d16z6 Head inspection - D-series.org
Old 01-13-2017, 09:39 AM   #1 (permalink)
anomolix's Avatar
Rep Power: 8 anomolix is almost a somebodyanomolix is almost a somebodyanomolix is almost a somebodyanomolix is almost a somebody
Default d16z6 Head inspection
Got to cleaning out some of the rust and noticed that I can't turn the camshaft. Tried to use the cam gear from a b7 head to turn it and nothing. Backed out all the valve adjusters to clean the threads and give me more clearance, then torqued it to 27 ft lbs and tried again and still can't turn the camshaft. The force over comes the torque and loosens it every time. Pics of some cam wear, is this normal? Video of me jiggling stuff around. The rockers on intake 4 and exhaust 1 have no movement, even with the screws backed all the way out.
anomolix is offline   Reply With Quote Quick reply to this message
Old 01-13-2017, 09:42 AM   #2 (permalink)
BLK92_D16's Avatar
Rep Power: 30 BLK92_D16 Still a JDM Star....
iTrader Score: 78 reviews
Are you rotating the assembly via the cam gear bolt counter-clockwise or clockwise?
Old 01-13-2017, 09:54 AM   #3 (permalink)
anomolix's Avatar
Counter clockwise sir, toward me.
Old 01-18-2017, 10:25 AM   #4 (permalink)
anomolix's Avatar
So, I took everything apart, cleaned it again, and reassembled it and put it on my block to try and turn the head with the crank pulley torqued down and still nothing. Loosened the valve train up a little bit to look at the range of motion because it does turn while loosened and some of the exhaust valves are longer than others by a good few millimeters. Took my straight edge to the bottom surface and it's not warped. I'm out of ideas. Any suggestions? Could really use a little assistance.
iconAll times are GMT -8. The time now is 04:59 PM. | Welcome to Forum, please register to access all of our features.
