DIY: Bushing Installation Tool ~$10-$20 - D-series.org
Old 03-19-2013, 09:53 AM   #1 (permalink)
Enigma's Avatar
Rep Power: 11 Enigma  is accepted as part of the communityEnigma  is accepted as part of the communityEnigma  is accepted as part of the communityEnigma  is accepted as part of the community
Default DIY: Bushing Installation Tool ~$10-$20
2x Pipe caps
1x 3/8" threaded rod 12" L
2x 3/8" fender washers
2x 3/8" nuts
Usually bad bshings are blown, cut out the remaining bits. A hammer and a flat head make the job easier, along with a hack saw.
Assemble the tool as shown in the photograph [edit: drill a hole in the center of the pipe caps with a 3/8" drill bit, angle the bit if necessary], then insert after properly lubricating the bushing. The bushing shown belongs to a 2001 Volkswagen Jetta trailing arm, it just happens to be the vehicle I am fixing at the moment.
I hope everyone here gets as much use of this tool as I have.
ID:	34913   Click image for larger version
ID:	36401   Click image for larger version
ID:	36409   Click image for larger version
"If ignorance is bliss then slap the smile off my face!"
Last edited by Enigma; 04-01-2013 at 03:59 PM. Reason: Added a few shots of the tool at work.
Enigma is offline   Reply With Quote Quick reply to this message
Old 03-19-2013, 02:04 PM   #2 (permalink)
95_EJ1's Avatar
Rep Power: 11 95_EJ1 is a name known to all95_EJ1 is a name known to all95_EJ1 is a name known to all95_EJ1 is a name known to all95_EJ1 is a name known to all95_EJ1 is a name known to all95_EJ1 is a name known to all95_EJ1 is a name known to all95_EJ1 is a name known to all
iTrader Score: 24 reviews
Awesome easiest way to install bushings without a press.
'95 EJ1 - Z6 Vitara build in (slow) progress
'90 Chevy Suburban - Future daily go-anywhere machine
'90 GMC Suburban - DD, future parts truck for the Chevy
95_EJ1 is offline   Reply With Quote Quick reply to this message
Old 03-19-2013, 02:11 PM   #3 (permalink)
cool. I used a c-clamp looking thing i brought from harbor fright.
But i have seen someone use a jack,socket and a truck to press them in.
Old 03-19-2013, 02:39 PM   #4 (permalink)
The_Acid_Beaver's Avatar
If you want to make something for constant use, purchase a length of ACME square threaded rod and the nuts to go with it. That will make sure the threads are going to last under a lot of abuse.
RTFM. No, really. Do it.
Old 03-19-2013, 02:40 PM   #5 (permalink)
_Jack_Bauer_'s Avatar
Rep Power: 9 _Jack_Bauer_ is starting to learn the ropes_Jack_Bauer_ is starting to learn the ropes_Jack_Bauer_ is starting to learn the ropes_Jack_Bauer_ is starting to learn the ropes_Jack_Bauer_ is starting to learn the ropes_Jack_Bauer_ is starting to learn the ropes_Jack_Bauer_ is starting to learn the ropes
I love it. Great to see some innovation when the right tool isnt available or out of budget.
_Jack_Bauer_ is offline   Reply With Quote Quick reply to this message
Old 03-19-2013, 03:00 PM   #6 (permalink)
ministry of mayhem!
eddcartes's Avatar
Rep Power: 48 eddcartes is on a level you can only DREAM about! ! !eddcartes is on a level you can only DREAM about! ! !eddcartes is on a level you can only DREAM about! ! !eddcartes is on a level you can only DREAM about! ! !eddcartes is on a level you can only DREAM about! ! !
eddcartes is on a level you can only DREAM about! ! !eddcartes is on a level you can only DREAM about! ! !eddcartes is on a level you can only DREAM about! ! !eddcartes is on a level you can only DREAM about! ! !eddcartes is on a level you can only DREAM about! ! !eddcartes is on a level you can only DREAM about! ! !eddcartes is on a level you can only DREAM about! ! !eddcartes is on a level you can only DREAM about! ! !eddcartes is on a level you can only DREAM about! ! !eddcartes is on a level you can only DREAM about! ! !eddcartes is on a level you can only DREAM about! ! !eddcartes is on a level you can only DREAM about! ! !eddcartes is on a level you can only DREAM about! ! !eddcartes is on a level you can only DREAM about! ! !
iTrader Score: 37 reviews
Send a message via AIM to eddcartes Send a message via Yahoo to eddcartes
awesome idea.
