1984 Civic d16a1 limp mode - D-series.org
Old 11-29-2017, 09:49 AM   #1 (permalink)
Rep Power: 0 paris.edwardsiii2 is trying to make new friends
Default 1984 Civic d16a1 limp mode
I have a 1984 Honda Civic that has a d16a1 swap from an 89 Integra. All the wiring is from the Integra . I replaced and reseated the valves , new MLS head gasket , arp headstuds , and all new ignition system - distributor , wires , plugs , and the car starts and runs but I am throwing a code 4 ( CPS ) and a code 20 (ELD) and the car is cutting rpms at about 3500 and car won't go past about 65 mph . I tried replacing the CPS with one from the junk yard and still have the same problem. Tried a new ecu , same problem still .I've went over all the wiring everything is grounded and plugged in properly , the timing is good .so I was wondering if anyone has had this issue and knows how to fix it . If not I was thinking of going obd1 . Any feedback is helpful.
Sent from my Z981 using Tapatalk
paris.edwardsiii2 is offline   Reply With Quote Quick reply to this message
Old 11-29-2017, 02:08 PM   #2 (permalink)
B-series Destroyer
rico58204's Avatar
Rep Power: 22 rico58204 is the fucking MAN!!!!rico58204 is the fucking MAN!!!!rico58204 is the fucking MAN!!!!
rico58204 is the fucking MAN!!!!rico58204 is the fucking MAN!!!!rico58204 is the fucking MAN!!!!rico58204 is the fucking MAN!!!!rico58204 is the fucking MAN!!!!rico58204 is the fucking MAN!!!!rico58204 is the fucking MAN!!!!rico58204 is the fucking MAN!!!!rico58204 is the fucking MAN!!!!rico58204 is the fucking MAN!!!!rico58204 is the fucking MAN!!!!rico58204 is the fucking MAN!!!!rico58204 is the fucking MAN!!!!
Does your civic even have an ELD?
Can you provide instructions on how to wire all 4 vtec solenoids in parallel? I would like to hit vtec 4 times as hard, but I'm confused as to how the wiring configuration would look. Thanks
You link all the grounds, then wire each solenoid into the spark plug wires, that way they hit sequentially as the engine fires. This creates what I like to call asphalt shattering VTEC.
rico58204 is offline   Reply With Quote Quick reply to this message
Old 11-29-2017, 02:45 PM   #3 (permalink)
Not sure , all the wiring is from the Integra . I didn't use any of the civics.where is it located on the Integra?
Old 11-30-2017, 04:09 AM   #4 (permalink)
B-series Destroyer
rico58204's Avatar
In the fuse block.
Old 11-30-2017, 12:15 PM   #5 (permalink)
jlicrx's Avatar
Rep Power: 13 jlicrx smells like Boratjlicrx smells like Boratjlicrx smells like Boratjlicrx smells like Boratjlicrx smells like Borat
code 4 is for the Crank Sensor which is inside the distributor - about the only way to fix it, to keep it from going into limp mode is to replace the distributor
something wrong with the Cylinder Sensor on the end of the exhaust camshaft will throw a code 9 and is usually a wiring problem - the sensor seldom fails
Code 20 is generally caused by a bad alternator - usually failed diodes
ZCspeed Racing
jlicrx is online now   Reply With Quote Quick reply to this message
Old 11-30-2017, 12:17 PM   #6 (permalink)
jlicrx's Avatar
In the fuse block.
the under hood fuse block
ZCspeed Racing
Old 11-30-2017, 12:23 PM   #7 (permalink)
Alright I'll try a better distributor because I did get a cheap one off eBay so that might be the problem
Old 11-30-2017, 02:21 PM   #8 (permalink)
Fixed!!! It was the distributor , it feels much better now .Thanks for your input.
Old 12-01-2017, 03:18 PM   #9 (permalink)
Meat Popsicle
Paterico's Avatar
Rep Power: 28 Paterico is on a level you can only DREAM about! ! !Paterico is on a level you can only DREAM about! ! !Paterico is on a level you can only DREAM about! ! !
Paterico is on a level you can only DREAM about! ! !Paterico is on a level you can only DREAM about! ! !Paterico is on a level you can only DREAM about! ! !Paterico is on a level you can only DREAM about! ! !Paterico is on a level you can only DREAM about! ! !Paterico is on a level you can only DREAM about! ! !Paterico is on a level you can only DREAM about! ! !Paterico is on a level you can only DREAM about! ! !Paterico is on a level you can only DREAM about! ! !Paterico is on a level you can only DREAM about! ! !
This is how all threads should be. Problem -> suggestions -> solution.
Not some dickhead noob who posts, gets advice, and never returns with the outcome.
Good on ya OP, glad it’s fixed
R.I.P. Pat Primmer
Paterico is offline   Reply With Quote Quick reply to this message
iconAll times are GMT -8. The time now is 06:25 AM. | Welcome to Forum, please register to access all of our features.
