2 questions: Map and ECU - D-series.org
Old 06-28-2009, 08:06 PM   #1 (permalink)
Rep Power: 12 civicek36 will become famous soon enoughcivicek36 will become famous soon enoughcivicek36 will become famous soon enough
Question 2 questions: Map and ECU
1: What voltage should a 4bar map sensor output be reading???
2: Does anyone know the ECU board diagram??? I'm getting a CEL for o2 on my chipped ECU, so I wanna check the board to see if my o2 stuff is alright in there.
civicek36 is offline   Reply With Quote Quick reply to this message
Old 06-29-2009, 06:15 PM   #2 (permalink)
Bump?!?!?!?
Old 06-29-2009, 06:46 PM   #3 (permalink)
Speedjunky01's Avatar
Rep Power: 18 Speedjunky01 is a Top Aussie
Speedjunky01 is a Top AussieSpeedjunky01 is a Top AussieSpeedjunky01 is a Top AussieSpeedjunky01 is a Top AussieSpeedjunky01 is a Top AussieSpeedjunky01 is a Top AussieSpeedjunky01 is a Top AussieSpeedjunky01 is a Top AussieSpeedjunky01 is a Top AussieSpeedjunky01 is a Top AussieSpeedjunky01 is a Top Aussie
iTrader Score: 40 reviews
outputs the same voltage i believe, its just that instead of 5v meaning 11psi 5v means 2.5 , 3, or 4 bad and the software you are using just scales it differently so that it reads correctly
as for the ecu board, if the car is running its most likely done right. disable the primary o2 sensor and the cel should go away
resident verbal assault tech Jr.
240,000 miles and counting turbo EH9
nothing like 4drs, ac,moon roof, and 4 whores and running 13psi out or a ching chong t3/t4 setup
the build
if it survives the winter JdM d15b+Vitara+FJT+25psi=
professional tranny assassin, 2 stock diffs in 4 weeks on street tires and preload was used
Speedjunky01 is offline   Reply With Quote Quick reply to this message
Old 06-30-2009, 01:40 AM   #4 (permalink)
The thing is that I checked my stock honda map for output voltage and I think I got .67 if i remember right, and when I plugged my 4 bar in I got 2.92 volts for output. So I wanna be sure I got a 4 bar with me so I dont mess up on tuning.
Old 06-30-2009, 08:40 AM   #5 (permalink)
Falcon7's Avatar
Rep Power: 15 Falcon7 is trying to make new friends
If you could explain exactly what you're trying to accomplish that would be a big help.
Or other things like: What engine management are you running? What Brand/Type of 4bar are you running?
Information like this is pretty helpful for people who can't physically be there to diagnose the problem for you.
Falcon7 is offline   Reply With Quote Quick reply to this message
Old 06-30-2009, 09:29 AM   #6 (permalink)
output at what? idle? wot? WTF are you talking about?
we really need more info if you want some help. im more then glad to help peope but if your looking gor spoon feeding with no work on your end
GTFO of d-series
the build
Old 07-01-2009, 08:10 PM   #7 (permalink)
Ok Im gonna be running a xenocron diy 4 bar. I was told that it is possible to check how many bar your map sensor is by putting your key to ignition and checking the output voltage, as there are Voltage, Ground, Output.
Right now Im using stock map with just 6 psi. Im tuned with Ectune.
Old 07-01-2009, 10:27 PM   #8 (permalink)
Falcon7's Avatar
Dude, if you're using a Xenocron 4bar then why do the voltage specs matter? He has writeups on his site that have the part numbers listed for 2.5, 3, and 4 bar. So once you get the sensor from xenocron just check the part number on the sensor against the ones he has listed already. No voltage testing necessary.
Tags
map sensor, o2 sensor, voltage output
iconAll times are GMT -8. The time now is 05:43 PM. | Welcome to Forum, please register to access all of our features.
