Calibrate Your Adjustable Cam Gear - D-series.org
Old 11-22-2012, 12:20 AM   #1 (permalink)
Nasty_Canasta's Avatar
Rep Power: 18 Nasty_Canasta is the fucking MAN!!!!Nasty_Canasta is the fucking MAN!!!!Nasty_Canasta is the fucking MAN!!!!
Nasty_Canasta is the fucking MAN!!!!Nasty_Canasta is the fucking MAN!!!!Nasty_Canasta is the fucking MAN!!!!Nasty_Canasta is the fucking MAN!!!!Nasty_Canasta is the fucking MAN!!!!Nasty_Canasta is the fucking MAN!!!!Nasty_Canasta is the fucking MAN!!!!
Default Calibrate Your Adjustable Cam Gear
I've had a lot of discussions about after market cam gears with people. Mostly
about them being off timing from the stock gear. A lot of people think their cam
gears are indexed properly but to be honest, I've never had one that is dead nuts
on time with the original gear. Ever.
When I bought my first cam gear, I trusted it. I was actually "advancing" my
timing back to stock. In this how-to, I'll show you an easy way to get your
gear lined up with your old gear and you won't be left wondering.
First, make sure your stock cam gear is set properly at TDC. If you don't
know how to do this, you should not be playing with an adjustable gear.
I stole this photo cuz I didn't take a pic of my stock gear on the cam -
After you've verified that the gear is at TDC, mark the top tooth of the
timing belt with a grease pen or goats blood. Your choice. Then remove
cam gear bolt and slide the cam gear off with the belt on it.
After you've removed the gear, spray some WD40 or other lubricant on
the end of the cam itself. This will come in later.
Loosen the bolts on your adjustable cam gear so that the center piece
that holds on to the cam can spin freely. Put top tooth in the same spot
of the belt you've marked with the grease pen and install the cam. Pay
no attention to the cam key yet. As long as you haven't moved the cam,
you're good so far.
This is my cam installed with the timing set at "stock" or "zero". It is
visibly off time.
Here's where the WD40 comes into play. It should help the center of the
cam gear spin with a little effort without moving the cam. Spin the center
until it lines up with the cam keyway.
Now that my cam keyway is lined up properly with both the gear and the
cam, the cam key should easily and freely slide into the hole. Tighten your
cam bolts and you are truly where your stock gear was. Notice that my
gear is not at "TDC"..it's 2 degrees off. So, 2* retarded is really TDC for
this particular cam gear.
Retard or advance to your liking from there. Set your ignition timing and
rest assured that your cam is really where you want it to be.
I need a flex hone to finish my budget A6 refresh. Help a brother out if you have one...
If you need a part, hit me up. I'm willing to help out the remaining D-Series soldiers on the cheap.
Nasty_Canasta is offline   Reply With Quote Quick reply to this message
Old 11-22-2012, 12:24 AM   #2 (permalink)
007
007's Avatar
Rep Power: 14 007 is hot as a volcano007 is hot as a volcano
007 is hot as a volcano007 is hot as a volcano007 is hot as a volcano007 is hot as a volcano007 is hot as a volcano007 is hot as a volcano007 is hot as a volcano
good shit Jay!
007 is offline   Reply With Quote Quick reply to this message
Old 11-22-2012, 12:29 AM   #3 (permalink)
Originally Posted by 007 View Post
good shit Jay!
Thanks, man. I was doing it at 3 am and figgr'd I'd make a how-to of it.
Old 11-22-2012, 01:01 AM   #4 (permalink)
007
007's Avatar
a little common sense goes a long way.
Old 11-22-2012, 02:07 AM   #5 (permalink)
there is some slight error with the crank key stock as well as the OEM cam gear can spin thus throwing cam timing off.
IMHO you can retard the factory cam 2 degrees at the PM3 cam gear and still pass SCCA tech inspection as most don't know where to look.
Old 11-22-2012, 03:25 AM   #6 (permalink)
It's so strange to think they said "close enough" when they are so meticulous
with everything else. Then again, they are just internal combustion engines.
You'd think they'd find a way to really lock that bitch in place, though.
Sorta' off subject..but I always found it strange that the stock B7 map had
such a huge timing offset from the actual stock dizzy timing.
