91 HF CRX ZC swap ecu pinout question - D-series.org
Old 02-17-2016, 02:07 PM   #1 (permalink)
Rep Power: 0 Unisonicz is nobody
Default 91 HF CRX ZC swap ecu pinout question
The car in question is a 91 CRX HF with a ZC swap. I have the correct dizzy(td43u) and a chipped obd1 ECU. I have the obd0 - obd1 jumper harness. Since I have the harness can I go by the obd0 pinout from this thread even though it says vtec?
http://honda-tech.com/honda-crx-ef-c...n-out-2911958/
There are 5 shielded wires. 2 wires to the crank angle sensor, 2 wires to the cylinder position sensor and 1 wire to the 02 sensor. The previous owner of the car butchered the wiring. I am wondering if it is required to have the shielding go to the ground wire pictured or even grounded at all??
Another question, the car has Glow Shift AFR gauge and 4 wire O2 sensor, do I need a 1 wire 02 sensor?
Any help is appreciated!
Best regards
Unisonicz is offline   Reply With Quote Quick reply to this message
iconAll times are GMT -8. The time now is 04:50 PM. | Welcome to Forum, please register to access all of our features.
