2 wire horn to 1 wire horn?? - D-series.org
Old 09-04-2018, 01:26 PM   #1 (permalink)
Pyro336's Avatar
Rep Power: 16 Pyro336 It's a JDM Star Bitches....
Pyro336 It's a JDM Star Bitches....Pyro336 It's a JDM Star Bitches....Pyro336 It's a JDM Star Bitches....
Default 2 wire horn to 1 wire horn??
I came across a set of 1 wire horns and wanted to know if anyone know how to wire them up. My 88' Civic has 2 wires both and no hornreally. I want to install a set of 1 wire horns that are louder. Any help on how to do so would be great. I've searched but found nothing specific. Thanks in advance.
Just remember that if the women don't find you handsome, they should at least find you handy!
You Rep Me, and I'll Rep You Back!!!!!
Pyro336 is offline   Reply With Quote Quick reply to this message
Old 09-04-2018, 02:32 PM   #2 (permalink)
Sailor's Avatar
Trace the two wires through. I expect one of them will eventually run back to earth. If that's the case, probably all you need to do with the one-wire horn is to make sure the casing is well grounded.
Worth a try, anyway. You shouldn't damage anything.
Four Hondas: two working
Old 09-04-2018, 02:48 PM   #3 (permalink)
Pyro336's Avatar
Sorry my first post was a little choppy. The wires that run to the horn are both hot until you press the horn button. At that point one wire goes neutral until the button is released.
Old 09-04-2018, 08:33 PM   #4 (permalink)
EFB055's Avatar
EFB055 It's a JDM Star Bitches....EFB055 It's a JDM Star Bitches....
Yep, the whole circuit is hot until you press the horn button, which grounds the circuit and turns the horns on. I'd add a relay and use the OEM horn switch to trigger like attached. Note that's assuming the horn is internally grounded through the mounting point.
Name:	single wire horn conversion.jpg
Old 10-08-2018, 03:19 PM   #5 (permalink)
Pyro336's Avatar
Thank you so much for your help. This worked like a charm thank you.
Old 10-08-2018, 04:41 PM   #6 (permalink)
EFB055's Avatar
No worries, glad you got it sorted.
iconAll times are GMT -8. The time now is 10:56 PM. | Welcome to Forum, please register to access all of our features.
