94 eg civic swap zc - D-series.org
Old 06-10-2017, 07:54 PM   #1 (permalink)
Rep Power: 0 Slushpup234 is nobody
Default 94 eg civic swap zc
It's a zc out of a 1988 integra trans out of a crx si distributor out of a 94 ex I've replaced plugs wires cap button coil ignition control module new tires rims new 02 sensor and it drives but has no power need help
Slushpup234 is offline   Reply With Quote Quick reply to this message
Old 06-10-2017, 08:09 PM   #2 (permalink)
what ecu? check timing
Old 06-10-2017, 08:13 PM   #3 (permalink)
it's a Ecu out of a integra but with the distributer and wiring being obd1
Old 06-10-2017, 08:20 PM   #4 (permalink)
but u gotta really push it to do 70
Old 06-11-2017, 06:33 AM   #5 (permalink)
Default 94 eg zc swap
Old 06-11-2017, 10:26 AM   #6 (permalink)
Sounds like you need to tune it. Unless you got an OBD1 DOHC ZC ecu some how, which I doubt.
Also I am going to assume its mechanical timing is wrong, just because kids love working on Hondas and doing timing belts wrong.
Old 06-11-2017, 05:54 PM   #7 (permalink)
there is no need to make 2 of the same threads.
Old 06-11-2017, 09:18 PM   #8 (permalink)
I'm not familiar with Hondas to much
Old 06-11-2017, 10:29 PM   #9 (permalink)
Time...is out.
Old 06-12-2017, 03:06 AM   #10 (permalink)
Rep Power: 21 robscrx is the fucking MAN!!!!robscrx is the fucking MAN!!!!robscrx is the fucking MAN!!!!
robscrx is the fucking MAN!!!!robscrx is the fucking MAN!!!!robscrx is the fucking MAN!!!!robscrx is the fucking MAN!!!!robscrx is the fucking MAN!!!!robscrx is the fucking MAN!!!!robscrx is the fucking MAN!!!!robscrx is the fucking MAN!!!!robscrx is the fucking MAN!!!!robscrx is the fucking MAN!!!!robscrx is the fucking MAN!!!!robscrx is the fucking MAN!!!!robscrx is the fucking MAN!!!!
ecu is obd0 but distributor is obd1?
robscrx is offline   Reply With Quote Quick reply to this message
Old 06-12-2017, 06:14 AM   #11 (permalink)
So what should I do
Old 06-12-2017, 12:26 PM   #12 (permalink)
theotherchris's Avatar
Rep Power: 13 theotherchris is hot as a volcano
theotherchris is hot as a volcanotheotherchris is hot as a volcanotheotherchris is hot as a volcanotheotherchris is hot as a volcanotheotherchris is hot as a volcanotheotherchris is hot as a volcanotheotherchris is hot as a volcanotheotherchris is hot as a volcanotheotherchris is hot as a volcanotheotherchris is hot as a volcanotheotherchris is hot as a volcanotheotherchris is hot as a volcanotheotherchris is hot as a volcanotheotherchris is hot as a volcano
Where to begin, where to begin....
1. You CANNOT run an obd0 ecu with an obd1 dizzy., so let's hope your using a 92 and up ecu.
2. The dohc zc did not come in the 88/89 integra's.
3. The 94 ex distibutor IS NOT the correct dizzy, you either need A. The td43-u distributor, or b, read the thread about swapping the internals of the 92-95 non vtec dizzy into the housing of the 88/89 Integra dizzy.
Your lack of specific details makes it open to.interpretation on our end, so we have to assume things.
So, let's assume, you are running an obd1 ecu.just about any non vtec ecu will allow you run and drive, although not at peak performance.
Your issue sounds like timing. Either mechanical, or electrical. Taking into account your not using the correct distributor, I'm going with electrical.
theotherchris is offline   Reply With Quote Quick reply to this message
Old 06-12-2017, 07:05 PM   #13 (permalink)
seems like the main theme here is TIMING.
iconAll times are GMT -8. The time now is 11:36 AM. | Welcome to Forum, please register to access all of our features.
