DIY Del Sol seats in an ef - without seat pan swap!!! - D-series.org
Old 05-08-2008, 06:26 AM   #1 (permalink)
The H Badge is it!
SOHC_Rules's Avatar
Rep Power: 20 SOHC_Rules is hot as a volcanoSOHC_Rules is hot as a volcano
iTrader Score: 30 reviews
Send a message via AIM to SOHC_Rules
Default DIY Del Sol seats in an ef - without seat pan swap!!!
alright guys, took a look at other diy's and what not on how to do this, looked like a huge pain in the ass, so i did it my own way.
tools required:
drill
3/8" drill bit
angle grinder is handy
welder
12mm socket
3" extension
3/8" ratchet
12mm wrench
and here's how:
--- I did the diy on the passenger side, but the driver side is the same idea, just diff side, obviously.. do this at your own risk, do not weld in the car. ---
first step:
out with the old..
....in with the new. do a quick test fit, making sure the seat is all the way back and the rails are all the way forward, and you will see that the front bolt nearest the center console fits right in.
you will also notice the rear inside is no where near close..
from here, get the seat to sit straight, then sorta eye ball where the hole would need to be in order for it to line up. after doing so, move on to the next step..
step 2:
i took the seat out of the car and layed it on its side, took my angle grinder and took off the paint in order to get some good welds:
rear outside slider:
(the bottom grind)
and the front outside, sorry for dark pic.. you will also see that i cut a notch out, theres a reason for this and if your seats sit straight ( like mine ) you will need to notch this too..
peekaboo crv wheel!!!! lol
step 3:
i then cut some 3/16x1" flat plate, but anything should work really, into pieces about this size:
theres a reason for the size difference, the larger one goes on the front to make sure theres enough material, and the smaller one is for the rear cause its not really that far off.
xbox live: turboa6
play COD BO2 and Forza 4
SOHC_Rules is offline   Reply With Quote Quick reply to this message
Old 05-08-2008, 06:27 AM   #2 (permalink)
The H Badge is it!
SOHC_Rules's Avatar
step4:
weld on your tabs
rear (after i painted it black, sorry)
you will notice that it is offset. if you have your seats lined up like mine, then your will be too.
front:
what i did was overlap the metal tab a little bit, and filled the hole with weld, and also hit it from the back for some extra strength.
step5:
put seat back into the car, put the front inside bolt in, and then get the seat to sit straight again. once they are straight get your drill and proceed to drill a 3/8" hole lined up with the bolt hole (duh..).. should look like this:
you will now see why the notch is necessary... lol... tighten those bolts down a little (not so much where they wont turn anymore) and do the same for the rear..
should be like this
and bam you're done that side, just rinse and repeat for the driver side
xbox live: turboa6
Old 05-08-2008, 06:30 AM   #3 (permalink)
The H Badge is it!
SOHC_Rules's Avatar
here's how they look in my car:
plenty of head clearance..
and there it is
let me know what you all think..
xbox live: turboa6
Old 05-08-2008, 06:31 AM   #4 (permalink)
yEaH tHaT gUy!!!
Onatop's Avatar
Rep Power: 32 Onatop is on a level you can only DREAM about! ! !Onatop is on a level you can only DREAM about! ! !Onatop is on a level you can only DREAM about! ! !Onatop is on a level you can only DREAM about! ! !
Onatop is on a level you can only DREAM about! ! !Onatop is on a level you can only DREAM about! ! !Onatop is on a level you can only DREAM about! ! !Onatop is on a level you can only DREAM about! ! !Onatop is on a level you can only DREAM about! ! !Onatop is on a level you can only DREAM about! ! !Onatop is on a level you can only DREAM about! ! !Onatop is on a level you can only DREAM about! ! !Onatop is on a level you can only DREAM about! ! !Onatop is on a level you can only DREAM about! ! !Onatop is on a level you can only DREAM about! ! !Onatop is on a level you can only DREAM about! ! !Onatop is on a level you can only DREAM about! ! !
iTrader Score: 58 reviews
Send a message via AIM to Onatop Send a message via Yahoo to Onatop
love the jerry rig. cool write up.
Often replicated but never DUPLICATED & NEVER done like D&M Tuning
Onatop is offline   Reply With Quote Quick reply to this message
Old 05-08-2008, 07:18 AM   #5 (permalink)
Hi hater!
Boosted-EH-804's Avatar
Rep Power: 38 Boosted-EH-804 is on a level you can only DREAM about! ! !Boosted-EH-804 is on a level you can only DREAM about! ! !Boosted-EH-804 is on a level you can only DREAM about! ! !Boosted-EH-804 is on a level you can only DREAM about! ! !Boosted-EH-804 is on a level you can only DREAM about! ! !
