87 Si D16a1 problems - D-series.org
Old 11-15-2012, 10:27 AM   #1 (permalink)
Performance Freaks EG's Avatar
Rep Power: 0 Performance Freaks EG is nobody
Default 87 Si D16a1 problems
I;m working on a friends 87 CRX Si with a D16a1 swap with a PG7 ecu. Car has been converted to electronic advance by a local shop and ran fine for a few months. But now the problem we're running into is the car will idle but wont rev up at all. Cam and ignition timing is perfect. Engine has new ngk plugs, new plug wires, new dist cap, new rotor and new coil. Also has a new TPS. With the throttle body wide open the motor will rev up but very very slowly. Any ideas what could be the issue here. Thanks guys
Originally Posted by TurboCivic95
I'll sell you a Flux Capacitor for $349.99. Its been ported so it pumps out 1.85jigawatts instead of the stock 1.21 jigawatts. It really helped my top end.....88mph and up it fawkin rips.
Save your $350 and put it towards a 'real' turbo kit.
project*Turbo Z6*
Performance Freaks EG is offline   Reply With Quote Quick reply to this message
Old 11-15-2012, 10:34 AM   #2 (permalink)
JBrettHowell's Avatar
Rep Power: 12 JBrettHowell is fly like an eagleJBrettHowell is fly like an eagleJBrettHowell is fly like an eagleJBrettHowell is fly like an eagleJBrettHowell is fly like an eagleJBrettHowell is fly like an eagleJBrettHowell is fly like an eagleJBrettHowell is fly like an eagleJBrettHowell is fly like an eagleJBrettHowell is fly like an eagleJBrettHowell is fly like an eagleJBrettHowell is fly like an eagle
Any CELs? What's the state of the O2 sensor? Fuel filter? Ignitor?
JBrettHowell is offline   Reply With Quote Quick reply to this message
Old 11-15-2012, 10:41 AM   #3 (permalink)
The_Acid_Beaver's Avatar
Cam timing. Maybe a belt skipped a tooth.
Fuel pressure?
IAT and ECT sensors in spec?
ICM/Ignitor check out?
RTFM. No, really. Do it.
Old 11-15-2012, 10:44 AM   #4 (permalink)
The owner of the car diidnt have a o2 sensor and had the bung open so i threw a sensor i had layin around in. the ends been cut so its not hooked up. I've already told him he definitely needs a new one. Just trying to narrow this down to a single issue.
Ignitor I'm unsure of. The motor has spark on all 4 cylinders but it does seem weak. Havent checked the fuel filter yet and I'm about to go check the CEL at the moment
project*Turbo Z6*
Old 11-15-2012, 11:18 AM   #5 (permalink)
You will have at least 1 code for the O2 sensor. Get the crimped in place properly and reset the ECU.
Old 11-23-2012, 08:39 PM   #6 (permalink)
arny213's Avatar
Rep Power: 9 arny213 is learning the way of the Darny213 is learning the way of the D
I would also hook up a fuel pressure gauge and check it while your trying to rev the motor. if you notice a substantial drop in pressure you could have a clogged fuel filter or a bad pump. it is acting like a fuel problem to me, unless your timing is way off, but then it would idle poorly aswell.
Posted by KUNGFUHUSTLER
Holy isht man! You pulled this off faster then a $20 bill in a titty bar! big props to you!
Re:ive been running the everliving *** out of this thing ALOT. beat 3 bikes in the past 2 days alone. probably nearing over 50 hwy pulls lol..still holding up awesome! its a wierd feeling because im use to having to replace the tranny by now. CG ftmfw!
93 civic hatch d16 street car [email protected]
arny213 is offline   Reply With Quote Quick reply to this message
iconAll times are GMT -8. The time now is 05:04 AM. | Welcome to Forum, please register to access all of our features.
