P70 Help - D-series.org
Go Back   D-series.org Ľ Motor Mayhem & Suspension Satisfaction Ľ Engine Management
Old 07-07-2009, 09:54 PM   #1 (permalink)
Rep Power: 0 i<3myhonda's is nobody
Exclamation P70 Help
i got my hands on a p70 ecu. iv read up on it and its a jdm domina sohc zc v-tec ecu. and i tired to run it on my d16z6 but i get a cel code 21. iv found that jumping a4 to d6 will solve the issue but it didnt. i know the p70 doesnt have a oil pressure sensor, so could that be the issue? its chipped and i thought it would be a good ecu to use. am i wrong? does it work well with a d16z6? any info would be great
i<3myhonda's is offline   Reply With Quote Quick reply to this message
Old 07-08-2009, 10:21 AM   #2 (permalink)
bump
Old 07-08-2009, 10:25 AM   #3 (permalink)
wheres my money man!!
sleepingciv's Avatar
Rep Power: 42 sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !
sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !
iTrader Score: 143 reviews
Send a message via AIM to sleepingciv Send a message via MSN to sleepingciv Send a message via Yahoo to sleepingciv
you already received your answer didnt you??
p70 HELP!!! - Honda Forum / Acura Forum - SuperHonda.com
PM me for
also do tucked harnesses
sleepingciv is offline   Reply With Quote Quick reply to this message
Old 07-08-2009, 02:09 PM   #4 (permalink)
Its always good to get answers from more then one person
Old 07-08-2009, 04:58 PM   #5 (permalink)
fuse's Avatar
Rep Power: 11 fuse is obviously a regularfuse is obviously a regularfuse is obviously a regularfuse is obviously a regularfuse is obviously a regularfuse is obviously a regularfuse is obviously a regularfuse is obviously a regular
If it is chipped try turning off the vtec psi switch on crome. I hear it is a bit buggy though sometimes not switching to the vtec map.
I cant remember 21 and 22 are a bit different. One is more a oil psi/psi switch problem and one is more a solenoid problem. If the ecu stock didnít come with a pressure switch I donít think it will throw a code for one but due to the chip and crome it may be looking for one.
I donít know never laid my hands on a p70 before.
I assume you are on crome?
Neptune dealer, Crome dealer, turbo edit, bre, nistune, street tunes, dyno tunes, ecu chipping obdo and obd1, ecu repairs, no basemaps, homemade conversion harnesses, homemade led gauge clusters, in co springs. Chips In stock ecus in stock with trade in discounts. Email
or pm
fuse is offline   Reply With Quote Quick reply to this message
Old 08-10-2009, 09:01 AM   #6 (permalink)
sry for the long reply...i bought it chipped...it throws a cel light but nothing seems wrong.. thx for all the response's
iconAll times are GMT -8. The time now is 03:35 PM. | Welcome to Forum, please register to access all of our features.
