Crack That Evil Crank Pulley Bolt - W/ Engine Out Of Car - D-series.org
Old 08-05-2019, 07:04 PM   #1 (permalink)
Nasty_Canasta's Avatar
Rep Power: 18 Nasty_Canasta is the fucking MAN!!!!Nasty_Canasta is the fucking MAN!!!!Nasty_Canasta is the fucking MAN!!!!
Nasty_Canasta is the fucking MAN!!!!Nasty_Canasta is the fucking MAN!!!!Nasty_Canasta is the fucking MAN!!!!Nasty_Canasta is the fucking MAN!!!!Nasty_Canasta is the fucking MAN!!!!Nasty_Canasta is the fucking MAN!!!!Nasty_Canasta is the fucking MAN!!!!
Default Crack That Evil Crank Pulley Bolt - W/ Engine Out Of Car
I had a Y8 crank pulley bolt that was giving me hell. So I had an idea -
I jacked the front end of the car up high enough to slide the block underneath.
Then I slowly brought the car down so the block had enough weight on it that it couldn't move. However, the jack was still supporting most all of the car's weight.
*Using the Honda crank pulley tool, I blocked the crank from moving.
*Heated up the crank pulley boly for a minute
*used a big-ass, socket pry bar with a 17mm socket and stood on it.
*CRACK!
So if you're in a pinch, use the weight of one of your Hondas to hold the block in place. You'll just pull an engine stand over if you aren't careful.
**Keep in mind that this threw a rod and I wanted parts off the block. However, if you are careful, you can do this with a block that you plan on using. You aren't really putting weight on the block. You are just using the weight of the car to keep the block from moving.
I need a flex hone to finish my budget A6 refresh. Help a brother out if you have one...
If you need a part, hit me up. I'm willing to help out the remaining D-Series soldiers on the cheap.
Nasty_Canasta is offline   Reply With Quote Quick reply to this message
Old 08-05-2019, 07:29 PM   #2 (permalink)
drtalon123's Avatar
Rep Power: 2 drtalon123 smells like Boratdrtalon123 smells like Boratdrtalon123 smells like Boratdrtalon123 smells like Boratdrtalon123 smells like Boratdrtalon123 smells like Borat
I was about to say did you put anything between the honda and the deck surface, but then I saw the thing about throwing a rod... that is actually a clever trick.
You could also lock the trans in gear and put the tires on the ground when everything was together, then make that the first thing you loosen/last thing you tighten!
My Recent EG Hatch
drtalon123 is offline   Reply With Quote Quick reply to this message
Old 08-05-2019, 07:42 PM   #3 (permalink)
That's funny! Good idea!
The plastic from the rocker panel covers did a pretty good job protecting it even though I didn't plan on it.
Old 08-06-2019, 01:57 AM   #4 (permalink)
Get a proper airline and fittings and a $40 CH impact will zip the bolt right off.
Size matters....
Old 08-06-2019, 02:08 PM   #5 (permalink)
I have no more air tools...or should say my compressor took a major shit on me.
But you are correct. A big, fat hose makes all the difference.
I need to get a new compressor...big time.
But yeah, this could help out a kid in his driveway with no access to serious tools.
This bolt was the most hardcore, stuck-ass crank bolt I've ever dealt with...even
worse than my old B7/ZC build...and that one was insanity.
Old 08-07-2019, 06:30 AM   #6 (permalink)
robgoof's Avatar
Rep Power: 17 robgoof is the fucking MAN!!!!robgoof is the fucking MAN!!!!robgoof is the fucking MAN!!!!robgoof is the fucking MAN!!!!
robgoof is the fucking MAN!!!!robgoof is the fucking MAN!!!!robgoof is the fucking MAN!!!!robgoof is the fucking MAN!!!!robgoof is the fucking MAN!!!!robgoof is the fucking MAN!!!!robgoof is the fucking MAN!!!!robgoof is the fucking MAN!!!!robgoof is the fucking MAN!!!!robgoof is the fucking MAN!!!!robgoof is the fucking MAN!!!!robgoof is the fucking MAN!!!!robgoof is the fucking MAN!!!!robgoof is the fucking MAN!!!!robgoof is the fucking MAN!!!!
been doing this the past couple,,,when I remember that is ..
Old 08-07-2019, 05:12 PM   #7 (permalink)
Meat Popsicle
Paterico's Avatar
Rep Power: 28 Paterico is on a level you can only DREAM about! ! !Paterico is on a level you can only DREAM about! ! !Paterico is on a level you can only DREAM about! ! !
Paterico is on a level you can only DREAM about! ! !Paterico is on a level you can only DREAM about! ! !Paterico is on a level you can only DREAM about! ! !Paterico is on a level you can only DREAM about! ! !Paterico is on a level you can only DREAM about! ! !Paterico is on a level you can only DREAM about! ! !Paterico is on a level you can only DREAM about! ! !Paterico is on a level you can only DREAM about! ! !Paterico is on a level you can only DREAM about! ! !Paterico is on a level you can only DREAM about! ! !
Ha, that’s one way I’ve never seen before.
Heat works wonders!
R.I.P. Pat Primmer
Paterico is offline   Reply With Quote Quick reply to this message
Old 08-07-2019, 08:45 PM   #8 (permalink)
RaveN1814's Avatar
Rep Power: 15 RaveN1814 is learning the way of the DRaveN1814 is learning the way of the D
If you have airtools, this is what practically everyone used back when I was a tech at a Honda dealership.
I just googled an image, since mine is at work in my toolbox. Snap-On makes one I believe. So does Matco, Ingersol Rand, and some other companies as well. It truly does work. Hell, you can even make one by just welding some thick piping to the outside of a cheap socket you don't care about. That's what I did before these were actually produced by anyone.