Boosted-EH-804 is on a level you can only DREAM about! ! !Boosted-EH-804 is on a level you can only DREAM about! ! !Boosted-EH-804 is on a level you can only DREAM about! ! !Boosted-EH-804 is on a level you can only DREAM about! ! !Boosted-EH-804 is on a level you can only DREAM about! ! !Boosted-EH-804 is on a level you can only DREAM about! ! !Boosted-EH-804 is on a level you can only DREAM about! ! !Boosted-EH-804 is on a level you can only DREAM about! ! !Boosted-EH-804 is on a level you can only DREAM about! ! !Boosted-EH-804 is on a level you can only DREAM about! ! !Boosted-EH-804 is on a level you can only DREAM about! ! !Boosted-EH-804 is on a level you can only DREAM about! ! !
iTrader Score: 47 reviews
Send a message via AIM to Boosted-EH-804
good write up
Rcautoworks has all your automotive needs
Boosted-EH-804 is offline   Reply With Quote Quick reply to this message
Old 05-08-2008, 07:46 AM   #6 (permalink)
10 second daily driver :)
Boosted91's Avatar
Rep Power: 24 Boosted91 Still a JDM Star....
Boosted91 Still a JDM Star....Boosted91 Still a JDM Star....Boosted91 Still a JDM Star....Boosted91 Still a JDM Star....
iTrader Score: 24 reviews
please tell me where the jb weld might come in to replace the real welding? was you implying to jb weld the flat steel? if so you better edit your post before some noob does it and the jb weld snaps the first speed bump or worse yet they get in a wreck and the seats snap loose. i think the main reason every one uses the crx pans is not just so the holes line up but also so the seats sit lower in the car. the sol pans might not be the same height. not sure though i never looked at a sol pan. should have shampooed or replaced your carpet while you had the seats out
1994 Civic DX B18c1 turbo and awd.
1971 240z LS6 swap t56 six speed, T72 turbo.
1993 Civic DX, B18C1 510/325 @ 20 PSI.(SOLD)
10.7 @ 137.97
1990 CRX Si D16Z6 305/265 @ 22 PSI (SOLD)
11.6 @ 118
Boosted91 is offline   Reply With Quote Quick reply to this message
Old 05-08-2008, 08:08 AM   #7 (permalink)
I can't read...
myHonda1's Avatar
Rep Power: 40 myHonda1 is on a level you can only DREAM about! ! !myHonda1 is on a level you can only DREAM about! ! !myHonda1 is on a level you can only DREAM about! ! !myHonda1 is on a level you can only DREAM about! ! !myHonda1 is on a level you can only DREAM about! ! !
myHonda1 is on a level you can only DREAM about! ! !myHonda1 is on a level you can only DREAM about! ! !myHonda1 is on a level you can only DREAM about! ! !myHonda1 is on a level you can only DREAM about! ! !myHonda1 is on a level you can only DREAM about! ! !myHonda1 is on a level you can only DREAM about! ! !myHonda1 is on a level you can only DREAM about! ! !myHonda1 is on a level you can only DREAM about! ! !myHonda1 is on a level you can only DREAM about! ! !myHonda1 is on a level you can only DREAM about! ! !myHonda1 is on a level you can only DREAM about! ! !myHonda1 is on a level you can only DREAM about! ! !
iTrader Score: 48 reviews
beautiful write-up!
yea, i wouldn't think about using jb weld on something like that.
"when life gives you lemons, paint that shit gold"
i love to rape kids...*silence*
let me touch you.
myHonda1 is offline   Reply With Quote Quick reply to this message
Old 05-08-2008, 08:13 AM   #8 (permalink)
The H Badge is it!
SOHC_Rules's Avatar
i agree, it is less than ideal to use JB weld instead of a real weld, but when used properly and given enough time to cure, it can hold just as strong. nonetheless i will edit the post.
the sol seat do sit a little higher, enough to notice while sitting in the seat but really not that bad.. probably sit 3/4" higher maximum.
and about my carpet, lol, theres no hope for it honestly. it used to be BLACK and is sun damaged to the point you see it now. kinda sucks, but i've lived with it for this long. eventually im going to either get a used replacement, or if i can bring myself to spend the cash, id get a brand new replacement.
thanks for the comments guys
xbox live: turboa6
Old 05-26-2008, 12:35 AM   #9 (permalink)
SnailTrail's Avatar
Rep Power: 0 SnailTrail is nobody
nice nice nice ! anybody know how to fit DEL SOLs into an EG? I'm havin trouble gettin the rail close to Ebrake to come off =(. gr8 DYI btw!
SnailTrail is offline   Reply With Quote Quick reply to this message
Old 05-28-2008, 12:35 PM   #10 (permalink)
panda's Avatar
Rep Power: 17 panda is hot as a volcano
panda is hot as a volcanopanda is hot as a volcanopanda is hot as a volcanopanda is hot as a volcanopanda is hot as a volcanopanda is hot as a volcanopanda is hot as a volcanopanda is hot as a volcanopanda is hot as a volcanopanda is hot as a volcanopanda is hot as a volcanopanda is hot as a volcanopanda is hot as a volcanopanda is hot as a volcano
Send a message via AIM to panda
atleast it wasnt gorilla glue lol.. but good wright up..
panda is offline   Reply With Quote Quick reply to this message
Old 05-28-2008, 01:04 PM   #11 (permalink)
racist-bigot-sexist-homophob
mindless's Avatar
Rep Power: 43 mindless is on a level you can only DREAM about! ! !mindless is on a level you can only DREAM about! ! !
iTrader Score: 43 reviews
Wait did you weld these or use JB weld? Dude please tell me you're not riding around in your rex with JB-welded del sol seats.
