Does a D16 piston in D14 engin works? - D-series.org
Old 05-31-2009, 06:17 PM   #1 (permalink)
Rep Power: 11 Techtrancer is trying to make new friends
Default Does a D16 piston in D14 engin works?
does annybody knows if a D16 dome piston works in an D14 engin?
nice greetings
Techtrancer is offline   Reply With Quote Quick reply to this message
Old 05-31-2009, 07:18 PM   #2 (permalink)
ekjdmd16a's Avatar
Rep Power: 11 ekjdmd16a is learning the way of the Dekjdmd16a is learning the way of the D
Send a message via AIM to ekjdmd16a
same bore but im not sure if it will work
ekjdmd16a is offline   Reply With Quote Quick reply to this message
Old 06-01-2009, 07:13 AM   #3 (permalink)
The_Acid_Beaver's Avatar
No, the compression heights are very different. You need some PM0 or PM2 pistons, if my memory serves me correctly.
RTFM. No, really. Do it.
Old 06-01-2009, 07:19 AM   #4 (permalink)
i want to use the D16 pistons with an D14z2 engin and a D16Z6 cylinderhead, because there are no D14 dome pistons to bye to drive with 11:1 ore so
iconAll times are GMT -8. The time now is 11:05 AM. | Welcome to Forum, please register to access all of our features.