Basic concept is the extra mass that's further away from the center of rotation gives the impact gun more "leverage" and thus more twisting force. That's my 2 cents on the subject.
Here's a quick video of one in action...
RaveN1814 is offline   Reply With Quote Quick reply to this message
Old 08-08-2019, 05:54 AM   #9 (permalink)
79hilux90crx's Avatar
Rep Power: 23 79hilux90crx Still a JDM Star....79hilux90crx Still a JDM Star....
79hilux90crx Still a JDM Star....79hilux90crx Still a JDM Star....79hilux90crx Still a JDM Star....79hilux90crx Still a JDM Star....79hilux90crx Still a JDM Star....79hilux90crx Still a JDM Star....79hilux90crx Still a JDM Star....79hilux90crx Still a JDM Star....79hilux90crx Still a JDM Star....79hilux90crx Still a JDM Star....79hilux90crx Still a JDM Star....79hilux90crx Still a JDM Star....
This is what I have always used.
Works great if you do not have a compressor.
https://www.amazon.com/Powerbuilt-64.../dp/B0000TMLWQ
https://www.oreillyauto.com/detail/b...w83168/4614583
https://www.autozone.com/loan-a-tool...-tool/420315_0
93 Ford F150 4.9 Daily/Work Truck
95 Chevy S10 2.2
08 Harley Davidson Ultra Classic
98 Jeep Cherokee 4" Lift Cut Fenders 33x12.50 Daily/Offroad Toy
14 Subaru Forester XT Touring 2.0 Turbo (Wifes Ride)
92 Mustang 2.3 5 Speed 325K on the clock and counting
07 V-Star 650 Classic Space Consumer in the shop
RIP PAT
79hilux90crx is offline   Reply With Quote Quick reply to this message
Old 08-08-2019, 09:08 AM   #10 (permalink)
Asshole
Chrisfrom1986's Avatar
Rep Power: 53 Chrisfrom1986 is on a level you can only DREAM about! ! !Chrisfrom1986 is on a level you can only DREAM about! ! !Chrisfrom1986 is on a level you can only DREAM about! ! !
Chrisfrom1986 is on a level you can only DREAM about! ! !Chrisfrom1986 is on a level you can only DREAM about! ! !Chrisfrom1986 is on a level you can only DREAM about! ! !Chrisfrom1986 is on a level you can only DREAM about! ! !Chrisfrom1986 is on a level you can only DREAM about! ! !Chrisfrom1986 is on a level you can only DREAM about! ! !Chrisfrom1986 is on a level you can only DREAM about! ! !Chrisfrom1986 is on a level you can only DREAM about! ! !Chrisfrom1986 is on a level you can only DREAM about! ! !Chrisfrom1986 is on a level you can only DREAM about! ! !Chrisfrom1986 is on a level you can only DREAM about! ! !Chrisfrom1986 is on a level you can only DREAM about! ! !Chrisfrom1986 is on a level you can only DREAM about! ! !Chrisfrom1986 is on a level you can only DREAM about! ! !Chrisfrom1986 is on a level you can only DREAM about! ! !
iTrader Score: 42 reviews
Removing crank pulley and flywheel out of car
99 ej8 ex b20z2 Taffeta White
Old 08-08-2019, 01:19 PM   #11 (permalink)
EFB055's Avatar
EFB055 It's a JDM Star Bitches....EFB055 It's a JDM Star Bitches....
Originally Posted by Chrisfrom1986 View Post
This is the method i've used. Doesn't cost anything, haha.
Old 08-09-2019, 05:35 AM   #12 (permalink)
Seems like this would have a tendency/chance to slip off of the dowel/locating pin if jarred hard enough.
95 Chevy S10 2.2
RIP PAT
Old 08-09-2019, 12:04 PM   #13 (permalink)
Asshole
I guess if you do it wrong? No side force should be applied to the wrench so I don't know how you can screw that up.
Old 08-10-2019, 08:43 PM   #14 (permalink)
B-series Destroyer
rico58204's Avatar
Rep Power: 22 rico58204 is the fucking MAN!!!!rico58204 is the fucking MAN!!!!rico58204 is the fucking MAN!!!!
rico58204 is the fucking MAN!!!!rico58204 is the fucking MAN!!!!rico58204 is the fucking MAN!!!!rico58204 is the fucking MAN!!!!rico58204 is the fucking MAN!!!!rico58204 is the fucking MAN!!!!rico58204 is the fucking MAN!!!!rico58204 is the fucking MAN!!!!rico58204 is the fucking MAN!!!!rico58204 is the fucking MAN!!!!rico58204 is the fucking MAN!!!!rico58204 is the fucking MAN!!!!rico58204 is the fucking MAN!!!!
I have been doing it like that for years. Never had an issue.
Can you provide instructions on how to wire all 4 vtec solenoids in parallel? I would like to hit vtec 4 times as hard, but I'm confused as to how the wiring configuration would look. Thanks
You link all the grounds, then wire each solenoid into the spark plug wires, that way they hit sequentially as the engine fires. This creates what I like to call asphalt shattering VTEC.
rico58204 is offline   Reply With Quote Quick reply to this message
Old Yesterday, 01:21 PM   #15 (permalink)
EFB055's Avatar
As long as you've loaded it square on it doesn't move. Definitely better to just buy the cranky pulley tool, but this will work fine in a pinch.
Old Yesterday, 02:16 PM   #16 (permalink)
EFB055's Avatar
Just found this pic from the depths of my photobucket archive haha.
Old Today, 06:11 AM   #17 (permalink)
got torque?
Old Today, 07:03 AM   #18 (permalink)
robgoof's Avatar
this works great.
iconAll times are GMT -8. The time now is 12:07 PM. | Welcome to Forum, please register to access all of our features.