Old 11-23-2012, 04:02 AM   #7 (permalink)
EJ6Civic27's Avatar
Rep Power: 14 EJ6Civic27 is a name known to allEJ6Civic27 is a name known to allEJ6Civic27 is a name known to allEJ6Civic27 is a name known to allEJ6Civic27 is a name known to allEJ6Civic27 is a name known to allEJ6Civic27 is a name known to allEJ6Civic27 is a name known to allEJ6Civic27 is a name known to allEJ6Civic27 is a name known to all
iTrader Score: 17 reviews
Send a message via AIM to EJ6Civic27
Good things to know, Jay! Wish I figured out the whole cam gear being off shit before I threw my adj. gear on...lol
a6 Cam/z6 intake manifold/full header back exhaust
Spider RPM tune/3500rpm launch/7200 fuel cut/NGK AFX Wideband
EJ6Civic27 is offline   Reply With Quote Quick reply to this message
Old 11-23-2012, 03:22 PM   #8 (permalink)
Pull your adjustable off real quick, time the cam gear with the stock and then
do the calibration. Take ya fifteen minutes with break in the middle.
Old 11-24-2012, 06:44 AM   #9 (permalink)
EJ6Civic27's Avatar
Did that already. Me and you set it up back in the beginning of summer.
Old 11-24-2012, 07:37 AM   #10 (permalink)
That's right.
I was just gonna tell ya to wrench the hangover away.
Just read your text. About to take the boy to his Mom's for
the day...then I'm chilling in the garage with the kerosene
heater on blast.
Old 11-24-2012, 05:53 PM   #11 (permalink)
wakkjobb's Avatar
Rep Power: 16 wakkjobb is the fucking MAN!!!!wakkjobb is the fucking MAN!!!!wakkjobb is the fucking MAN!!!!
wakkjobb is the fucking MAN!!!!wakkjobb is the fucking MAN!!!!wakkjobb is the fucking MAN!!!!wakkjobb is the fucking MAN!!!!wakkjobb is the fucking MAN!!!!
This is awesome since I picked up a ?? adj cam gear tonight... now I won't set it at "zero" before installing it.
Rest in peace, PatPrimmer...
1985 4Runner: 22RE w/ engnbldr head, 261* cam and O/S valves, 5.29 gears, Detroit front locker, E-Locker rear, girlfriend-bought 38" tires, 4" AllPro lift, dual t-cases, hi steer and an increasing amount of body damage. But that's what it's for; it's not a Jeep.
There's no reason a car built on a Fairmont chassis with a Pinto engine and Lincoln brakes should work this well, but it does!
wakkjobb is offline   Reply With Quote Quick reply to this message
Old 11-24-2012, 07:05 PM   #12 (permalink)
Asshole
Chrisfrom1986's Avatar
Rep Power: 53 Chrisfrom1986 is on a level you can only DREAM about! ! !Chrisfrom1986 is on a level you can only DREAM about! ! !Chrisfrom1986 is on a level you can only DREAM about! ! !
Chrisfrom1986 is on a level you can only DREAM about! ! !Chrisfrom1986 is on a level you can only DREAM about! ! !Chrisfrom1986 is on a level you can only DREAM about! ! !Chrisfrom1986 is on a level you can only DREAM about! ! !Chrisfrom1986 is on a level you can only DREAM about! ! !Chrisfrom1986 is on a level you can only DREAM about! ! !Chrisfrom1986 is on a level you can only DREAM about! ! !Chrisfrom1986 is on a level you can only DREAM about! ! !Chrisfrom1986 is on a level you can only DREAM about! ! !Chrisfrom1986 is on a level you can only DREAM about! ! !Chrisfrom1986 is on a level you can only DREAM about! ! !Chrisfrom1986 is on a level you can only DREAM about! ! !Chrisfrom1986 is on a level you can only DREAM about! ! !Chrisfrom1986 is on a level you can only DREAM about! ! !Chrisfrom1986 is on a level you can only DREAM about! ! !
iTrader Score: 42 reviews
Need to remember to do this when I change my timing belt. Plus figure out which timing marks to use since Ive seen it both ways in fsm's for d15b.
99 ej8 ex b20z2 Taffeta White
Old 11-25-2012, 07:27 PM   #13 (permalink)
Right on, man. I had done my valve lash with a rod down the spark plug tubes
with this new engine. Wasn't really looking at the cam timing. Then when I
got the crank to TDC, I realized that the cam had been set a tooth advanced
by the previous dude..So I pulled it back, redid the lash and then decided to
conjure up a way to make sure this cam gear wasn't out of whack.
I would think the D15b would use the 7 o'clock marker...but then being a
D15, I could see it being set like a B7. If the FSMs show it both ways, I
think it's a matter of trial 'cuz there's no way you could even get a straight
answer from Honda. Out of curiosity, where are you running it right now?
