93 civic dx no fuel no spark - D-series.org
Old 12-25-2017, 03:37 AM   #1 (permalink)
mitchwbr's Avatar
Rep Power: 7 mitchwbr is obviously a regularmitchwbr is obviously a regularmitchwbr is obviously a regularmitchwbr is obviously a regularmitchwbr is obviously a regularmitchwbr is obviously a regularmitchwbr is obviously a regularmitchwbr is obviously a regular
Default 93 civic dx no fuel no spark
Injectors are out of the rail and plugged into the harness but not spraying. Fuel pump does prime. Had this car running fine a few weeks ago, but fro what I think happened, the positive battery terminal arced on the body from not having any cover on it. Anyways checked the 80 amp battery fuse and the kid had a 40 amp in there instead and it was blown... Replaced that nothing, also fuse #24 under dash that controls fueling and spark or either or, can't remember was blown. replaced and still nothing. Put in a new engine harness, different coil, and igniter, different ECU, main relay is good for sure, used my friends that runs his car fine, any other ideas? I'll throw parts at it if I have too I just do the know what else to try..... Thanks guys as always
Stock D15b7, z6 head, Precision 5431, 450 inj.
Vtak turned off. 220 hp 175 tq.
mitchwbr is offline   Reply With Quote Quick reply to this message
Old 12-25-2017, 08:09 AM   #2 (permalink)
2jzdreamin's Avatar
iTrader Score: 49 reviews
Are you getting 12 volts to the yellow/black wires at the injector plugs?
Could be another blown fuse.
all so do vtec sub-harness
instagram @magicman9won4
Old 12-25-2017, 10:50 AM   #3 (permalink)
mitchwbr's Avatar
Yes, the injectors have power with the key on. checked with a test light back probing the wire
Old 12-25-2017, 10:51 AM   #4 (permalink)
mitchwbr's Avatar
Distributor has power to it as well just no spark
Old 12-25-2017, 01:49 PM   #5 (permalink)
2jzdreamin's Avatar
When you replaced the coil and igniter where they know good ones?
There could be a brake in the wire(s) from ecu to shock tower plugs. Or could be a bad cam/crank sensor.
Old 12-26-2017, 02:54 AM   #6 (permalink)
mitchwbr's Avatar
Coil and igniter were from the junkyard...... But they were probably good right? If the dizzy has power (at the square plug I think it's the fatter blue wire of the two wires) then does that mean the ECU is sending a signal to fire the car? Your right didn't think about the cam sensor, maybe I'll just try another dizzy all together. Ok cool any other ideas?
Old 12-26-2017, 03:25 AM   #7 (permalink)
2jzdreamin's Avatar
The 12 volt power wire for the distributor is in the 2 wire plug and is black/yellow wire.
iconAll times are GMT -8. The time now is 04:47 PM. | Welcome to Forum, please register to access all of our features.
