2 O2's to 1 O2 - D-series.org
Old 05-15-2009, 04:32 PM   #1 (permalink)
boost ben's Avatar
Rep Power: 13 boost ben It's a JDM Star Bitches....
boost ben It's a JDM Star Bitches....boost ben It's a JDM Star Bitches....
Default 2 O2's to 1 O2
Hey guys,
Last week I replaced my D16Y7 exhaust manifold and cat combo to an Airmass header. Wile doing the swap I removed my primary O2 sensor (top one), lengthened it and placed it onto my header. I have a check engine light on now witch is expected (I scanned it but forgot the exact code) from losing the second O2 sensor. My question is should my car be running really shitty? It feels as if tho I have no power and the car idles really rough some times. The exhaust is an Airmass header straight into a stainless steel 2 1/4 mandrel bent pipe all the way back to a vibrant street power flat black muffler, no cat no resonators.
boost ben is offline   Reply With Quote Quick reply to this message
Old 05-15-2009, 04:35 PM   #2 (permalink)
boostfreak0885's Avatar
Rep Power: 20 boostfreak0885 is hot as a volcanoboostfreak0885 is hot as a volcano
boostfreak0885 is hot as a volcanoboostfreak0885 is hot as a volcanoboostfreak0885 is hot as a volcanoboostfreak0885 is hot as a volcanoboostfreak0885 is hot as a volcanoboostfreak0885 is hot as a volcanoboostfreak0885 is hot as a volcanoboostfreak0885 is hot as a volcanoboostfreak0885 is hot as a volcanoboostfreak0885 is hot as a volcanoboostfreak0885 is hot as a volcanoboostfreak0885 is hot as a volcano
Send a message via AIM to boostfreak0885
primary reads the output of the engine... secondary reads after the cat just to make sure your cat is doing its job.. soo in other words, you shouldnt be running any richer then what you were running before.. it prolly just smells really bad because you dont have a cat anymore.. im sure your throwing a code for the secondary o2 and a cat because its not getting any reading
my new and improved build... check it out
best time so far
11.201 at 128mph with a 1.79 60 foot.. damn i need traction, best trap speed is 129mph. 26psi h1c
NEW best 60' 1.56!!!
boostfreak0885 is offline   Reply With Quote Quick reply to this message
Old 05-15-2009, 04:38 PM   #3 (permalink)
wheres my money man!!
sleepingciv's Avatar
Rep Power: 42 sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !
sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !
iTrader Score: 143 reviews
Send a message via AIM to sleepingciv Send a message via MSN to sleepingciv Send a message via Yahoo to sleepingciv
??Hmm i wouldnt think removing your second o2 would cause this.??
Did ya over look to make sure you havent jarred something loose while installing the header?
PM me for
also do tucked harnesses
sleepingciv is offline   Reply With Quote Quick reply to this message
Old 05-15-2009, 04:40 PM   #4 (permalink)
yeah, the secondary o2 wont cause it to run rich... it probably has something to do with your wiring for the primary
best time so far
Old 05-15-2009, 04:44 PM   #5 (permalink)
boost ben's Avatar
It does smell from no cat but I'm used to that smell. The car runs noticeably different tho. If I were to have a bad primary o2 sensor what would the symptoms be like?
Old 05-15-2009, 04:46 PM   #6 (permalink)
sluggish, really smelly, bad bad gas mileage, bad idle... all those kinds of things... but it worked before the install right..??? so imo its something with your wiring when you lengthened the wires
best time so far
Old 05-15-2009, 04:46 PM   #7 (permalink)
dito
PM me for
Old 05-15-2009, 04:49 PM   #8 (permalink)
boost ben's Avatar
This is what I'm thinking to now. The car ran great before. I may just bight the bullet and buy a brand new o2 sensor. It will be on the dyno soon after the new engine is installed and converted to OBD-1. The check engine light should the go off after all of this.
Old 05-15-2009, 04:50 PM   #9 (permalink)
cmgreen50's Avatar
Rep Power: 22 cmgreen50 is the fucking MAN!!!!cmgreen50 is the fucking MAN!!!!cmgreen50 is the fucking MAN!!!!cmgreen50 is the fucking MAN!!!!
cmgreen50 is the fucking MAN!!!!cmgreen50 is the fucking MAN!!!!cmgreen50 is the fucking MAN!!!!cmgreen50 is the fucking MAN!!!!cmgreen50 is the fucking MAN!!!!cmgreen50 is the fucking MAN!!!!
^werd bust out the ohmeter
edit its more likely you dont have a good connection with one of the wires than it is your primary o2 took a crap.
i seriously have a donkey if you're serious..
The problem is, my need for speed exceeds the need to save the earth.
WELL FINE! I'LL JUST GO EAT THE SHIT OUTTA MY OREO'S THEN!
cmgreen50 is offline   Reply With Quote Quick reply to this message
Old 05-15-2009, 04:51 PM   #10 (permalink)
yeah the light will go out after you change to obd1 and chipped and tuned... no need for a narrow band o2 sensor anymore once its tuned. just a wideband
best time so far
Old 05-15-2009, 06:53 PM   #11 (permalink)
EKboostedY8's Avatar
Rep Power: 16 EKboostedY8 is hot as a volcano
EKboostedY8 is hot as a volcanoEKboostedY8 is hot as a volcanoEKboostedY8 is hot as a volcanoEKboostedY8 is hot as a volcanoEKboostedY8 is hot as a volcanoEKboostedY8 is hot as a volcanoEKboostedY8 is hot as a volcanoEKboostedY8 is hot as a volcanoEKboostedY8 is hot as a volcanoEKboostedY8 is hot as a volcanoEKboostedY8 is hot as a volcanoEKboostedY8 is hot as a volcanoEKboostedY8 is hot as a volcano
iTrader Score: 20 reviews
You always wana be careful with the o2 sensors also. Ive noticed a trend with some people at work and I know its not bad luck. Ive seen occasions where exhaust work was done on a car, o2 R+R with the same one and the car will throw a primary heater circuit fault code. Seems some senors are rather delicate.
EKboostedY8 is offline   Reply With Quote Quick reply to this message
Old 05-16-2009, 01:50 PM   #12 (permalink)
boost ben's Avatar
This could be it as well. I couldn't for the life of me get it out of my stock cat so I used an o2 socket and my IR impact gun. Sorry I haven't been able to update with my fixes, its been poring for the past 2 days.
Old 05-16-2009, 06:25 PM   #13 (permalink)
sql_civic's Avatar
Rep Power: 17 sql_civic is about to blow upsql_civic is about to blow upsql_civic is about to blow upsql_civic is about to blow upsql_civic is about to blow upsql_civic is about to blow upsql_civic is about to blow upsql_civic is about to blow upsql_civic is about to blow upsql_civic is about to blow upsql_civic is about to blow upsql_civic is about to blow upsql_civic is about to blow upsql_civic is about to blow upsql_civic is about to blow up
iTrader Score: 31 reviews
Any CELs?
sql_civic is offline   Reply With Quote Quick reply to this message
Old 05-17-2009, 01:26 PM   #14 (permalink)
boost ben's Avatar
So I worked on it today. I broke out the multimeter and found that the resistance of the O2 was infinity so I cut it back to before the soldering and it still rad infinity so I cut it back all the way to just above the sensor and it still read infinity. I took a trip to the local auto parts store and bought a bosch replacement and it works awesome now.
iconAll times are GMT -8. The time now is 12:47 AM. | Welcome to Forum, please register to access all of our features.
