DIY D to B spark leads or visa versa - D-series.org
Old 01-12-2015, 10:28 PM   #1 (permalink)
Icarus's Avatar
Rep Power: 13 Icarus is a name known to allIcarus is a name known to allIcarus is a name known to allIcarus is a name known to allIcarus is a name known to allIcarus is a name known to allIcarus is a name known to allIcarus is a name known to allIcarus is a name known to all
Default DIY D to B spark leads or visa versa
Hello.
So you might be thinking this is stupid why not buy new leads?
In my case I did a D to B swap and needed B leads and had recently purchased D leads and didn't want to go through the hassle of selling them and purchasing new ones since the D leads were new.
Some leads cost up to 100 USD with I think is over priced.
I am using the PowerTec brand on lead and have found them very good value for money at 28 USD
The B leads I used are old and went into the bin.
Anyway sharing is caring
B and D leads are very similar the only main difference is the tube and the top boot.
They are very easy to pull apart and the tubes have a groove that will allow the clips to slide free.
I found there was a bit of glue on the B lead and loosened it up with a screw driver.
Then simply reinstall the boot and tube the way it came off.
Once the clip part it back in the tube (loosley) simply rotate the tube to the tabs do not line up with the slots and the clip will stay in place if you had to swap plugs.
Bit of a useless DIY but maybe this helps someone?
The process can be revered if you want to turn your B leads into D leads.
Or just buy a new set.
Icarus is offline   Reply With Quote Quick reply to this message
Old 01-12-2015, 11:14 PM   #2 (permalink)
Which D HT leads were you using? Two designs that I know of....
Old 01-13-2015, 12:02 AM   #3 (permalink)
Icarus's Avatar
PowerTec PT578
1x PowerTec HT Ignition Lead Sets OE PT578
Old 01-13-2015, 01:07 AM   #4 (permalink)
useless info.
Old 01-13-2015, 01:22 AM   #5 (permalink)
Icarus's Avatar
its all i got.
Old 01-13-2015, 11:19 AM   #6 (permalink)
HiProfile's Avatar
Hmm, I'm going to pull apart all the spare D/B/F/H plugs I have and take some measurements. Most of mine are OEM. Some are virtually new but I'm no longer using the particular motor, so this will definitely save some cash.
Old 01-13-2015, 11:35 AM   #7 (permalink)
HondaDNA's Avatar
Bone means VTEC or nonVTEC
Old 01-13-2015, 09:15 PM   #8 (permalink)
Icarus's Avatar
non vtec. Nativity we only get non vtec D-series
Old 01-14-2015, 08:41 AM   #9 (permalink)
shoebox_civic's Avatar
more accurately he means front plug or back plug, since there were non-vtec versions of both...
99 CRV
17 Q50 2.0T
07 350Z touring
Old 01-14-2015, 09:20 AM   #10 (permalink)
Icarus's Avatar
oooh I used front plugs.
Haven't opened back plugs yet.
iconAll times are GMT -8. The time now is 10:08 AM. | Welcome to Forum, please register to access all of our features.
