1990 5.0 mustang LX auto cranks but won't start. - D-series.org
Old 12-23-2014, 03:57 PM   #1 (permalink)
Rep Power: 0 90mustangLX is nobody
Default 1990 5.0 mustang LX auto cranks but won't start.
I have a 1990 mustang that up to about a week ago ran perfect. My battery took a crap so I put another one in it. Now here's the problem, as soon as I put the battery in and hop in the car I turn the key on and notice that the fuel pump relay under the seat keeps clicking and now the car won't start. So trying to diagnose the problem my self I start replacing parts. Parts replaced- relay under the seat, distributor cap and rotor, coil, tfi module, fuel filter. Still problem not solved. I haven't replaced the fuel pump because I'm sure it still works because I can hear it and has pressure at the fuel rail. Something else I noticed was that I have spark at the coil to the distributor cap but no spark at the plugs. Please help!!
90mustangLX is offline   Reply With Quote Quick reply to this message
Old 12-23-2014, 04:04 PM   #2 (permalink)
DIY Guru
BogusSVO's Avatar
Rep Power: 13 BogusSVO is the fucking MAN!!!!BogusSVO is the fucking MAN!!!!BogusSVO is the fucking MAN!!!!
BogusSVO is the fucking MAN!!!!BogusSVO is the fucking MAN!!!!BogusSVO is the fucking MAN!!!!BogusSVO is the fucking MAN!!!!BogusSVO is the fucking MAN!!!!BogusSVO is the fucking MAN!!!!BogusSVO is the fucking MAN!!!!BogusSVO is the fucking MAN!!!!BogusSVO is the fucking MAN!!!!BogusSVO is the fucking MAN!!!!BogusSVO is the fucking MAN!!!!BogusSVO is the fucking MAN!!!!
Send a message via Yahoo to BogusSVO
Ok first... Why did you bring and no less join a HONDA fourm, when you have a FORD Mustang?!?!?!? There are tons of fourms that cover both Fords in general and Mustangs specifically.
But I would suggest a new Dizzy... sounds like the PIP module or the coil in the dizzy has gone bad.
And no, it is not the same kind of coil that that you have replaced, this is a small one under the reluctor.
this is probably the best noob weve ever had just pop in and actually be worth his weight
BogusSVO nomination for newb of the year 2014, maybe lifetime honorary mention as well.
BogusSVO is offline   Reply With Quote Quick reply to this message
Old 12-23-2014, 04:16 PM   #3 (permalink)
shoebox_civic's Avatar
99 CRV
17 Q50 2.0T
07 350Z touring
Old 12-23-2014, 04:26 PM   #4 (permalink)
Ok so would the dizzy cause the relay to click nonstop with the key on? That's for the reply. Must have gotten the forums mixed up somewhere.
Old 12-23-2014, 04:27 PM   #5 (permalink)
"Thanks"
Old 12-23-2014, 04:30 PM   #6 (permalink)
DIY Guru
BogusSVO's Avatar
Yep sure will.
BTW, if the TFI is not a true "Motorcraft" one, get one and install it, even the pick n pull used one is better than the BWD or wells. The timing map in the parts store one sucks and pulls too much timing.
But this is a Honda fourm... so what do I know??
<<<--- If my name makes sense.. you will do as I suggest
Old 12-23-2014, 04:38 PM   #7 (permalink)
Ok. Thanks a lot. I will give that a try. Is the part I need called a dizzy or is there a technical name for it.
Old 12-23-2014, 04:42 PM   #8 (permalink)
DIY Guru
BogusSVO's Avatar
Dizzy is fourm speak for distributor
Also since you did not know what I was speaking of, please go join a Ford or mustang fourm
Use the search and and read up on how to change/swap/R&R the distributor
It is not quite a drop and go deal
Old 12-23-2014, 05:09 PM   #9 (permalink)
Cali Noob's Avatar
Rep Power: 32 Cali Noob is on a level you can only DREAM about! ! !Cali Noob is on a level you can only DREAM about! ! !Cali Noob is on a level you can only DREAM about! ! !Cali Noob is on a level you can only DREAM about! ! !Cali Noob is on a level you can only DREAM about! ! !
