2 tunes on a 512? - D-series.org
Old 12-08-2005, 01:12 AM   #1 (permalink)
decev
Default 2 tunes on a 512?
Haven't really scene what I'm looking for. I know I can load two .bins, but how to select which one is presently running the car. Thought I'd ask here first.
Old 12-08-2005, 06:17 AM   #2 (permalink)
top right...the "2timer"
http://www.xenocron.com/products.php?page=components
ive been looking into this a little myself. kind of cool
[email protected]
Old 12-08-2005, 09:31 AM   #3 (permalink)
I plead the 5th
Old 12-08-2005, 01:39 PM   #4 (permalink)
Originally Posted by transzex
I plead the 5th
oh, come one now
tell us what you know
[email protected]
Old 12-08-2005, 04:34 PM   #5 (permalink)
makku's Avatar
Rep Power: 20 makku is a Top Aussie
makku is a Top Aussiemakku is a Top Aussiemakku is a Top Aussiemakku is a Top Aussiemakku is a Top Aussiemakku is a Top Aussiemakku is a Top Aussiemakku is a Top Aussiemakku is a Top Aussiemakku is a Top Aussiemakku is a Top Aussie
Send a message via AIM to makku Send a message via MSN to makku Send a message via Yahoo to makku
i'll give the secret. a 512 chip looks exactly the same as a 256 chip except for 1 pin. (Pin 1 if I remember right). This pin when at 0V will only let the ECU read "page 1" or the first 256K of memory. When you put the pin at 5V, the ecu will only read "page 2" or the second 256K of memory.
Now, in a stock ECU, that pin is always going to be at 0V (or 5V... i don't remember). So it will always be at one of the pages. But if you bend the pin out, so it doesn't sit in the socket, you can attach a switch that either connects it to ground (0V) or 5V. Then the switch will let you flip from page 1 to page 2... while the car is running. (your ROMS have to have all the same code except for maps and certain parameters... ex. you can't run a crome and an uberdata rom together, but you can run two different crome roms as long as they use the same base code.)
My car: 94 Civic DX sedan w/ JDM D15B VTEC
Trustworthy people: krAzySi, thesqad127, Turntune, Civic4ges, Sonny7730, mark7901, miked16z6, Low EG-T
forecast for tomorrow... a few sprinkles of genius with a chance for DOOM!
But I thought you said TV was bad?
It is... but we fucking need it.
makku is offline   Reply With Quote Quick reply to this message
Old 12-08-2005, 04:51 PM   #6 (permalink)
hell ya!! awesome info Lee!!
[email protected]
Old 12-08-2005, 05:46 PM   #7 (permalink)
So like I could have my high MPG tune on page one, then when AKSC is engaged via the AC switch the ECU flips to page 2 with a boost map AND engages the AKSC clutch at 65% throttle??????
Is it really that easy?????
Blundell thinks so
Old 12-08-2005, 07:01 PM   #8 (permalink)
decev
Awesome. That is more direct info than I'd found in almost two days. Lee is the man. Xenocron's got a prefab setup on the above link, but $30 is a little steep.
Old 12-08-2005, 07:36 PM   #9 (permalink)
Blundell thinks so
sounds like you have a plan brewing in your head
[email protected]
Old 12-12-2005, 10:15 PM   #10 (permalink)
makku's Avatar
$30 isn't too bad for a slick little board like that. But if you're clever, you can easily use a resistor, a couple of wires, and a switch from radioshack to accomplish the same thing. I did it for a couple of people before... not as pretty but it works
Old 12-13-2005, 12:30 AM   #11 (permalink)
4speedpride's Avatar
Rep Power: 14 4speedpride  is slowly gaining respect4speedpride  is slowly gaining respect4speedpride  is slowly gaining respect4speedpride  is slowly gaining respect4speedpride  is slowly gaining respect
Send a message via AIM to 4speedpride
that ac stwich trick doesnt seem like a bad idea.... light on means mad tyte jdm performance is on
Originally Posted by S Q A D
hondas love boost .... boost loves you
*1990 EX 4dr*
B18C1 w/ CTR pistons, B16 head, skunk2 valve springs, crower stage 3 cams and CBR1000 Throttle bodies
*1993 LX 4dr*
H23A1, QSD H2B kit, GSR trans, log mani, HX35, 27x7x2.5 FMIC, 2.25" ic piping
My ride thread:
:bravo:
4speedpride is offline   Reply With Quote Quick reply to this message
Old 12-13-2005, 10:09 AM   #12 (permalink)
esp. when it adds 12 pounds of boost
Old 12-13-2005, 01:34 PM   #13 (permalink)
so thats why you are an active member on HMT now...
[email protected]
Old 12-13-2005, 07:32 PM   #14 (permalink)
nope, just killing stupid thoughts over there............I do have a CX manifold sitting here, might go a low boost HMT someday
Old 12-15-2005, 06:39 PM   #15 (permalink)
Rep Power: 15 Jim Truett is learning the way of the DJim Truett is learning the way of the D
http://www.iroczone.com/projepromsw01.htm
Jim Truett is offline   Reply With Quote Quick reply to this message
iconAll times are GMT -8. The time now is 03:00 PM. | Welcome to Forum, please register to access all of our features.
