06 Code HELP! OBD0 - D-series.org
Old 05-10-2009, 09:31 AM   #1 (permalink)
Rep Power: 0 I Ride Dumped is nobody
Default 06 Code HELP! OBD0
Ok so my uncle and I changed my clutch yesterday. We just dropped the motor a bit to get to the clutch. After we where done I started it up and now it is idling uber high. Also I noticed there is a sensor (I think) Right under my distributor that seems to have been disconnected and I cant figure out what it is. Is this all related? Will replacing the sensor fix the problem?
P.S.
My gas mileage went down ALOT. I can actually see the needle moving.
I Ride Dumped is offline   Reply With Quote Quick reply to this message
Old 05-10-2009, 09:32 AM   #2 (permalink)
wheres my money man!!
sleepingciv's Avatar
Rep Power: 42 sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !
sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !
iTrader Score: 143 reviews
Send a message via AIM to sleepingciv Send a message via MSN to sleepingciv Send a message via Yahoo to sleepingciv
any codes?
PM me for
also do tucked harnesses
sleepingciv is offline   Reply With Quote Quick reply to this message
Old 05-10-2009, 09:38 AM   #3 (permalink)
Yes. I checked the ECU. It blinks 6 times. But I am curious as to what that sensor is under my distributor
Old 05-10-2009, 11:16 AM   #4 (permalink)
Rep Power: 0 z6rex smells like Boratz6rex smells like Boratz6rex smells like Boratz6rex smells like Boratz6rex smells like Boratz6rex smells like Borat
Coolant temp sensor. That will make it idle high. I assume it's the 2 wire right?
z6rex is offline   Reply With Quote Quick reply to this message
iconAll times are GMT -8. The time now is 12:42 AM. | Welcome to Forum, please register to access all of our features.
