185/65/14 on CRXwith DOHC ZC - D-series.org
Old 11-09-2015, 07:19 PM   #1 (permalink)
CRX88's Avatar
Rep Power: 0 CRX88 is nobody
Default 185/65/14 on CRXwith DOHC ZC
Hi guys,
I just wanted to know your thoughts with tyres on a DOHC ZC with 185/65/14s?
I know that factory CRXs came out with 185/60/14 it's just that I like the tallness for more comfort and hopefully not throw out my rpms and fuel mileage?
Thanks guys Your expertise is much appreciated here down under
CRX88 is offline   Reply With Quote Quick reply to this message
Old 11-09-2015, 07:20 PM   #2 (permalink)
CRX88's Avatar
Note I'm also on coil overs and low hence my thoughts on putting comfy tyres
Old 11-09-2015, 08:40 PM   #3 (permalink)
Your speedo will be accurate for once.
MPG will be the same, but the devices recording will be showing TRUE numbers and not inflated numbers, so while it will change, it will be correct for once.
Old 11-10-2015, 12:14 AM   #4 (permalink)
CRX88's Avatar
Thanks Transzex,
im about to buy 4 new tyres 185/65/14
lol so the factory tyre size were incorrect.
performance ? id assume it wouldnt change soo much
Old 11-10-2015, 01:52 AM   #5 (permalink)
CRX88's Avatar
ive just been offered 17/65/14 at a set of four all same brands or 185/65/14 with two tpye of brands.
would the 175/65/14 be way off for my crx?
Old 11-10-2015, 10:17 AM   #6 (permalink)
theotherchris's Avatar
Rep Power: 13 theotherchris is hot as a volcano
theotherchris is hot as a volcanotheotherchris is hot as a volcanotheotherchris is hot as a volcanotheotherchris is hot as a volcanotheotherchris is hot as a volcanotheotherchris is hot as a volcanotheotherchris is hot as a volcanotheotherchris is hot as a volcanotheotherchris is hot as a volcanotheotherchris is hot as a volcanotheotherchris is hot as a volcanotheotherchris is hot as a volcanotheotherchris is hot as a volcanotheotherchris is hot as a volcano
Without seeing the tires I'd stick with the 185's
theotherchris is offline   Reply With Quote Quick reply to this message
Old 11-10-2015, 10:20 AM   #7 (permalink)
there are tire size calculators available online, find one.
I suggest the 185/65/14s
much more common size if tire hazard warranty is required for any reason, and much easier to match a pair of snow tires or something in the future
Old 11-10-2015, 11:18 AM   #8 (permalink)
CRX88's Avatar
Thanks guys .. ! Yes I've used the calculator too and the 185/65 shows a 3% positive and the 175/65 showed 1%...
Old 11-12-2015, 06:19 AM   #9 (permalink)
JoelEspinoza's Avatar
Rep Power: 13 JoelEspinoza is hot as a volcano
JoelEspinoza is hot as a volcanoJoelEspinoza is hot as a volcanoJoelEspinoza is hot as a volcanoJoelEspinoza is hot as a volcanoJoelEspinoza is hot as a volcanoJoelEspinoza is hot as a volcanoJoelEspinoza is hot as a volcanoJoelEspinoza is hot as a volcanoJoelEspinoza is hot as a volcanoJoelEspinoza is hot as a volcanoJoelEspinoza is hot as a volcanoJoelEspinoza is hot as a volcano
If you are looking to split the line between comfort and performance, I think you are probably going about it the wrong way. Crappy tires and hard springs = crappy performance. Decent tires and softer springs = decent performance.
Give a man a match, you will keep him warm for a minute. Light him on fire, however, and he will be warm the rest of his life....
JoelEspinoza is offline   Reply With Quote Quick reply to this message
iconAll times are GMT -8. The time now is 07:55 AM. | Welcome to Forum, please register to access all of our features.
