Need help! Won't start.. d16y7 head, d15b block - D-series.org
Old 05-10-2009, 01:20 PM   #1 (permalink)
Mugen112's Avatar
Rep Power: 0 Mugen112 is nobody
Default Need help! Won't start.. d16y7 head, d15b block
I made another thread about this, but I'm going to lay everything out here and hopefully someone can help me. I've been trying to get this right for the last 48hrs straight with no luck. PLEASE HELP!
I have been looking around on here and have gotten mixed answers from all over. If you have any experience with this, PLEASE help!
So I have a d15b block with a blown head, so I proceeded to swap the head out for an OBDII d16y7 head I had laying around. I swapped out the dizzy and walla! 190 compression in all calenders! This got me pretty happy, but then she wouldnt crank over.
What I've tried so far:
- I've used a straw to get #1 cyl to TDC and put the UP mark on the cam gear up. Made sure nothing was being hit and tried to start it. Nothing but a bunch of back fires and hickups.
- From there I proceeded to move the timing belt 1 tooth over at the cam in either direction to either retard or advance it in either direction. I did this over a 3 tooth span in either direction with no luck what so ever.
- I re-did everything again trying to get the #1 cyl to TDC and putting the cam gear in the UP position. Still no luck.
There were a few times where I go the engine to just keep cranking with no back fires or hickups, but deffinetly didn't want to start.
- I then tried swapping out the d16y7 cam gear with the d15b cam gear and it looked to be about 1/2 a tooth difference. I did everything all over again numerous times with the exact same results.
Does anyone have any suggestions on what I should do? I'm deffinetly getting fuel (smells ALOT), getting spark, and also have great compression (checked it twice)... PLEASE HELP!
d16y7... in the process of rebuilding for 400whp.
Mugen112 is offline   Reply With Quote Quick reply to this message
Old 05-10-2009, 04:28 PM   #2 (permalink)
RandysSOHC's Avatar
Rep Power: 14 RandysSOHC is a name known to allRandysSOHC is a name known to allRandysSOHC is a name known to allRandysSOHC is a name known to allRandysSOHC is a name known to allRandysSOHC is a name known to allRandysSOHC is a name known to allRandysSOHC is a name known to all
iTrader Score: 26 reviews
hmmm... as long as it didn't jump time far..
but you say you put it back to tdc so...
do you have a fuel pressure gauge?
& the car is cranking over?
RandysSOHC is offline   Reply With Quote Quick reply to this message
Old 05-10-2009, 08:33 PM   #3 (permalink)
Mugen112's Avatar
Well I finally go it to start! I started to look over every single avenue I could as to why it wasn't starting. I figured it was getting spark, but maybe it just wasn't strong enough. So I thought I would get some sand paper and sand the rotor down a little to see if that would help any. Right when i take the cap off, I see a screw sitting there and the rotor without a screw... Turns out, the rotor was just spinning and causing a spark at any random time causing the back fires/hick ups.
It still wouldn't start after I put the screw back into the rotor, but it sounded really close. So I moved the cam over a tooth and BAM! Started right up. It seems to be running really smooth, but I'll have to put the timing light up to it tomorrow.
For future reference: I have a jdm d15b block with a d16y7 head and I used the z6 timing belt, and y7 head gasket. I also used the d15b cam gear.
Thanks for the help everyone!
Old 05-11-2009, 12:38 AM   #4 (permalink)
transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !
which D15B cam gear did you use?????????
simple question, pic A or B ok????
A
B
Old 05-11-2009, 01:03 AM   #5 (permalink)
Mugen112's Avatar
the first one. cam gear A. Why? Is something wrong?
Old 05-11-2009, 01:15 AM   #6 (permalink)
nope! Just checking to be sure.
Old 05-11-2009, 01:18 AM   #7 (permalink)
Mugen112's Avatar
haha scared me for a sec! She runs great btw! thanks for all the help man!
Old 05-11-2009, 01:22 AM   #8 (permalink)
Try teaching some of the newbs then.....so folk have a clue, those I keep tabs on and check their progress.
The more I look back, I'm a teacher like mom was, told her so today.
Old 05-12-2009, 08:37 AM   #9 (permalink)
Rep Power: 0 builtsinglecam is nobody
A
B
ok i did the samething but im running a d15b7 block?y7 head and im using y7 cam gear and it sounds like the timing is off but the marks are correct so could this be my problem that im not using the cam gear in pic A.
builtsinglecam is offline   Reply With Quote Quick reply to this message
Old 05-12-2009, 07:38 PM   #10 (permalink)
anyone?
Old 05-20-2009, 09:50 PM   #11 (permalink)
teamols's Avatar
Rep Power: 15 teamols is trying to make new friends
find a cam gear like that in example a and carefully set your cam timing to remove the slack. run it it sounds like what u need
teamols is offline   Reply With Quote Quick reply to this message
Old 01-28-2012, 09:18 PM   #12 (permalink)
Rep Power: 0 civic coupe is nobody
Hi i have a d16y7 engine with a blown bottom end and i have a d15b jdm engine and im going to put the y7 head on the d15b block will that work fine with my obd2 harness and ecu and witch head gasket and timing belt do i use all information would be great thanks
civic coupe is offline   Reply With Quote Quick reply to this message
iconAll times are GMT -8. The time now is 05:48 AM. | Welcome to Forum, please register to access all of our features.
