p28 diode cracked - D-series.org
Old 11-05-2015, 10:27 AM   #1 (permalink)
Rep Power: 0 eddie7978 is  EVIL !!!!!!!!
Default p28 diode cracked
ok so i bought a p28 but this diode is cracked
eddie7978 is offline   Reply With Quote Quick reply to this message
Old 11-05-2015, 10:43 AM   #2 (permalink)
Full_Tilt's Avatar
Rep Power: 29 Full_Tilt is on a level you can only DREAM about! ! !Full_Tilt is on a level you can only DREAM about! ! !Full_Tilt is on a level you can only DREAM about! ! !
Full_Tilt is on a level you can only DREAM about! ! !Full_Tilt is on a level you can only DREAM about! ! !Full_Tilt is on a level you can only DREAM about! ! !Full_Tilt is on a level you can only DREAM about! ! !Full_Tilt is on a level you can only DREAM about! ! !Full_Tilt is on a level you can only DREAM about! ! !Full_Tilt is on a level you can only DREAM about! ! !Full_Tilt is on a level you can only DREAM about! ! !Full_Tilt is on a level you can only DREAM about! ! !Full_Tilt is on a level you can only DREAM about! ! !Full_Tilt is on a level you can only DREAM about! ! !Full_Tilt is on a level you can only DREAM about! ! !Full_Tilt is on a level you can only DREAM about! ! !Full_Tilt is on a level you can only DREAM about! ! !
Thats usually an unused input IIRC.
Old 11-05-2015, 10:57 AM   #3 (permalink)
92CXyD's Avatar
Rep Power: 15 92CXyD is hot as a volcano92CXyD is hot as a volcano
Isn't that the caused by purge valve plug getting mixed up with IAT?
If you want to know about my avatar
ENMO.
An Emo car would cut its own tires and never get out of the garage.
92CXyD is offline   Reply With Quote Quick reply to this message
Old 11-05-2015, 10:59 AM   #4 (permalink)
Formally D_Tuned
Tw34k's Avatar
Rep Power: 19 Tw34k is the fucking MAN!!!!Tw34k is the fucking MAN!!!!Tw34k is the fucking MAN!!!!
Tw34k is the fucking MAN!!!!Tw34k is the fucking MAN!!!!Tw34k is the fucking MAN!!!!Tw34k is the fucking MAN!!!!Tw34k is the fucking MAN!!!!Tw34k is the fucking MAN!!!!Tw34k is the fucking MAN!!!!Tw34k is the fucking MAN!!!!Tw34k is the fucking MAN!!!!
EVAP purge solenoid drive Transistor. You probably don't need it, if you do I can help you find one.
All I ever wanted was to pop vtec...
Tw34k is offline   Reply With Quote Quick reply to this message
Old 11-05-2015, 01:34 PM   #5 (permalink)
i think it has to do with the o2 sensor because the previous one i had the diode was burnt and was throwing cel for the o2
Old 11-05-2015, 02:01 PM   #6 (permalink)
see this was the burnt one that was throwing cel 41 for the o2
Old 11-05-2015, 02:55 PM   #7 (permalink)
Formally D_Tuned
Tw34k's Avatar
That's Q31 and it has nothing to do with your O2 sensor. It simply allows the ecu to supply enough current to open the EVAP purge solenoid. I have seen many of these go from improperly connecting plugs on the engine harness to the wrong place, most often it has to do with the IACV since it is a 12V device while most other plugs near it are resistance based ground loop sensors.
The ECU should function fine without it unless the heat from it dying caused damage to other tracks on the board or for some reason you need EVAP. It can be replaced fairly cheaply if need be.
Old 11-05-2015, 03:16 PM   #8 (permalink)
Find the part number and search online for it.
should be very cheap.
a soldering ribbon will help remove that with minimal risk. you heat from the bottom side, and as the solder melts the ribbon absorbs it.
Works great when I was really into old xbox and ps2/3 repairs
Old 11-05-2015, 03:26 PM   #9 (permalink)
Formally D_Tuned
Tw34k's Avatar
Learn here
2SD21780SA TRANS NPN 50VCEO 2A MT-3 Panasonic - SSG datasheet pdf data sheet FREE from datasheetz.com
Buy here
Q31 or Q34 - SD21780SA Transistor [Q31] - $2.00 : Moates.Net
Or track it down from many other places.
Old 11-05-2015, 04:17 PM   #10 (permalink)
oh ok i thought thats why that ecu was throwing a cel 41 for an o2
i bought a different p28 and no codes so i guess theres somthing else wrong with the p28 besides that diode
iconAll times are GMT -8. The time now is 02:40 PM. | Welcome to Forum, please register to access all of our features.
