DIY: Rear Sway Bar Installation into a non-Si CRX - D-series.org
Closed Thread
Old 04-08-2007, 08:38 AM   #1 (permalink)
The Great Weldini
remoer's Avatar
Rep Power: 32 remoer Still a JDM Star....remoer Still a JDM Star....
remoer Still a JDM Star....remoer Still a JDM Star....remoer Still a JDM Star....remoer Still a JDM Star....remoer Still a JDM Star....remoer Still a JDM Star....remoer Still a JDM Star....remoer Still a JDM Star....remoer Still a JDM Star....
iTrader Score: 54 reviews
Send a message via AIM to remoer Send a message via MSN to remoer Send a message via Yahoo to remoer
Lightbulb DIY: Rear Sway Bar Installation into a non-Si CRX
here a really good write up taken from www.crxcommunity.com. i would have gotten everything from the original but it's no longer up.
http://www.crxcommunity.com/viewtopic.php?t=4944
First off I want to credit JMart for this project. I personally have only had Si models, but he converted a Rio Pink 89 DX to a 90-91 Si, swapping everything but the roof over from his wrecked Si.
So why do you do this? The best upgrade for any front-wheel-drive understeering Honda is a rear sway bar, whether you're adding it or upgrading the stock one. Unfortunately, Honda decided not to include a factory rear sway bar on the non-Si (HF and DX) model CRXs. For some aftermarket bars, you can use the rear tow-hook mounts with an adapter bracket. If you don't want to drop a lot of money on one, or you think an OEM Si sway bar is enough, this is how you can mount it like stock.
Materials and Tools
CRX/Civic Si rear lower control arms
CRX/Civic Si sway bar with brackets
sway bar to lower control arm bolts
sway bar bracket to frame bolts with nuts (use shock top hat nuts)
Grommets to fit the large holes
Electric drill with 3/8" bit and a stepped bit large enough to fit a 14mm socket through
14mm socket x2 and ratchet x2 with extension
jack and stands
Removing the old LCAs
This first part is pretty easy, you need to take out the stock lower control arms. Unbolt them from the hub, the shock, and finally from the car, and pull them out.
Installing the Sway Bar
All CRXs have the holes for the bracket bolts in the frame, but they don't all have the welded-on nuts for the bolts to thread into. A good choice for these is some shock tower (top hat) nuts. These nuts also make good replacements for the nuts that are welded to the frame to hold the lower control arms.
First thing, before you start drilling, empty the trunk of carpet and anything else that could be damaged. Using your 3/8" bit, drill through the floor pan from the bottom. Now you have four holes in the trunk that look directly down to the ground through the frame of your car. Get back inside the trunk, and open each hole up with your larger stepped bit.
You can now drop the nuts down through the top holes, while feeding the bolts up from the bottom. Bolt the brackets up to the car, letting the sway bar end links hang free for now. After installation, use the grommets you got to plug the holes.
Holes in the trunk for the bracket bolts.
Sway bar bracket installed (bottom view), just like OEM
Re-Installing the LCAs
Before you get them in, this is a good time to install new OEM or polyurethane bushings into your LCAs. If you already have some, this might be a good time to grease them up so they won't squeak as much. If you're installing used OEM arms, you may want to clean them up first, at the very least chase all the threads with a tap.
Put the inside end in first, and bolt the arm to the frame of the car. Then swing it up and bolt it up to the hub. Now bolt the sway bar end link to the LCA. Note that the first side will be much easier. To avoid stripping the hole or breaking anything, try to use a jack on the bar or the wheel to line up the bolt as much as possible, and remember to use anti-seize on all suspension parts.
Bolting the LCA to the shock and sway bar...
...and to the hub
1 monkey power = 0.332 hp.
The suspension should always be faster than the engine - BMW
The term stage was created to make mentally slow ppl feel physically fast.
my DOHC ZC - 133.73whp and 108.48wtq (tuned on a Dynojet)
remoer is offline   Quick reply to this message
Old 04-08-2007, 08:41 AM   #2 (permalink)
The Great Weldini
remoer's Avatar
here' more pics of parts and install.
