91 vs 95 trans. wiring - D-series.org
Old 09-03-2018, 09:23 AM   #1 (permalink)
Rep Power: 0 phlips904 is nobody
Default 91 vs 95 trans. wiring
Seen good things here and was recommended to visit with my ??. 48 yo newbe so here is my ?. 91 ef blown D15B2 motor good auto trans. 95 good D15B7 bad auto trans. I know I can just reuse dual point but want multi from 95 so ? is can I use harness from 95 with trans from 91?I have a 100% complete 95 donor ecu and all. Like I said, I'm 48 and not really looking for performance so to speak witch is why I thought of just engine swap and using old dual point my dist. extend wire for temp. sensor, ect. ect. If it sounds like I know what I'm talking about already, nope just what I read on internet so far but no answer to my specific ?.
phlips904 is offline   Reply With Quote Quick reply to this message
Old 09-03-2018, 11:33 AM   #2 (permalink)
Motor-wise, d15b2=d15b7
Re-use d15b2 manifolds, sensors, etc...
The shortblock and head are identical
No idea about the transmissions. I am pretty sure the OBD1 (92-95) transmissions use more electronics to operate.
Old 09-03-2018, 03:49 PM   #3 (permalink)
Will use dual point for now but also have access to free complete 2000 civic with blown motor good trans. OBD2. Frankenstein B7 long block, multi point, dist. ect. with 2000 trans. in 91 EF?
Old 09-04-2018, 12:46 PM   #4 (permalink)
Evil1_4real's Avatar
Rep Power: 0 Evil1_4real is nobody
You can use a 2000 civic transmission, but you will have to use the axles and hubs from the 2000 to make it all work. I would also stay with obd1 for easy tuning.
Evil1_4real is offline   Reply With Quote Quick reply to this message
Old 09-04-2018, 03:59 PM   #5 (permalink)
Unless he is an HF or STD chassis, I dont see a reason for him to swap hubs and axles.
WIRING is the biggest hurdle here.
Important things to note are the solenoids, how it "kicks down" whether via electronics or via a cable, and how the shifter cables hook up.
At this point, it would be easier to try tracking down an EX auto setup, and use the transmission, ecu, wiring, and multiport (4cyl) injection stuff.
From there, an OBD1 conversion MIGHT be possible, but again, transmission electronics will be the hurdle.
I would start looking up wiring diagrams, and verify any differences, and go from there.
Old 09-04-2018, 05:50 PM   #6 (permalink)
D15B7 with B2 intake swap, extend fan wiring and done, keep the current trans and be done.
Aka long block swap. KISS
transzex is online now   Reply With Quote Quick reply to this message
Old 09-30-2018, 04:47 PM   #7 (permalink)
D15B7 long block with B2 acc. project finished and runs fantastic. Even gave me a chance to fix A/C that now comes out of vents at 39 degrees. FK yea!!!! Thanx guys for all your wisdom.
iconAll times are GMT -8. The time now is 02:38 PM. | Welcome to Forum, please register to access all of our features.