It's simple, a Puerto Rican Nazi
Evil spirits beautiful naked girl live boobs
Resident D-series.org metalhead Alliance member #666!
rip emilio gallardo (milo). outstanding father, spouse, friend and member of dso. you will always be missed.
rip, patprimmer. last of the titans.
one thing i've learned from this job is to always keep a pack of cheese for your whine.
my ED6 build thread:
my dyno compe build:
eddcartes is offline   Reply With Quote Quick reply to this message
Old 03-19-2013, 05:20 PM   #7 (permalink)
formerly allnaturalrex
greasemonkey89's Avatar
Rep Power: 22 greasemonkey89 is the fucking MAN!!!!greasemonkey89 is the fucking MAN!!!!greasemonkey89 is the fucking MAN!!!!
Send a message via AIM to greasemonkey89
i might try this if i dont get access to the press at work. this might come in handy when i order all my sonem bushings.
greasemonkey89 is offline   Reply With Quote Quick reply to this message
Old 03-23-2013, 07:21 AM   #8 (permalink)
Rep Power: 10 b16racereg6 is a name known to allb16racereg6 is a name known to allb16racereg6 is a name known to allb16racereg6 is a name known to allb16racereg6 is a name known to allb16racereg6 is a name known to allb16racereg6 is a name known to allb16racereg6 is a name known to allb16racereg6 is a name known to allb16racereg6 is a name known to all
Awesome idea!!
b16racereg6 is offline   Reply With Quote Quick reply to this message
Old 03-23-2013, 08:23 AM   #9 (permalink)
Enigma's Avatar
Thanks guys!
I can't wait to see someone break out this tool at the track!
Old 03-23-2013, 09:04 AM   #10 (permalink)
Who replaces bushings at the track? Hahaha, I guess... haha. rep
Old 03-24-2013, 04:13 AM   #11 (permalink)
Enigma's Avatar
I've seen all sorts of stuff happen at the track, bushings are least of everyone's worries .. but it does happen!
Old 03-24-2013, 04:48 AM   #12 (permalink)
crxdonwon's Avatar
Rep Power: 11 crxdonwon is a name known to allcrxdonwon is a name known to allcrxdonwon is a name known to allcrxdonwon is a name known to allcrxdonwon is a name known to allcrxdonwon is a name known to allcrxdonwon is a name known to allcrxdonwon is a name known to allcrxdonwon is a name known to allcrxdonwon is a name known to all
Default Re: DIY: Bushing Installation Tool ~$10-$20
Awesome idea. I have used the same concept on the rear LCA bushings. My idea was a little more dinosaurish. Oct box covers with a hole drilled in the center, because they didn't have washers big enough. I used some old mount bolts and my electric impact.
"Son... We don't cry unless we're bleedin' or broken!"
-DonWon
"Don't get too close to me, you'll get Horsepower on you!"
-DonWon
crxdonwon is offline   Reply With Quote Quick reply to this message
Old 03-24-2013, 05:47 AM   #13 (permalink)
guest's Avatar
Rep Power: 24 guest is hot as a volcanoguest is hot as a volcano
iTrader Score: 46 reviews
making your own SST's !!!!!!
They don't teach you that, no wait, I did learn that in auto. tech. school....
XP4EVER
Old 03-24-2013, 10:21 AM   #14 (permalink)
Enigma's Avatar
SST?
Old 03-24-2013, 11:32 AM   #15 (permalink)
guest's Avatar
special service tool
XP4EVER
Old 03-25-2013, 03:17 AM   #16 (permalink)
Enigma's Avatar
Gotcha, I never attended any type of traditional trade school for mechanics. I started with LEGO's and Erector Sets.
Then I turned 15 years of age.
Old 03-25-2013, 06:23 AM   #17 (permalink)
guest's Avatar
I attended an auto tech program and it's help me land jobs. Great for a resume, especially if your trying to do this for a living and have just wrenched on cars at home and you don't have any experience on paper.
XP4EVER
Old 04-01-2013, 04:01 PM   #18 (permalink)
Enigma's Avatar
All of the shops in my area avoid students from ATI or UTI .. they want people that actually work on cars in the heat. They want people that have experience, now it would look better on my resume for a dealership or a high-end shop to have formal education given my years of experience.
Oh, added a few shots of the tool at work.
iconAll times are GMT -8. The time now is 01:31 PM. | Welcome to Forum, please register to access all of our features.
