DIY Fuel Line Tuck (Parts List) - D-series.org
Go Back   D-series.org » D-series Knowledge Factory » DIY Forum
Old 12-22-2013, 06:45 PM   #1 (permalink)
HondaDNA's Avatar
Default DIY Fuel Line Tuck (Parts List)
I was bored so I put together a list of what would be needed to do a fuel line tuck. This might of been covered but I haven't seen it on here.
AN size is "X"/16 so -6AN is 6/16 or 3/8. The OEM feed line on Civic's and Integra's is 5/16 and the return is 1/4, this equals out to be -5AN and the return is -4AN, odd sizes are hard to find so best to use -6 for the feed.
I have a AEM fuel rail which is -6AN so a -6AN O-ring boss adapter is needed. If you are using a OEM fuel rail you can remove the stud for the banjo feed line and use a 12 x 1.25 to -6AN adapter.
If you are using a stock rail or stock feed location, hose lengths may vary in my case the feed location is on the driver side and my stock steel feed line is cut right after it enters the engine compartment so I only need about a foot and a half to two feet of -6AN hose, same length for the return.
To convert the steel feed line to AN a 5/16 tube to -6AN compression adapter fitting is used. You need two straight -6AN hose ends, a FUEL INJECTION approved inline filter, and a 90 degree -6AN female to female adapter.
For the return you can use your stock rubber line if you want to save some cash, or you can use some fancy braided line with -4AN "dress up" hose ends, basically gear worm clamps with covers on them to make them look like AN fittings. Bam fuel line tuck is done.
Part list with links:
AN to Tube Adapter Fittings
90 Degree Female -6 AN to Female -6 AN
Male -6 AN to Male -6 AN O-Ring
Econ-O-Fit Hose Clamps
Russell Competition Fuel Filters
Summit Racing® Hose Ends
Vibrant Performance Braided Flexible Race Hose -4AN
Vibrant Performance Braided Flexible Race Hose -6AN
Old 12-22-2013, 07:20 PM   #2 (permalink)
Live,love,laugh,be real
4Door's Avatar
Rep Power: 39 4Door is on a level you can only DREAM about! ! !4Door is on a level you can only DREAM about! ! !
4Door is on a level you can only DREAM about! ! !4Door is on a level you can only DREAM about! ! !4Door is on a level you can only DREAM about! ! !4Door is on a level you can only DREAM about! ! !4Door is on a level you can only DREAM about! ! !4Door is on a level you can only DREAM about! ! !4Door is on a level you can only DREAM about! ! !4Door is on a level you can only DREAM about! ! !
iTrader Score: 20 reviews
are you going to post step by step pics in this or another thread..?
R.I.P. my mom - I miss you
10/3/1945-6/16/2007
R.I.P. - MiloReaper & Pat Primmer
96' CE1 Lx - Wags
04' Pilot EXL - Black Pile - Love it
is your friend, try it
[youtube ][ /youtube]
4Door is offline   Reply With Quote Quick reply to this message
Old 12-22-2013, 08:23 PM   #3 (permalink)
HondaDNA's Avatar
I thought about putting this in tech since I haven't got the parts yet (nor will I have them anytime soon). I was just looking at buying the kit from Fuel Tuck'd and wondered if I could put it together for cheaper. With all the parts added up my way is about $100, Fuel Tock'd kit is $150. My kit has a better filter though.
Old 12-22-2013, 08:38 PM   #4 (permalink)
2jzdreamin's Avatar
iTrader Score: 49 reviews
Pretty much the same stuff I use. If you need pics of it on the car I have them in my build thread.
all so do vtec sub-harness
instagram @magicman9won4
Old 12-23-2013, 10:22 AM   #5 (permalink)
2jzdreamin's Avatar
Here's two pics. All I can find right now.
Stock fuel lines converted to an
Braided hose with hose ends.
Old 12-23-2013, 06:01 PM   #6 (permalink)
HondaDNA's Avatar
Glad you posted, I tried to find pics in your build but couldn't find anything. I'd convert that banjo fitting to AN though
Old 12-23-2013, 06:09 PM   #7 (permalink)
2jzdreamin's Avatar
Yea I don't know what happened to them. I had to dig in my phone to find those. I know I have more but to many pics to look threw. I'll keep digging to see if I can find more pics.
Only reason the banjo is on there is I helped some one out and sold them that set up. I all ways convert the rail to an fitting.
Old 12-23-2013, 06:17 PM   #8 (permalink)
2jzdreamin's Avatar
Found some more.
Here you can see it on the motor.
Old 12-25-2013, 05:46 AM   #9 (permalink)
ministry of mayhem!
eddcartes's Avatar
Rep Power: 48 eddcartes is on a level you can only DREAM about! ! !eddcartes is on a level you can only DREAM about! ! !eddcartes is on a level you can only DREAM about! ! !eddcartes is on a level you can only DREAM about! ! !eddcartes is on a level you can only DREAM about! ! !
eddcartes is on a level you can only DREAM about! ! !eddcartes is on a level you can only DREAM about! ! !eddcartes is on a level you can only DREAM about! ! !eddcartes is on a level you can only DREAM about! ! !eddcartes is on a level you can only DREAM about! ! !eddcartes is on a level you can only DREAM about! ! !eddcartes is on a level you can only DREAM about! ! !eddcartes is on a level you can only DREAM about! ! !eddcartes is on a level you can only DREAM about! ! !eddcartes is on a level you can only DREAM about! ! !eddcartes is on a level you can only DREAM about! ! !eddcartes is on a level you can only DREAM about! ! !eddcartes is on a level you can only DREAM about! ! !eddcartes is on a level you can only DREAM about! ! !
iTrader Score: 37 reviews
Send a message via AIM to eddcartes Send a message via Yahoo to eddcartes
stickied.