Cali Noob is on a level you can only DREAM about! ! !Cali Noob is on a level you can only DREAM about! ! !Cali Noob is on a level you can only DREAM about! ! !Cali Noob is on a level you can only DREAM about! ! !Cali Noob is on a level you can only DREAM about! ! !Cali Noob is on a level you can only DREAM about! ! !Cali Noob is on a level you can only DREAM about! ! !Cali Noob is on a level you can only DREAM about! ! !Cali Noob is on a level you can only DREAM about! ! !Cali Noob is on a level you can only DREAM about! ! !Cali Noob is on a level you can only DREAM about! ! !Cali Noob is on a level you can only DREAM about! ! !Cali Noob is on a level you can only DREAM about! ! !Cali Noob is on a level you can only DREAM about! ! !
lol, merry xmas to the fam....
"Believe none of what you hear and half of what you see."
Pat Primmer, gone but not forgotten, RIP mate!
Function > Form
RTFM!!!
Cali Noob is offline   Reply With Quote Quick reply to this message
Old 12-25-2014, 08:30 PM   #10 (permalink)
Retired From Hondas
Esotericimage's Avatar
Rep Power: 37 Esotericimage is on a level you can only DREAM about! ! !Esotericimage is on a level you can only DREAM about! ! !
Esotericimage is on a level you can only DREAM about! ! !Esotericimage is on a level you can only DREAM about! ! !Esotericimage is on a level you can only DREAM about! ! !Esotericimage is on a level you can only DREAM about! ! !Esotericimage is on a level you can only DREAM about! ! !Esotericimage is on a level you can only DREAM about! ! !Esotericimage is on a level you can only DREAM about! ! !Esotericimage is on a level you can only DREAM about! ! !Esotericimage is on a level you can only DREAM about! ! !Esotericimage is on a level you can only DREAM about! ! !Esotericimage is on a level you can only DREAM about! ! !Esotericimage is on a level you can only DREAM about! ! !Esotericimage is on a level you can only DREAM about! ! !
trollin!
DSO Spam Basher
Originally Posted by Artikgrau325is
People try so hard to be unique, they lose their sense of style
Esotericimage is offline   Reply With Quote Quick reply to this message
Old 12-26-2014, 03:33 AM   #11 (permalink)
Rep Power: 21 robscrx is the fucking MAN!!!!robscrx is the fucking MAN!!!!robscrx is the fucking MAN!!!!
robscrx is the fucking MAN!!!!robscrx is the fucking MAN!!!!robscrx is the fucking MAN!!!!robscrx is the fucking MAN!!!!robscrx is the fucking MAN!!!!robscrx is the fucking MAN!!!!robscrx is the fucking MAN!!!!robscrx is the fucking MAN!!!!robscrx is the fucking MAN!!!!robscrx is the fucking MAN!!!!robscrx is the fucking MAN!!!!robscrx is the fucking MAN!!!!robscrx is the fucking MAN!!!!
lol
robscrx is offline   Reply With Quote Quick reply to this message
Old 12-28-2014, 05:19 AM   #12 (permalink)
Chandler's Avatar
Rep Power: 11 Chandler is nobody
my question is does it crank or not? because if he installed the battery backwards........ that will make a lot of things click.....
Chandler is offline   Reply With Quote Quick reply to this message
Old 12-29-2014, 10:21 AM   #13 (permalink)
JoelEspinoza's Avatar
Rep Power: 13 JoelEspinoza is hot as a volcano
JoelEspinoza is hot as a volcanoJoelEspinoza is hot as a volcanoJoelEspinoza is hot as a volcanoJoelEspinoza is hot as a volcanoJoelEspinoza is hot as a volcanoJoelEspinoza is hot as a volcanoJoelEspinoza is hot as a volcanoJoelEspinoza is hot as a volcanoJoelEspinoza is hot as a volcanoJoelEspinoza is hot as a volcanoJoelEspinoza is hot as a volcanoJoelEspinoza is hot as a volcano
I am sure the guy who owns a fake SVO mustang knows what he is talking about, but before you go crazy make sure the terminals are on the right posts on the battery, and make sure the connections are good on the batter terminals and where they attach, especially the ground wires.
Give a man a match, you will keep him warm for a minute. Light him on fire, however, and he will be warm the rest of his life....
JoelEspinoza is offline   Reply With Quote Quick reply to this message
Old 12-29-2014, 11:17 AM   #14 (permalink)
DIY Guru
BogusSVO's Avatar
Joel.... If you look at the list of parts he has already thrown at it you can see he really wants to spend money and do the "shotgun" method of repair.
