Old 02-16-2006, 07:22 AM   #5 (permalink)
No he is right. He has it chipped and will load a y8 basemap on there for you instead of the p28 basemap. This will be a pretty good tune but your other variables that you add will alter the tune over time and it will need to be retuned.
93 Toyota Supra TT
05 SeaDoo RXT
Old 02-16-2006, 07:39 AM   #6 (permalink)
gimmezell's Avatar
Alright, I'm learning. So if he loads a y8 basemap onto a P28 will it in way hurt the performance or more important to me my reliability in being a daily driver? Will I gain anything in putting a P28 in now? I'm kind feeling that maybe I should spend the few hundred in something else, is that correct? If so what?
Old 02-16-2006, 07:48 AM   #7 (permalink)
The only way that putting in the p28 now is if you have other mods that could benefit from tuning and you have the programs and whatnot to be able to tune and burn your own chip. I personally would wait to get the whole turbo kit pieced together and on and then throw the p28 on and get it tuned when you have all the parts you are gonna use on there. Otherwise you will just have to be retuning all the time.
93 Toyota Supra TT
05 SeaDoo RXT
Old 02-16-2006, 07:52 AM   #8 (permalink)
Rep Power: 0 berettagtz117 is a Top Aussie
berettagtz117 is a Top Aussieberettagtz117 is a Top Aussieberettagtz117 is a Top Aussieberettagtz117 is a Top Aussieberettagtz117 is a Top Aussieberettagtz117 is a Top Aussieberettagtz117 is a Top Aussieberettagtz117 is a Top Aussieberettagtz117 is a Top Aussieberettagtz117 is a Top Aussieberettagtz117 is a Top Aussie
iTrader Score: 17 reviews
Just run your ECU until you boost!
berettagtz117 is offline   Reply With Quote Quick reply to this message
Old 02-16-2006, 08:00 AM   #9 (permalink)
gimmezell's Avatar
00kickercivic,
I understand what your saying about installing a P28 ECU in now. There would be no point in doing it at this time if i'm looking for any gains. If I did I would have to retune it each time I add a new piece to get anything out of it. Looks like I will be collecting parts.
Let me throw this out there. If I go ahead and install the P28 with a y8 base map and I'm not expecting any gains would that be alright? I would just have it ready to go for the turbo.
Old 02-16-2006, 08:05 AM   #10 (permalink)
yes... if it has a y8 basemap... it should run the same as your y8 ecu that is in there right now
93 Toyota Supra TT
05 SeaDoo RXT
Old 02-16-2006, 09:28 AM   #11 (permalink)
nah... It might be a little loud, loose a little torque, but that is all... Unless you want 250WHP, 2.5 is cool.
Old 02-16-2006, 09:31 AM   #12 (permalink)
gimmezell's Avatar
thanks for the input. I don't have any torque to lose to begin with!
Old 02-16-2006, 09:34 AM   #13 (permalink)
HAHA... Welcome to driving Honda's... Enjoy your stay... lmao
Old 02-17-2006, 08:59 AM   #14 (permalink)
gimmezell's Avatar
Once I get the ECU is there any benefit in lowering the VTEC to 5000 RPM? Is there any real reasons not to?
Old 02-17-2006, 09:19 AM   #15 (permalink)
Rep Power: 0 em dot is nobody
i was also running the p28 on a mini me swap but the 4800 vtec engagement loss power compared to setting it above 5k rpm. also i was wasting a lot of gas when it was set at the stock 4800.
em dot is offline   Reply With Quote Quick reply to this message
Old 02-17-2006, 09:43 AM   #16 (permalink)
gimmezell's Avatar
So, keep it at stock 5500 RPM (I have a '00 EX), or lower it to 5000 RPM?
Old 02-17-2006, 10:54 AM   #17 (permalink)
Falcon7's Avatar
Rep Power: 15 Falcon7 is trying to make new friends
Keep it stock 5500 RPMs... lowering the vtec won't do any good on a stock motor... the only time you should change the vtec at all is if you've done something drastic to modify the performance characteristics of your motor.
Falcon7 is offline   Reply With Quote Quick reply to this message
Old 02-17-2006, 11:16 AM   #18 (permalink)
gimmezell's Avatar
don't drop it down even an extra 500 RPM huh? It's sucks that VTEC is so late on the Y8 5500 RPM. Redline is only at 7000 RPM. I get to only enjoy the wonders of VTEC for only 1500 RPM!
Old 02-17-2006, 11:47 AM   #19 (permalink)
gimmezell's Avatar
John at http://phearable.net doesn't recommend that I get the ECU until i'm ready. That sucks.
Old 02-17-2006, 12:42 PM   #20 (permalink)
gimmezell's Avatar
Damn, I wish I had a few grand laying around! Oh well "All good things come to those who wait"
iconAll times are GMT -8. The time now is 09:31 PM. | Welcome to Forum, please register to access all of our features.