Old 04-08-2007, 11:19 AM   #3 (permalink)
jOnYBrAvO's Avatar
Rep Power: 0 jOnYBrAvO is nobody
Send a message via MSN to jOnYBrAvO
very useful post!
thanks!
Civic EC9 D14A1
jOnYBrAvO is offline   Quick reply to this message
Old 04-08-2007, 11:40 AM   #4 (permalink)
Ferio inspired
NastyHabitzCRX's Avatar
Rep Power: 31 NastyHabitzCRX Still a JDM Star....NastyHabitzCRX Still a JDM Star....
NastyHabitzCRX Still a JDM Star....NastyHabitzCRX Still a JDM Star....NastyHabitzCRX Still a JDM Star....NastyHabitzCRX Still a JDM Star....NastyHabitzCRX Still a JDM Star....NastyHabitzCRX Still a JDM Star....NastyHabitzCRX Still a JDM Star....NastyHabitzCRX Still a JDM Star....NastyHabitzCRX Still a JDM Star....NastyHabitzCRX Still a JDM Star....NastyHabitzCRX Still a JDM Star....NastyHabitzCRX Still a JDM Star....
if you have access to a welder, you can weld-in some flange nuts upside down in those holes also.
this is how i did my DA sway on my sedan and works great. I wasn't too keen to drillin extra holes in my car
Re Fried Dreams 559
95 Civic EX 4dr- Ferio'd out
00 Civic LX 4dr- Ferio Vi-RS equipped
90 Civic EX 4dr- turbo D15b (sold)
98 Civic EX 4dr- USDM (99 front) (sold)
92 Accord EX 4dr- ricermobile(sold)
NastyHabitzCRX is offline   Quick reply to this message
Old 04-08-2007, 12:18 PM   #5 (permalink)
The Great Weldini
remoer's Avatar
then tell me why do they make rubber gromet for the holes in the front firewall? you can used them for them too.
Old 04-14-2007, 02:48 AM   #6 (permalink)
Rep Power: 13 mithuth is trying to make new friends
Very nice write up. Now I got more "to do" on my 90 CRX Dx... THANKS A LOT! hehe.
2003 Jeep Wrangler. Lifted, Locked and ready to rock.
1991 CRX Si 117K original miles, rust free
mithuth is offline   Quick reply to this message
Old 04-14-2007, 03:36 AM   #7 (permalink)
Live,love,laugh,be real
4Door's Avatar
Rep Power: 39 4Door is on a level you can only DREAM about! ! !4Door is on a level you can only DREAM about! ! !
4Door is on a level you can only DREAM about! ! !4Door is on a level you can only DREAM about! ! !4Door is on a level you can only DREAM about! ! !4Door is on a level you can only DREAM about! ! !4Door is on a level you can only DREAM about! ! !4Door is on a level you can only DREAM about! ! !4Door is on a level you can only DREAM about! ! !4Door is on a level you can only DREAM about! ! !
iTrader Score: 20 reviews
good info...
R.I.P. my mom - I miss you
10/3/1945-6/16/2007
R.I.P. - MiloReaper & Pat Primmer
96' CE1 Lx - Wags
04' Pilot EXL - Black Pile - Love it
is your friend, try it
[youtube ][ /youtube]
4Door is offline   Quick reply to this message
Old 04-14-2007, 07:59 PM   #8 (permalink)
The Great Weldini
remoer's Avatar
here's my soon to be in my rex, the whole 90 integra supension, w/90 VW Carrabo rotors, stainless steel lines still in the plastic.
i still need some parts. i have to go and replace the old Integra cailipers, order EBC Red Stuff brake pads, a Fastbrake bracket and ASR frame brace. in the pic you see a 14mm GSR rear swaybar i will be getting a 22mm swaybar.
damd that looks sexy. lol.