It's simple, a Puerto Rican Nazi
Evil spirits beautiful naked girl live boobs
Resident D-series.org metalhead Alliance member #666!
rip emilio gallardo (milo). outstanding father, spouse, friend and member of dso. you will always be missed.
rip, patprimmer. last of the titans.
one thing i've learned from this job is to always keep a pack of cheese for your whine.
my ED6 build thread:
my dyno compe build:
eddcartes is offline   Reply With Quote Quick reply to this message
Old 05-11-2015, 08:10 PM   #10 (permalink)
NeonPinHead's Avatar
Rep Power: 26 NeonPinHead is the fucking MAN!!!!NeonPinHead is the fucking MAN!!!!NeonPinHead is the fucking MAN!!!!NeonPinHead is the fucking MAN!!!!
NeonPinHead is the fucking MAN!!!!NeonPinHead is the fucking MAN!!!!NeonPinHead is the fucking MAN!!!!NeonPinHead is the fucking MAN!!!!NeonPinHead is the fucking MAN!!!!NeonPinHead is the fucking MAN!!!!NeonPinHead is the fucking MAN!!!!NeonPinHead is the fucking MAN!!!!NeonPinHead is the fucking MAN!!!!NeonPinHead is the fucking MAN!!!!NeonPinHead is the fucking MAN!!!!
iTrader Score: 51 reviews
reviving an old thread.
instead of the compression fitting to adapt the hard lines, why not cut, re-flare, and use the original fuel line fitting. in which case does anyone know the size of the fitting for the stock filter? im sure you could find an adapter fitting to 6an, and it would hold more than 50psi.
NeonPinHead is offline   Reply With Quote Quick reply to this message
Old 05-11-2015, 08:31 PM   #11 (permalink)
Retired From Hondas
Esotericimage's Avatar
Rep Power: 37 Esotericimage is on a level you can only DREAM about! ! !Esotericimage is on a level you can only DREAM about! ! !
Esotericimage is on a level you can only DREAM about! ! !Esotericimage is on a level you can only DREAM about! ! !Esotericimage is on a level you can only DREAM about! ! !Esotericimage is on a level you can only DREAM about! ! !Esotericimage is on a level you can only DREAM about! ! !Esotericimage is on a level you can only DREAM about! ! !Esotericimage is on a level you can only DREAM about! ! !Esotericimage is on a level you can only DREAM about! ! !Esotericimage is on a level you can only DREAM about! ! !Esotericimage is on a level you can only DREAM about! ! !Esotericimage is on a level you can only DREAM about! ! !Esotericimage is on a level you can only DREAM about! ! !Esotericimage is on a level you can only DREAM about! ! !
because its cheaper then having to buy a flare tool..
The earls fitting from hardline to AN holds up to 80 IIRC. there was a video from earls with install instructions and details.
Im using the hardline to AN on my setup and its fine so far
DSO Spam Basher
Originally Posted by Artikgrau325is
People try so hard to be unique, they lose their sense of style
Esotericimage is offline   Reply With Quote Quick reply to this message
Old 05-11-2015, 08:38 PM   #12 (permalink)
just wondering because i already have a flaring tool. only $11 from harbor freight. says on the summit page 50psi max pressure. just looking at different options.
Old 05-11-2015, 08:58 PM   #13 (permalink)
Retired From Hondas
HA! after some searching, I found the vid..
Earls brand says 60-80lbs at the end..
http://www.anplumbing.com/page/16
DSO Spam Basher
Old 05-11-2015, 08:59 PM   #14 (permalink)
you would just need a 14mm x 1.5 inverted flare to -6AN adapter. like THIS.
Old 05-11-2015, 09:01 PM   #15 (permalink)
Retired From Hondas
hmm.. so the hardline gets pressed into a "cone" shape?
Well i guess either way will work..
DSO Spam Basher
Old 05-11-2015, 09:13 PM   #16 (permalink)
no you would need the flaring tool to create the cone shape. another option im looking into is using a -5an tube sleeve and nut. then just getting a male -5an to male -6an fitting. which would be cheaper than the $20 fitting.
Old 05-11-2015, 09:15 PM   #17 (permalink)
Retired From Hondas
20 bucks to save me from trying to fuck with a hardline pressed against a firewall is totally worth it IMO.
But like I said, the Earls fitting is good to 80lbs.. fine by me.
DSO Spam Basher
Old 05-11-2015, 09:16 PM   #18 (permalink)
2jzdreamin's Avatar
that fitting would work for the 96 and up civic, not so much for the 92-95 civic...the fuel line on the 92-95 civic would need to be bent for that fitting to work,at least thats how i see it..
people want to tuck the fuel line and cutting the stock line down low and using either the compression fitting or flaring it and running it behind the intake manifold..
Old 05-11-2015, 09:18 PM   #19 (permalink)
Retired From Hondas
Yea, I cut mine down on my 99
DSO Spam Basher
Old 05-11-2015, 09:23 PM   #20 (permalink)
ok let me walk you guys through this...
cut fuel hard line down low
slide on -5an tube nut
slide on -5an tube sleeve
flare the hard line with the tool
install -5an male to -6an adapter fitting
It would look something like this...
iconAll times are GMT -8. The time now is 03:35 PM. | Welcome to Forum, please register to access all of our features.
