p28 ecu...Q3 transistor ....d16z6 - D-series.org
Old 12-12-2015, 05:07 AM   #1 (permalink)
Rep Power: 0 d series singapore is nobody
Arrow p28 ecu...Q3 transistor ....d16z6
recently I had some starting issues in the morning ,my fuel pump took a long time before it could prime, changed my main relay ,still same thing.
Traced it all the way to the ecu ,many capacitors were leaking and transistor
Q3 (2SD1779) was fried .I changed all the caps but couldn't find Q3 in sg .
decided to start the car without it ,car started right up ,COULD NOT rev ,CEL ON !,I have a SAFC2 which showed me there was no throttle voltage even if I floored it .so when to a tech guy to find replacement for Q3(2SD1779)
here are the replacement transistor for Q3
2sc3070
2sd1164
2sd1583
2sd1582
2sd1581
the transistor I used was 2sc3070 ,problem solved for fuel pump and TPS .
I hope this info was useful to u guys .
d series singapore is offline   Reply With Quote Quick reply to this message
Old 12-12-2015, 07:14 AM   #2 (permalink)
Sac*HXy5's Avatar
Rep Power: 7 Sac*HXy5 is about to blow upSac*HXy5 is about to blow upSac*HXy5 is about to blow upSac*HXy5 is about to blow upSac*HXy5 is about to blow upSac*HXy5 is about to blow upSac*HXy5 is about to blow upSac*HXy5 is about to blow upSac*HXy5 is about to blow upSac*HXy5 is about to blow upSac*HXy5 is about to blow upSac*HXy5 is about to blow upSac*HXy5 is about to blow upSac*HXy5 is about to blow upSac*HXy5 is about to blow up
Nice find, good share.
Sac*HXy5 is offline   Reply With Quote Quick reply to this message
Old 12-12-2015, 10:03 AM   #3 (permalink)
HiProfile's Avatar
Almost any NPN transistor w/5v signal could work, it's basically used as a low-draw relay/switch. The 2sc3070 looks ideal, if you can find someone selling it. It may be easier to find a larger form factor and shoehorn it in there, since those smaller transistors are usually for lower outputs (like the last p/n).
Old 12-15-2015, 12:23 PM   #4 (permalink)
Thanks hiprofile for your advice
Old 12-15-2015, 03:01 PM   #5 (permalink)
atheworld0's Avatar
Rep Power: 9 atheworld0 is fly like an eagleatheworld0 is fly like an eagleatheworld0 is fly like an eagleatheworld0 is fly like an eagleatheworld0 is fly like an eagleatheworld0 is fly like an eagleatheworld0 is fly like an eagleatheworld0 is fly like an eagleatheworld0 is fly like an eagleatheworld0 is fly like an eagleatheworld0 is fly like an eagle
How can you tell if the q3 is blown? I know what a bad capacitor looks like. I have an ecu that had the same problem, only caused no starts at time. I removed the ecu and replaced with a new one and have no issue. I was going to replace c14 and hope that fixes it though it looks good.
atheworld0 is offline   Reply With Quote Quick reply to this message
Old 12-18-2015, 08:55 AM   #6 (permalink)
It's best if u replace all the caps at one go , if Q3 is blown you won't be able to accelerate and the check engine light will come on ,visual inspection of damage Q3 will show that the legs of the transistor will either be burnt or missing ,check below the PCB as well for burnt circuit tracks
Old 12-18-2015, 11:27 AM   #7 (permalink)
atheworld0's Avatar
Well that wasn't the issue. Just random no start.
Tags
fuel pump, p28 ecu help, q3 transistor p28 ecu, tps throttle sensor
iconAll times are GMT -8. The time now is 01:07 PM. | Welcome to Forum, please register to access all of our features.
