Crazy burning oil after headgasket replacement - D-series.org
Old 02-21-2016, 02:06 AM   #1 (permalink)
Rep Power: 0 Bumblebee is nobody
Default Crazy burning oil after headgasket replacement
Hi there, i'm happy that i found a forum.
I have a huge problem with my euro spec crx. Engine type is d16z5.
2 weeks ago i replaced the headgasket on it. Also the valve stem seals were replaced same time. So i did a test ride with low rpm's, it was smoking white/ gray and i thought it can be some coolant or oil which stands in the block, so did an oilchange. Nothing changed it was still smoking, yesterday i drove to work with car (i'm working in a car repair shop) and showed the master mechanic how its doing. So we did an wheel alignment and than he checked the engine, took the plugs out did an compression test which was good.
we had done also an leak test (after first testride when headgasket was done) and the gauge showed under 20% leaking.
The mAster mechanic is thinking the vss are bad. Today i started it up and at idle it began to missfire, dark grey and brown smoke came out. In seconds my garage looked foged like a club.
After doing a little bit research i was reading that the vss on intake and exhaust side are different and the springs have different colors. I asked the mechanic (he helped me to replace the vss) if we did it right and he said who cares they are all the same. Right now i don't know what to do and what is worn. Hopefully you guys can help me
Bumblebee is offline   Reply With Quote Quick reply to this message
Old 02-21-2016, 09:14 AM   #2 (permalink)
HiProfile's Avatar
It's possible the wrong headgasket was used, since your motor appears to be a dohc ZC style. Most likely the seals are leaking, either from being made wrong or installed wrong. Since the dohc ZC is not as common, I wonder if the seals used were for a newer sohc motor.
Did the person that installed the seals ever perform them before for that specific head, or at least done a few 90's Honda heads?
Old 02-21-2016, 10:07 AM   #3 (permalink)
We did one head before on same type of engine but years ago. The headgasket kit i ordered should fit perfect. I put the head gasket on, there was marker on "up this side"
Thats what i did,
Do you think it could be the head gasket?
Old 02-21-2016, 10:11 AM   #4 (permalink)
We used the head set payen DS881.
Old 02-21-2016, 10:41 AM   #5 (permalink)
I called also an engine rebuild shop. They told me the piston rings are broken. I can't believe that. Also the head gasket, i cleaned the head side and block side perfect, put the head on, tighten the bolts with right torque,
Put a new timing belt with new pulley on, checked the timing settings 2 more times, valve clearence adjusted, new plugs,
I don't know why but i have the feeling that on the valve stem seals something is wrong.
I mean they looked really all the same. Same diameter and all same, but we had not checked for different colors. Can that really be that huge difference?
Old 02-21-2016, 12:38 PM   #6 (permalink)
jetrinka's Avatar
Rep Power: 5 jetrinka is starting to learn the ropesjetrinka is starting to learn the ropesjetrinka is starting to learn the ropesjetrinka is starting to learn the ropesjetrinka is starting to learn the ropesjetrinka is starting to learn the ropesjetrinka is starting to learn the ropes
If it never smoked before the problem lies in the work that was done to the vehicle.
jetrinka is offline   Reply With Quote Quick reply to this message
Old 02-21-2016, 12:40 PM   #7 (permalink)
vss is on the transmission, not cylinder head.
Old 02-21-2016, 12:44 PM   #8 (permalink)
jetrinka's Avatar
I think he means valve stem seals.
Old 02-21-2016, 01:21 PM   #9 (permalink)
Yes i mean valve stem seals,
I open the engine tomorrow evening again, i'll let you know
Old 04-02-2016, 10:00 AM   #10 (permalink)
So, sorry that it took so long to hear something of me.
I took the head off, replaced all valve and stem seals again, replaced head gasket, head bolts, new piston rings, new rod bearings.
Engine runs fine so far but after couple rides the next problem is here
As soon the engine is hot the oil pressure warning light comes on.
I measured it with tool and the oil pressure goes real low to 10-15psi
As soon that happens the valves are
Ticking louder. No noise from rod bearings or main bearings.
I have no idea what to do now
Before i put all together i cleaned also the filter of oil pump.
The engine had the oem rod bearings in and i replaced them with king racing rod bearings in standard size
Oil i used 10w40 and an parts plus oil filter.
Does somebody have an idea?
Old 04-02-2016, 10:05 AM   #11 (permalink)
My girlfriend came back 2 minutea ago and said she was driving it, pushed it hard over 6000 rpms, let it came down and stopped at a stop sign, engine just cut off. She started it up again and it wouldnt idle, she was waiting 5-10 minutes and than it was idle ok, she drove back and the oil light came back on, she said first it was blinking dimmed and than it stayed on again
Old 04-02-2016, 11:09 AM   #12 (permalink)
oil pump.
slo_eg8 is online now   Reply With Quote Quick reply to this message
Old 04-02-2016, 01:22 PM   #13 (permalink)
Oil pump would be ok for me
I hope ita the oil pump and not the new king rod bearings
Old 04-02-2016, 02:17 PM   #14 (permalink)
you need to stop throwing parts at it.
AT this point it would be FAR more effective for someone who is very familiar with hondas come and look at it.
Old 04-02-2016, 02:38 PM   #15 (permalink)
theotherchris's Avatar
Rep Power: 13 theotherchris is hot as a volcano
theotherchris is hot as a volcanotheotherchris is hot as a volcanotheotherchris is hot as a volcanotheotherchris is hot as a volcanotheotherchris is hot as a volcanotheotherchris is hot as a volcanotheotherchris is hot as a volcanotheotherchris is hot as a volcanotheotherchris is hot as a volcanotheotherchris is hot as a volcanotheotherchris is hot as a volcanotheotherchris is hot as a volcanotheotherchris is hot as a volcanotheotherchris is hot as a volcano
Did you at least inspect the VALVE GUIDES when you were in there?
theotherchris is offline   Reply With Quote Quick reply to this message
Old 04-02-2016, 03:08 PM   #16 (permalink)
Totally forgot valve guides are replaced also,
I take out the oil pan tomorrow and check the rod bearings again
Then i leave all open to get the bearings measured, i've seen on line that standard king bearings are same size than the blue oem bearings, they are the biggest ones, i like to make sure that they don't mess up my crank
Old 04-03-2016, 04:01 AM   #17 (permalink)
The_Acid_Beaver's Avatar
You need to measure clearances and not just slap in rod bearings.
RTFM. No, really. Do it.
Old 04-03-2016, 05:07 AM   #18 (permalink)
So finally have good, i took the oil pan off...
Took the rod bearings out again, they are broken down. King xp racing bearings gone after a half fuel tank driving. I just put my old oem ones back in, did a testdrive for about 2 hours and 80 miles later no problems.
I checked the numbers on rods and crank to identify what the spec bearings are they would fit for my engine. So i got color brown cylinder 1&4, green for 2&3.
the king bearings have a oem number to cross and this makes a blue bearing, a lot to big for my engine.
Why do they sell bearings in the biggest size?
Old 04-03-2016, 05:11 AM   #19 (permalink)
I will order the bearings oem like the numbers are saying, then i will use plastigauge to make sure its perfect.
Normally if you order standard size bearings you will get the middle thickness of bearings, so i know it from vw, it's not a 100% perfect but it works well
iconAll times are GMT -8. The time now is 12:00 PM. | Welcome to Forum, please register to access all of our features.