Old 12-29-2014, 12:34 PM   #15 (permalink)
79hilux90crx's Avatar
Rep Power: 23 79hilux90crx Still a JDM Star....79hilux90crx Still a JDM Star....
79hilux90crx Still a JDM Star....79hilux90crx Still a JDM Star....79hilux90crx Still a JDM Star....79hilux90crx Still a JDM Star....79hilux90crx Still a JDM Star....79hilux90crx Still a JDM Star....79hilux90crx Still a JDM Star....79hilux90crx Still a JDM Star....79hilux90crx Still a JDM Star....79hilux90crx Still a JDM Star....79hilux90crx Still a JDM Star....79hilux90crx Still a JDM Star....
I want a late 80's mustang body on a early 90's 4x4 bronco frame with a chevy 454 in it.
Oh and don't just assume you have enough fuel pressure throw a gauge on that bitch and find out takes like 5 min!
93 Ford F150 4.9 Daily/Work Truck
95 Chevy S10 2.2
08 Harley Davidson Ultra Classic
98 Jeep Cherokee 4" Lift Cut Fenders 33x12.50 Daily/Offroad Toy
14 Subaru Forester XT Touring 2.0 Turbo (Wifes Ride)
92 Mustang 2.3 5 Speed 325K on the clock and counting
07 V-Star 650 Classic Space Consumer in the shop
RIP PAT
79hilux90crx is offline   Reply With Quote Quick reply to this message
Old 12-29-2014, 12:40 PM   #16 (permalink)
Mr.Fodo's Avatar
Rep Power: 14 Mr.Fodo is the fucking MAN!!!!Mr.Fodo is the fucking MAN!!!!
Mr.Fodo is the fucking MAN!!!!Mr.Fodo is the fucking MAN!!!!Mr.Fodo is the fucking MAN!!!!Mr.Fodo is the fucking MAN!!!!Mr.Fodo is the fucking MAN!!!!Mr.Fodo is the fucking MAN!!!!Mr.Fodo is the fucking MAN!!!!Mr.Fodo is the fucking MAN!!!!Mr.Fodo is the fucking MAN!!!!Mr.Fodo is the fucking MAN!!!!Mr.Fodo is the fucking MAN!!!!Mr.Fodo is the fucking MAN!!!!Mr.Fodo is the fucking MAN!!!!Mr.Fodo is the fucking MAN!!!!
What do you know "fake SVO" lol?
Have you ever tried building a bird house with a shotgun?
Just noticed the back-handed "Thanks"
This is even posted in the wrong location. sigh
Start there, if you still cant figure it out, you are not going to.
How
to act on this forum...
Mr.Fodo is offline   Reply With Quote Quick reply to this message
Old 12-29-2014, 12:50 PM   #17 (permalink)
DIY Guru
BogusSVO's Avatar
BogusSVO or RangerSVO... the build for a beater is about the same.. lol
I miss that old rust bucket!
Old 12-29-2014, 02:27 PM   #18 (permalink)
Asshole
Chrisfrom1986's Avatar
Rep Power: 53 Chrisfrom1986 is on a level you can only DREAM about! ! !Chrisfrom1986 is on a level you can only DREAM about! ! !Chrisfrom1986 is on a level you can only DREAM about! ! !Chrisfrom1986 is on a level you can only DREAM about! ! !
iTrader Score: 42 reviews
This isn't a real thread guys. Move along.
99 ej8 ex b20z2 Taffeta White
Old 12-29-2014, 04:28 PM   #19 (permalink)
Attachment 79305
The 2.3 turbo was a fun engine at the time. My brother had a Merkur XR4Ti, was kinda like an overweight Cadillac version of the SVO, and even it was pretty fun. I am sure the lighter version was a blast. If I remember right some state used them as highway patrol cars even though they didnt have a back seat. Basically police interceptors that had to call in a crown vic for backup if they needed to arrest anyone.
Old 12-29-2014, 06:36 PM   #20 (permalink)
DIY Guru
BogusSVO's Avatar
The old 2.3T is a heavy pig, but damn durable, Ford did a few things right with it, factory forged pistons and Inconal faced exhaust valves.
I had 3 Xr's at one point. damn funky rubber doughnut drive shaft bushing and a weak 5 speed mixed with an ECU that a 2 dollar digital watch has more computing power.
iconAll times are GMT -8. The time now is 12:19 AM. | Welcome to Forum, please register to access all of our features.
