98 civic 1.6L misfire problems Help!! - D-series.org
Old 12-09-2012, 03:37 PM   #1 (permalink)
Rep Power: 0 jpm7481 is nobody
Default 98 civic 1.6L misfire problems Help!!
I have a 98 civic with the 1.6L motor. The check engine light is on. I had the codes checked and it came back as a misfire in 1 and 3. I changed the plugs,plug wires,cap,rotor and the coil. The codes were cleared but came back within a few miles of driving. It kinda "chugs" at idle and it seems to need a second to start. I could really use some help as this is my first Honda!
jpm7481 is offline   Reply With Quote Quick reply to this message
Old 12-09-2012, 04:16 PM   #2 (permalink)
D-series SoCal Division
AJAY's Avatar
Rep Power: 16 AJAY is the fucking MAN!!!!AJAY is the fucking MAN!!!!AJAY is the fucking MAN!!!!
AJAY is the fucking MAN!!!!AJAY is the fucking MAN!!!!AJAY is the fucking MAN!!!!AJAY is the fucking MAN!!!!AJAY is the fucking MAN!!!!AJAY is the fucking MAN!!!!AJAY is the fucking MAN!!!!AJAY is the fucking MAN!!!!AJAY is the fucking MAN!!!!AJAY is the fucking MAN!!!!AJAY is the fucking MAN!!!!
My brothers 98' GSR had a similar problem. Check engine light came on code misfire cylinder 3 and 4. Changed out the spark plugs, plug wires, cap, and rotor. Still had the misfire. We figured out there was a lot of oil coming from the valve cover vent hose to the intake tube thus burning oil in cylinders 3 and 4.(aka blowby) We changed out the PCV valve and the problem was solved.
1993 civic dx hatch
jdm d15b vtec obd1
web level 1 cam
15g turbo 13 psi
STOLEN!
AJAY is offline   Reply With Quote Quick reply to this message
Old 12-09-2012, 04:27 PM   #3 (permalink)
Thanks for that info. I will check that tomorrow
Old 12-10-2012, 06:37 PM   #4 (permalink)
eee-jay-ate's Avatar
Rep Power: 11 eee-jay-ate is learning the way of the Deee-jay-ate is learning the way of the D
You might have better luck posting this sort of question in the general tech section.
But maybe I can help you out a bit. Start simple, are the grounds all good? If so, make sure spark that is good. Next if you have good spark, check your injectors, make sure they are firing.
Then just report back.
PS, here's a good way to check for spark: DIY: How to test for spark and to troubleshoot spark problems - Honda-Tech
best threads ever:
eee-jay-ate is offline   Reply With Quote Quick reply to this message
Old 12-10-2012, 06:48 PM   #5 (permalink)
Tfish1's Avatar
Rep Power: 7 Tfish1 is nobody
I thought this was the diy section not how to diy
Tfish1 is offline   Reply With Quote Quick reply to this message
Old 12-11-2012, 02:13 AM   #6 (permalink)
Thanks for the info eee jay ate. Tfish1.... If I posted this in the wrong place...my bad but u don't need to be an ignorant ass about it. I am new and just looking for some info. If u can't help. Don't reply
iconAll times are GMT -8. The time now is 10:07 AM. | Welcome to Forum, please register to access all of our features.
