96-00 Civic Modification Options (Interior & Exterior) - D-series.org
Old 07-18-2013, 11:35 PM   #1 (permalink)
Rep Power: 0 CO671 is trying to make new friends
Default 96-00 Civic Modification Options (Interior & Exterior)
FAQs - Frequently Asked (Tech) Questions
6th Generation FAQ
Interior
~$20+ (usually under $20) used Integra dual-bend shifter into 96-00 Civic
(Will need to be cut/dremeled to fit)
I highly recommend this, a noticeably different feel /short throw and worth the effort.
Comparison
~$??? weighted shift knob
If you want a different feel in shifting but don't want to do the shifter mod mentioned above, purchase a weighted knob. I personally use the PWJDM and it makes a huge difference.
PWJDM Brass Knuckle 530gram -Picture #2
~$25 240mm Convex Broadway rear view mirror (Ebay/Amazon)
If you're not a fan of a Convex, then a flat version is available.
Before - After
~$5 48-LED panel Dome Light insert
Amazon Listing Amazon Listing
~$??? used Integra Map-Light DIY
Search on for Tutorial as it's against rules for me to posting external DIY links
~$??? - Seat Swap
96-00 CIVIC:
-Front-
•92-95 Civic w/EK rails
•94-01 Integra w/EK rails
•97-01 CR-V w/EK rails
•92-97 Del Sol w/EK rails
•97-01 Prelude w/EK rails
•97-02 Accord Coupe w/EK rails
•01-03 CL w/EK rails*Requires 12v for heat feature
-Rear-(Hatch)
•92-95 Civic *Hatchback only
•94-01 Integra *Hatchback only
•02-06 RSX
-Rear-(Coupe)
•01-05 Civic Si*EP3 only
-Rear-(Sedan)
•92-95 Civic Sedan
•94-01 Integra Sedan
Cluster Modifications
Any 96-00 based Civic chassis cluster will plug & play no modification, this applies internationally.
Japanese, European, Asian, Australian/New Zealand, Canadian clusters will fit in USDM Civic's too.
97-01 CRV's - JDM Honda SMX - CDM (Canada) Acura 1.6 EL - Isuzu Gemini - Honda Orthia - JDM Honda Integra SJ also
Modification Required Clusters:
*search on Google as it's against rules to post external DIY links*
94-01 Integra
03-04 Civic
S2000
Exterior
96 - 98 Lip Options
If purchasing a replica lip, do yourself a favor & get a polyurethane replica, they're much more flexible than the ABS plastic which may crack & break very easily, although their fitment may be more precise (not as precise as OEM or genuine of course)
99 - 00 Lip options
Info: When considering 99-00 lips, OEM, SI (EM1), Civic Type R are the same lip. The replica "OEM/SI/Type R" lips however are more flared. It takes a bit of a closer look but in time you can easily spot the difference in the shape.
Same applies as mentioned above for the 96-98 replica lips purchases & quality.
Rear lips:
Info: There is a difference on rear bumpers between the years & models.
96-98 Coupes/Sedans share the same rear bumper
99-00 Coupes/Sedans share the same rear bumper
96-00 Hatchbacks share the same rear bumper
96-98 USDM 1998 Civic Coupe rear lip
99-00 Coupe/Sedan/SI USDM rear lip
Civic Type R rear lip
96-00 Civic Hatchback EDM VTI rear lip
Mugen Rear Spats 99-00 Coupe
Mugen Rear Lip Civic EK Ferio
Mudguard options:
Front mudguards:
FOR COUPE = Any '96-'00 Civic mudguards will fit.
FOR HATCH = Any '96-'00 Civic mudguards will fit.
FOR SEDAN = Any '96-'00 Civic mudguards will fit.
Rear mudguards:
FOR '96-'98 COUPE = '96-'98 Civic coupe/sedan mudguards fit.
FOR '99-'00 COUPE = '99-'00 Civic coupe/sedan mudguards fit.
