' 99 p2t ecu SI vtec fit with '99 mini-me y7/y8 swap ? - D-series.org
Old 12-16-2005, 02:07 AM   #1 (permalink)
Curious George
Belette's Avatar
Rep Power: 18 Belette is approaching greatnessBelette is approaching greatnessBelette is approaching greatnessBelette is approaching greatnessBelette is approaching greatnessBelette is approaching greatnessBelette is approaching greatnessBelette is approaching greatnessBelette is approaching greatnessBelette is approaching greatnessBelette is approaching greatnessBelette is approaching greatnessBelette is approaching greatnessBelette is approaching greatness
Default ' 99 p2t ecu SI vtec fit with '99 mini-me y7/y8 swap ?
thank you
Turbo D16y7/8
Setup in building:
Video of my old setup:
Awesome Photography Thread:
Belette is offline   Reply With Quote Quick reply to this message
Old 12-16-2005, 04:56 AM   #2 (permalink)
Rep Power: 0 Devine_wind is trying to make new friends
no you need a p2p
Devine_wind is offline   Reply With Quote Quick reply to this message
Old 12-16-2005, 04:57 PM   #3 (permalink)
Curious George
Belette's Avatar
it's tha same obd2b plugs, so it's table who are so different ?
any comments ?
thank you
Turbo D16y7/8
Setup in building:
Old 12-16-2005, 05:05 PM   #4 (permalink)
Shoot me!
Hellhatch's Avatar
Rep Power: 45 Hellhatch is on a level you can only DREAM about! ! !Hellhatch is on a level you can only DREAM about! ! !Hellhatch is on a level you can only DREAM about! ! !
Hellhatch is on a level you can only DREAM about! ! !Hellhatch is on a level you can only DREAM about! ! !Hellhatch is on a level you can only DREAM about! ! !Hellhatch is on a level you can only DREAM about! ! !Hellhatch is on a level you can only DREAM about! ! !Hellhatch is on a level you can only DREAM about! ! !Hellhatch is on a level you can only DREAM about! ! !Hellhatch is on a level you can only DREAM about! ! !Hellhatch is on a level you can only DREAM about! ! !Hellhatch is on a level you can only DREAM about! ! !Hellhatch is on a level you can only DREAM about! ! !Hellhatch is on a level you can only DREAM about! ! !Hellhatch is on a level you can only DREAM about! ! !Hellhatch is on a level you can only DREAM about! ! !
iTrader Score: 50 reviews
I would think it would work all the same sensors as the ex.Are the pins in the right spots though on the ecu.
Hellhatch is offline   Reply With Quote Quick reply to this message
Old 12-16-2005, 07:12 PM   #5 (permalink)
makku's Avatar
Rep Power: 20 makku is a Top Aussie
makku is a Top Aussiemakku is a Top Aussiemakku is a Top Aussiemakku is a Top Aussiemakku is a Top Aussiemakku is a Top Aussiemakku is a Top Aussiemakku is a Top Aussiemakku is a Top Aussiemakku is a Top Aussiemakku is a Top Aussie
Send a message via AIM to makku Send a message via MSN to makku Send a message via Yahoo to makku
if you have the 2-wire IACV on the minime, then I don't see why it wouldn't work out.
My car: 94 Civic DX sedan w/ JDM D15B VTEC
Trustworthy people: krAzySi, thesqad127, Turntune, Civic4ges, Sonny7730, mark7901, miked16z6, Low EG-T
forecast for tomorrow... a few sprinkles of genius with a chance for DOOM!
But I thought you said TV was bad?
It is... but we fucking need it.
makku is offline   Reply With Quote Quick reply to this message
Old 12-16-2005, 07:45 PM   #6 (permalink)
shifty35's Avatar
Rep Power: 16 shifty35 is a name known to allshifty35 is a name known to allshifty35 is a name known to allshifty35 is a name known to allshifty35 is a name known to allshifty35 is a name known to allshifty35 is a name known to allshifty35 is a name known to allshifty35 is a name known to allshifty35 is a name known to all
Work, yes. Work well, no.
What is it and will the doom hit the valve when vtec is engaged?
'00 Honda Insight - the commuter, 70+ mpg
'90 Mazda Miata - Weekend Fun Car
'04 Toyota Prius - Wife / family car
shifty35 is offline   Reply With Quote Quick reply to this message
Old 12-17-2005, 03:26 AM   #7 (permalink)
Curious George
Belette's Avatar
like shifty35 said, it will work well due to different powerband and fuel/ignition table ?
thank you
Turbo D16y7/8
Setup in building:
Old 12-17-2005, 03:50 AM   #8 (permalink)
the p2t and a 99-00 p2p is totally different. the p2p has more pins on the middle part. the 99-00 is different in comparison between the 96-00 p2p, also in shape. I do however have a 98 p2p sittin in my garage, though.
Old 12-17-2005, 10:45 AM   #9 (permalink)
Curious George
Belette's Avatar
I need OBD2b 99-00 p2p ecu. 98 won't fit on my harness plug.
Does OBD2b p2t use the same plugs pattern as p2p one ?
Turbo D16y7/8
Setup in building:
Old 12-18-2005, 01:02 PM   #10 (permalink)
Curious George
Belette's Avatar
anything else I should know ?
Turbo D16y7/8
Setup in building:
Old 12-19-2005, 01:07 AM   #11 (permalink)
that is a good question that I kdon't know about, I haven't looked into that in over 2 years. I don't want to give you the wrong info on both the ecu's that you have alreaddy mentioned.
But in my opinion there are going to be a few different things different like the obd2b p2p will not have that extra pin for that sensor that looks for the other cam, ofcoarse a knock sensor also the fuel tables will differ, input to the fuel injectors are totally different. Heck, the fuel injectors on the d vs. b-series has different flow rates.
I am sorry I am not able to give you direct info on this subject at this time.
Old 12-19-2005, 01:53 AM   #12 (permalink)
Curious George
Belette's Avatar
yeah i see your point !! thank you ! I like that kind of comments...
but I'm sure that inectors are 240 cc on B like almost every D...
Turbo D16y7/8
Setup in building:
Old 12-19-2005, 02:37 AM   #13 (permalink)
Hey man an update for ya' if you crack open your helms book 1996-2000 on the fuel and emission chapter (11-88 to 11-96) it will show you the pins of the ecu's unfortunately, it will not individualize the ecu's that they have used. But it will let you see perfectly for which one is which. I am sure this will help to understand. If you don't have a helms there is an adobe acrobat format of the civic book in archives. I tried to find the flow rates for the injectors in the book. Looks like I am going to keep on searching.
iconAll times are GMT -8. The time now is 04:15 PM. | Welcome to Forum, please register to access all of our features.
