Oil & what looks like metal particles.... - D-series.org
Old 07-15-2012, 09:14 AM   #1 (permalink)
95CivicDOHC's Avatar
Rep Power: 8 95CivicDOHC is starting to learn the ropes95CivicDOHC is starting to learn the ropes95CivicDOHC is starting to learn the ropes95CivicDOHC is starting to learn the ropes95CivicDOHC is starting to learn the ropes95CivicDOHC is starting to learn the ropes
Default Oil & what looks like metal particles....
On my spark plugs. Fuck. Where to start? Obd 1 dohc zc
95CivicDOHC is offline   Reply With Quote Quick reply to this message
Old 07-15-2012, 10:01 AM   #2 (permalink)
_Jack_Bauer_'s Avatar
Rep Power: 9 _Jack_Bauer_ is starting to learn the ropes_Jack_Bauer_ is starting to learn the ropes_Jack_Bauer_ is starting to learn the ropes_Jack_Bauer_ is starting to learn the ropes_Jack_Bauer_ is starting to learn the ropes_Jack_Bauer_ is starting to learn the ropes_Jack_Bauer_ is starting to learn the ropes
Oil in the plug hole, or on the tip?
_Jack_Bauer_ is offline   Reply With Quote Quick reply to this message
Old 07-15-2012, 10:48 AM   #3 (permalink)
It was on the threads. After I pulled the VC I figured I need new tube seals.
Old 07-15-2012, 10:53 AM   #4 (permalink)
could just be vc seals as said.
Drain the oil and fine out whats going on down there.
Other then that runs good?
Old 07-15-2012, 12:09 PM   #5 (permalink)
TheToaster's Avatar
Rep Power: 16 TheToaster is the fucking MAN!!!!TheToaster is the fucking MAN!!!!TheToaster is the fucking MAN!!!!
TheToaster is the fucking MAN!!!!TheToaster is the fucking MAN!!!!TheToaster is the fucking MAN!!!!TheToaster is the fucking MAN!!!!TheToaster is the fucking MAN!!!!TheToaster is the fucking MAN!!!!TheToaster is the fucking MAN!!!!TheToaster is the fucking MAN!!!!
Change your oil. Use a good filter. Try a magnetic Drain plug. MFactory is cheap goodness.
TheToaster is offline   Reply With Quote Quick reply to this message
Old 07-15-2012, 03:08 PM   #6 (permalink)
Also, check PCV system. If its clogged up it will cause some blow by.
Old 07-16-2012, 04:25 PM   #7 (permalink)
take pics
it was probably anti-seize.
either that or some bad ass detonation.
iconAll times are GMT -8. The time now is 05:05 AM. | Welcome to Forum, please register to access all of our features.