Old 11-25-2012, 08:19 PM   #14 (permalink)
CaliLegal's Avatar
Rep Power: 15 CaliLegal is hot as a volcanoCaliLegal is hot as a volcano
CaliLegal is hot as a volcanoCaliLegal is hot as a volcanoCaliLegal is hot as a volcanoCaliLegal is hot as a volcanoCaliLegal is hot as a volcanoCaliLegal is hot as a volcanoCaliLegal is hot as a volcanoCaliLegal is hot as a volcanoCaliLegal is hot as a volcanoCaliLegal is hot as a volcano
Nice, Ill have to re-check my Cam gear.
Old
D16z6
11.5psi 204whp/180ftlbs. old setup
New - 5/25/12
.002 P2W
75.5mm Z6
TD04H 15G @ 22.6psi ??WHP
Put a new motor in?
Dont race your car?
If you see smoke don't insert face?
If any of this confuses you die!
R.I.P - Pat Primmer
CaliLegal is offline   Reply With Quote Quick reply to this message
Old 11-25-2012, 08:44 PM   #15 (permalink)
40MPGd15b7's Avatar
Rep Power: 11 40MPGd15b7 is a Top Aussie
40MPGd15b7 is a Top Aussie40MPGd15b7 is a Top Aussie40MPGd15b7 is a Top Aussie40MPGd15b7 is a Top Aussie40MPGd15b7 is a Top Aussie40MPGd15b7 is a Top Aussie40MPGd15b7 is a Top Aussie40MPGd15b7 is a Top Aussie40MPGd15b7 is a Top Aussie40MPGd15b7 is a Top Aussie40MPGd15b7 is a Top Aussie40MPGd15b7 is a Top Aussie
nice write up jay!
must spread rep, lol.
40MPGd15b7 is offline   Reply With Quote Quick reply to this message
Old 11-25-2012, 10:36 PM   #16 (permalink)
Asshole
I believe I set it level with the head when I put in a stock z6 cam, but my junk2 gear is also set 4* retarded. Idles and run great but Id like to get it where its supposed to be.
Old 11-26-2012, 11:24 AM   #17 (permalink)
Originally Posted by 40MPGd15b7 View Post
nice write up jay!
Thanks, man. Glad you dig it.
Being who you are, I'm assuming you're running a chipped ECU. What if you
set the cam both ways, set the dizzy timing to 16* and ran a stock map or
stock ECU. I'm guessing that whichever one gets the closest to factory
listed MPGs would be the "proper" setting. Trying to think of other ways.
What do you think?
Also, the cam gear I'm running is the Rage..which is identical to the Junk2..
it's even made by the same people who make the Junk2s. Jason was never
secretive about that...which I find respectable. Point being - I'm guessing
the gear is at least a degree or two off...or more. I had one that was almost
4.5 degrees (half a damn tooth).
Old 11-26-2012, 11:38 AM   #18 (permalink)
BigTuna's Avatar
Rep Power: 18 BigTuna is about to kiss the sky
BigTuna is about to kiss the skyBigTuna is about to kiss the skyBigTuna is about to kiss the skyBigTuna is about to kiss the skyBigTuna is about to kiss the skyBigTuna is about to kiss the skyBigTuna is about to kiss the sky
iTrader Score: 21 reviews
Another thing to keep in mind is that not all of the keys are cut correctly in stock cams and especially after market camshafts. This on top of aftermarket cam gears not being notched or marked correctly can make a big difference.
Many moons ago this was stickied in the DIY section.
https://www.d-series.org/forums/diy-f...-your-cam.html
If you really want to start figuring out where the cam is, where it likes to be etc start degreeing and filling a note book with with what you find.
BigTuna is offline   Reply With Quote Quick reply to this message
Old 11-26-2012, 11:48 AM   #19 (permalink)
Also, check this out.
Here is a stock Y7 gear -
Now check out the "Y7" adjustable cam gear. The key and/or keyway is visibly
closer to a stock Z6 / PM3 gear than the stock Y7 -
The Adjustable Z6 (PM3) gear. Here's where it gets tricky. My adjustable
"Y7" gear is indexed EXACTLY like a PM3 or adjustable Z6 gear. I will take
pics. At "zero", the keyway is dead center with the top tooth of the cam
gear. Just like a PM3. No offset. It's identical to this but is
stamped "D16Y" -
Hope that made sense. Just woke up from a well deserved sleep session. Basically,
a lot of "Y7" adjustable cam gears are indexed just like PM3 gears. When you hold
them up to a PM3 gear, the keyways match up exactly.
Old 11-26-2012, 11:50 AM   #20 (permalink)
I have started such notebook. Titled "The Jacked Up Cam Gear Log"
Great idea, man. People should. And then compile knowledge.
iconAll times are GMT -8. The time now is 04:01 AM. | Welcome to Forum, please register to access all of our features.