FOR '96-'00 HATCH = '96-'00 Civic hatch mudguards fit.
FOR '96-'98 SEDAN = '96-'98 Civic coupe/sedan mudguards fit.
FOR '99-'00 SEDAN = '99-'00 Civic coupe/sedan mudguards fit.
Rear RSX mudguards have been cut to fit rear bumpers with rear lips on hatchbacks.
Fog Lights options
96-98 Circle - 96-98 Square
99-00 Circle
DIY 96-98 Civic square fog light wiring tutorial
DIY 99-00 Civic Ebay Fog Light Wiring tutorial
Tail-light options:
96-00 Coupes
96-98 OEM Amber - 99-00 OEM Non-Amber - 96-98 Red tint over amber - 99-00 Smoked over Clear
96-98 Sedans
info: (need clarification) 96-98 Red/Clear Depo's are replicas of the 96-98 Red/Clear JDM SiR/Honda Integra SJ
96-98 OEM Amber - 96-98 Red/Clear JDM SiR/Honda Integra SJ
99- 00 Sedans
info: 99-00 Red/Clear Depo's are replicas of the 99-00 Red/Clear Philippine SiR/Honda Integra SJ
99-00 OEM Amber - 99-00 Red/Clear Philippine SiR/Honda Integra SJ
96-00 Hatchbacks
96-98 OEM Amber - 99-00 OEM non-Amber - 96-00 Clear Hatchback Aftermarkets
CO671 is offline   Reply With Quote Quick reply to this message
Old 07-18-2013, 11:38 PM   #2 (permalink)
\/ apply baby lotion here \/
Pata's Avatar
Rep Power: 46 Pata is on a level you can only DREAM about! ! !Pata is on a level you can only DREAM about! ! !Pata is on a level you can only DREAM about! ! !Pata is on a level you can only DREAM about! ! !Pata is on a level you can only DREAM about! ! !
Pata is on a level you can only DREAM about! ! !Pata is on a level you can only DREAM about! ! !Pata is on a level you can only DREAM about! ! !Pata is on a level you can only DREAM about! ! !Pata is on a level you can only DREAM about! ! !Pata is on a level you can only DREAM about! ! !
iTrader Score: 136 reviews
Old 07-18-2013, 11:40 PM   #3 (permalink)
*This is more of a resource thread of multiple DIY's/ideas instead of a DIY itself, so apologies in advance if it's in the wrong section but it seems most fitting here.
I'm unaware if D-series allows the option to edit a thread within a certain time-frame, or whenever the normal member OP would like to. The character limit had limited me to whatever I have posted above, so in time I will update some more, but if it's too late I will request a deletion and create a new thread. Cheers to anybody interested in their Civic.
Old 07-18-2013, 11:41 PM   #4 (permalink)
Originally Posted by Pata View Post
Oh no, not spam. It's a developing thread to end all the "What can I do to my 96-00 Civic?" that we see VERY often on multiple forums... and a sort of resource for people who want to see the options of modifications that i've collected here.
edit: I just reread the forum rules;
"If you have a link to another site with a DIY, do not post it. "
so i'll have to edit my first post
Old 07-18-2013, 11:46 PM   #5 (permalink)
Pata's Avatar
we already have a thread like this somewhere in our archives. If somebody wants to figure out what to do to their Ek, Google is the very best place to start looking.
Old 07-19-2013, 04:39 AM   #6 (permalink)
va 91 hatch's Avatar
Rep Power: 0 va 91 hatch is trying to make new friends
Send a message via Yahoo to va 91 hatch
Agreed, admin lock thread.
Pre-build thread changes
va 91 hatch is offline   Reply With Quote Quick reply to this message
Old 07-19-2013, 08:11 AM   #7 (permalink)
want to see one of these posts but for the 92-95 chasis
iconAll times are GMT -8. The time now is 06:36 PM. | Welcome to Forum, please register to access all of our features.