Old 05-28-2008, 02:54 PM   #12 (permalink)
peace out
icarusdown's Avatar
Rep Power: 16 icarusdown is approaching greatnessicarusdown is approaching greatnessicarusdown is approaching greatnessicarusdown is approaching greatnessicarusdown is approaching greatnessicarusdown is approaching greatnessicarusdown is approaching greatnessicarusdown is approaching greatnessicarusdown is approaching greatnessicarusdown is approaching greatnessicarusdown is approaching greatnessicarusdown is approaching greatnessicarusdown is approaching greatnessicarusdown is approaching greatness
iTrader Score: 18 reviews
hmm. that seems a little sketchy. even if it is welded, that shit could possibly snap in a collision if those welds are flawed and they do look a little boogery.
never seen green carpet in a crx either.
I like the seats tho.
icarusdown is offline   Reply With Quote Quick reply to this message
Old 05-28-2008, 03:08 PM   #13 (permalink)
D-series WTF?!?!
MiloReaper87's Avatar
Rep Power: 20 MiloReaper87 is hot as a volcanoMiloReaper87 is hot as a volcano
MiloReaper87 is hot as a volcanoMiloReaper87 is hot as a volcanoMiloReaper87 is hot as a volcanoMiloReaper87 is hot as a volcanoMiloReaper87 is hot as a volcanoMiloReaper87 is hot as a volcanoMiloReaper87 is hot as a volcano
Send a message via AIM to MiloReaper87 Send a message via Yahoo to MiloReaper87
Green stain carpet??? WTF
Originally Posted by modsHXcivi
LOL.... The Man.... The Myth..... The Milo....
Check my photography
CAUTION: Remoer and myself may
on a verbal war
MiloReaper87 is offline   Reply With Quote Quick reply to this message
Old 05-28-2008, 06:54 PM   #14 (permalink)
mindless's Avatar
I agree. A seat pan swap may be harder but it is safer. But at least it's mounted at all points and not the 3 out of 4 some people roll around on. I still hope that isn't JB weld though.
It's the new JDM....didn't you know?
Old 05-28-2008, 07:28 PM   #15 (permalink)
Shoot me!
Hellhatch's Avatar
Rep Power: 44 Hellhatch is on a level you can only DREAM about! ! !Hellhatch is on a level you can only DREAM about! ! !Hellhatch is on a level you can only DREAM about! ! !
Hellhatch is on a level you can only DREAM about! ! !Hellhatch is on a level you can only DREAM about! ! !Hellhatch is on a level you can only DREAM about! ! !Hellhatch is on a level you can only DREAM about! ! !Hellhatch is on a level you can only DREAM about! ! !Hellhatch is on a level you can only DREAM about! ! !Hellhatch is on a level you can only DREAM about! ! !Hellhatch is on a level you can only DREAM about! ! !Hellhatch is on a level you can only DREAM about! ! !Hellhatch is on a level you can only DREAM about! ! !Hellhatch is on a level you can only DREAM about! ! !Hellhatch is on a level you can only DREAM about! ! !Hellhatch is on a level you can only DREAM about! ! !Hellhatch is on a level you can only DREAM about! ! !
iTrader Score: 50 reviews
Very nice job i just put these in my 00 hatch.
MY RIDE THREAD!!
GO STEELERS!
Hellhatch is offline   Reply With Quote Quick reply to this message
Old 05-28-2008, 07:54 PM   #16 (permalink)
mike93eh's Avatar
Rep Power: 14 mike93eh smells like Boratmike93eh smells like Boratmike93eh smells like Boratmike93eh smells like Boratmike93eh smells like Borat
Send a message via AIM to mike93eh
got del sol's in my crx...but mine were done a little bit better..
93 civic hatch street car - d16z6
10.93 @ 129mph (1.66 sixty foot)
mike93eh is offline   Reply With Quote Quick reply to this message
Old 08-04-2009, 07:47 PM   #17 (permalink)
Rep Power: 0 ED6b7Y8 is nobody
pics dont work...
E/S
ED6b7Y8 is offline   Reply With Quote Quick reply to this message
Old 08-05-2009, 04:08 PM   #18 (permalink)
Rep Power: 11 zccrxsi will become famous soon enoughzccrxsi will become famous soon enoughzccrxsi will become famous soon enough
i didn it a while ago in my crx it was a nice upgrade then i got rid of them for some pleather eg seats
zccrxsi is offline   Reply With Quote Quick reply to this message
Old 08-05-2009, 04:10 PM   #19 (permalink)
Originally Posted by ED6b7Y8 View Post
pics dont work...
because its over a year old, genius
[email protected]
Old 08-06-2009, 01:33 PM   #20 (permalink)
why not swap the rails? sooooo much easier. I did that in my eg8
iconAll times are GMT -8. The time now is 06:16 PM. | Welcome to Forum, please register to access all of our features.
