need help identifying A6, ZC, B7 cams - D-series.org
Old 04-02-2017, 07:40 AM   #1 (permalink)
Louie's Avatar
Rep Power: 12 Louie will become famous soon enoughLouie will become famous soon enoughLouie will become famous soon enough
Default need help identifying A6, ZC, B7 cams
Sup gentlemen, need some help identifying a few cams i have laying around. Had them separate but after a move they got mixed up. The stickys i read do not have any detailed pictures showing specific differences so i am hoping a shaped eyed gent will shed some light. One is an A6, sohc ZC and stock B7. Thank you in advance.
Here is what i have:
Louie is offline   Reply With Quote Quick reply to this message
Old 04-02-2017, 08:54 AM   #2 (permalink)
the d15b7 cam will have the shortest profile, and the biggest angle seperation, as it is made for lower rpm torque.
my total and utter guess based on the picture with hammer on top and 3 laid out top to bottom, the b7 is the far right cam.
Old 04-02-2017, 04:50 PM   #3 (permalink)
Louie's Avatar
Thank you for the reply Matt.
My hope is that someone will have a cam laying around that they can visually compare with mine and accurately confirm which is which for the benefit of all. Looking closely, they are different from one another in that some cam journals have grooves machined into them. Also, in picture 3, the left most cam has a groove on the journal closest to the distributor lug and also the thrust locator.
I can take better pics if necessary.
Old 04-02-2017, 07:28 PM   #4 (permalink)
take close up pics of any casting nmumbers. I believe I have a d15b2 or d15b7 camshaft in a head laying around (same camshaft)
I also have a d16a6 head for sure, I can check.
Will be late tomorrow, if I remember
Old 04-02-2017, 10:10 PM   #5 (permalink)
There is a sticky with the cam measurements, try there first.
I know, I did the measuring.
iconAll times are GMT -8. The time now is 11:33 PM. | Welcome to Forum, please register to access all of our features.