Old 04-14-2007, 10:35 PM   #9 (permalink)
4Door's Avatar
dude, the pic just tripped me out... i thought it was upside down for a minute...lol
i didnt know you could rock vw rotors...
10/3/1945-6/16/2007
96' CE1 Lx - Wags
Old 04-14-2007, 11:18 PM   #10 (permalink)
D-series WTF?!?!
MiloReaper87's Avatar
Rep Power: 20 MiloReaper87 is hot as a volcanoMiloReaper87 is hot as a volcano
MiloReaper87 is hot as a volcanoMiloReaper87 is hot as a volcanoMiloReaper87 is hot as a volcanoMiloReaper87 is hot as a volcanoMiloReaper87 is hot as a volcanoMiloReaper87 is hot as a volcanoMiloReaper87 is hot as a volcano
Send a message via AIM to MiloReaper87 Send a message via Yahoo to MiloReaper87
yEAH remoer thanks for rubbin it man u lucky twat!!!
Originally Posted by modsHXcivi
LOL.... The Man.... The Myth..... The Milo....
Check my photography
CAUTION: Remoer and myself may
on a verbal war
MiloReaper87 is offline   Quick reply to this message
Old 04-15-2007, 01:44 PM   #11 (permalink)
The Great Weldini
remoer's Avatar
i think you wanted to say milo was you damd pussy and i'll yup. your are what you eat. lol
yeah it's a big brake up grade. there's a thread on here done by c0nspire (click on the pics cause the forum was hack and you can't see them unless you click on them)about the big brake up grade and lapatx the difference of rotors stock to ITR rotors.
here's threads
lapatx: https://www.d-series.org/forums/showthread.php?t=64296
c0nspire: https://www.d-series.org/forums/showthread.php?t=46079
Old 04-15-2007, 02:33 PM   #12 (permalink)
Rep Power: 0 zero_ is nobody
awesome write up! now i have to try this!
zero_ is offline   Quick reply to this message
Old 11-23-2007, 04:44 AM   #13 (permalink)
EP3Moschini's Avatar
Rep Power: 15 EP3Moschini It's a JDM Star Bitches....
iTrader Score: 16 reviews
How about I just one up you remoer . . .
Im going to use EG/DC Omni lca's and an EG/DC ASR brace. . . then run a type-ARrrrg bar and call it a day less drilling and more bling. .
EP3Moschini is offline   Quick reply to this message
Old 11-23-2007, 06:54 AM   #14 (permalink)
Rep Power: 14 solfly is a name known to allsolfly is a name known to allsolfly is a name known to allsolfly is a name known to allsolfly is a name known to allsolfly is a name known to allsolfly is a name known to allsolfly is a name known to all
Send a message via AIM to solfly
the st bar fits any dx/hf/si
2002 Kawasaki Prairie 650
2002 Honda Civic Si
1999 Honda CRV EX RT4WD
1993 Honda Civic EX Sedan
1993 Honda del Sol Si
1988 Honda Civic STD Hatch
1979 Raised Ranch
solfly is offline   Quick reply to this message
Old 11-23-2007, 07:37 AM   #15 (permalink)
REDRAGN53's Avatar
Rep Power: 12 REDRAGN53 is starting to learn the ropesREDRAGN53 is starting to learn the ropesREDRAGN53 is starting to learn the ropesREDRAGN53 is starting to learn the ropesREDRAGN53 is starting to learn the ropesREDRAGN53 is starting to learn the ropesREDRAGN53 is starting to learn the ropes
remoer=pimp...rep for u
1994 Civic
East Coast Honda Challenge H4
While your out pick up a 20 lbs bag of play sand so you can extrude hone your intake with the engine running.
REDRAGN53 is offline   Quick reply to this message
Closed Thread
iconAll times are GMT -8. The time now is 09:28 PM. | Welcome to Forum, please register to access all of our features.
