Polyurethane Bushings Squeak Fix - Greasing - D-series.org
Old 03-14-2016, 04:36 PM   #1 (permalink)
Michael99's Avatar
Rep Power: 8 Michael99 is learning the way of the DMichael99 is learning the way of the D
Default Polyurethane Bushings Squeak Fix - Greasing
I greased my bushing couple days ago, because they Squeaked terribly after 3 years of use.
Especially on twisting actions and on small or large bumps.
I drilled each metal arm where the bushing located all the way through the rubber to the metal sleeve and cut thread 1/4-28 and put auto-zone standard zerk fitting.
And pressed Lucas marine grease with grease gun.
I did it for all 3 front bushings on each side and the squeak gone away finally
I make a video of how I did it. the name on youtube - polyurethane bushings Squeak fix Honda civic 99 EX
https://www.youtube.com/watch?v=vb6g_xr0Lds
Ill try to post some pictures also but video more detailed, and not so long
ID:	104129   Click image for larger version
ID:	104137   Click image for larger version
Michael99 is offline   Reply With Quote Quick reply to this message
Old 03-14-2016, 05:01 PM   #2 (permalink)
Michael99's Avatar
only fitting on the first picture gonna be replaced for set on each side screw because could be damaged by road conditions,
two another fittings are recessed so they can stay on the place
Old 03-14-2016, 05:35 PM   #3 (permalink)
make sure the grease will not eat at the poly.
marine grease does not necessarily describe it as proper.
on the tube or bottle, it will say what it is compatible with.
Old 03-14-2016, 06:13 PM   #4 (permalink)
Michael99's Avatar
I will see if it eats or not, with the time. But I don't think its gonna eat the bushings.
Old 03-14-2016, 06:26 PM   #5 (permalink)
Asshole
Chrisfrom1986's Avatar
Rep Power: 53 Chrisfrom1986 is on a level you can only DREAM about! ! !Chrisfrom1986 is on a level you can only DREAM about! ! !Chrisfrom1986 is on a level you can only DREAM about! ! !Chrisfrom1986 is on a level you can only DREAM about! ! !
iTrader Score: 42 reviews
You're likely also not a chemical engineer but whatever. I used the provided poly lube when I installed energy suspension tension rod bushings.
99 ej8 ex b20z2 Taffeta White
Old 03-14-2016, 06:47 PM   #6 (permalink)
most petroleum products eat at rubber and poly bushings.
It generally needs to be a silicone based grease to be safe.
it will specifically say on container if safe for rubber products.
if it does not, you may need to replace those bushings in as little as 6 months
Old 03-14-2016, 08:04 PM   #7 (permalink)
Michael99's Avatar
thanks guys i'll check it on the bottle
Old 03-15-2016, 04:26 PM   #8 (permalink)
Michael99's Avatar
check the bottle and there is nothing saying about rubber,
the sign there says - multipurpose, good for roller bearings and automotive use and many more stuff
so if it good for roller bearings there is also rubber seals on bearings so it should be good.
And I did the test today I had poly bushing from 26mm sway bar that I don't use. In the morning I greased it well, and in the evening they fit shaft the same and stay hard the same.
I have prothane bushings that is more harder than energy suspension.
And with the time I'll definitely gonna fill the looseness in joints if it is gonna happen
Old 03-15-2016, 04:34 PM   #9 (permalink)
it says nothing about rubber. its not good for it then.
bearings dont use straight rubber. its a compound of sorts that is resistant to chemicals and petroleum.
the difference will be like an oil leak onto your belts. it wont effect it right away. it will take awhile to deteriorate.
Id find a grease marked safe for rubber or poly, and simply get enough in there that it forces the other stuff out. no need to pull things apart and clean.
I greased my brothers rear swaybar bushings with what I thought was a safe grease. I changed those bushings after only 4 months. they still appeared okay, but they shrunk and were sloppy in the bracket
Old 03-15-2016, 11:02 PM   #10 (permalink)
LAMER's Avatar
Rep Power: 9 LAMER  is accepted as part of the communityLAMER  is accepted as part of the communityLAMER  is accepted as part of the communityLAMER  is accepted as part of the community
I don't know if the marine grease you used is a lithium grease(water and heat (~130 oC) resistant), but if it is - you are all good. I've been running it for like 2-3 years now, on my diy 90 shore poly bushings.
Maxed out 565cc
LAMER is offline   Reply With Quote Quick reply to this message
Old 03-16-2016, 03:24 PM   #11 (permalink)
Michael99's Avatar
probably I'll follow the advise above and gonna press new grease safe for it. There is alot of work to replace them again + money too
Old 03-16-2016, 03:28 PM   #12 (permalink)
yeah, no need to change out the bushing or whatever. just be slow about squeezing new grease, you will be fine.
greasable bushings means that its easy noise control in the future though!!
Old 03-16-2016, 03:53 PM   #13 (permalink)
AutoXCivic's Avatar
Rep Power: 25 AutoXCivic Still a JDM Star....
AutoXCivic Still a JDM Star....AutoXCivic Still a JDM Star....AutoXCivic Still a JDM Star....AutoXCivic Still a JDM Star....AutoXCivic Still a JDM Star....AutoXCivic Still a JDM Star....AutoXCivic Still a JDM Star....AutoXCivic Still a JDM Star....AutoXCivic Still a JDM Star....AutoXCivic Still a JDM Star....
Send a message via AIM to AutoXCivic Send a message via MSN to AutoXCivic Send a message via Yahoo to AutoXCivic
Tell me I'm not the only one who thinks the grease squishing out looks like something out of a Miyazaki film.
Straight lines are for sissies.
<--- Stolen
<--- Sold.
barrel roll in airplane > barrel roll in nsx
AutoXCivic is offline   Reply With Quote Quick reply to this message
iconAll times are GMT -8. The time now is 03:17 AM. | Welcome to Forum, please register to access all of our features.
