3 pin IACV experiment - D-series.org
Old 09-20-2011, 09:57 AM   #1 (permalink)
007
007's Avatar
Rep Power: 14 007 is hot as a volcano007 is hot as a volcano
007 is hot as a volcano007 is hot as a volcano007 is hot as a volcano007 is hot as a volcano007 is hot as a volcano007 is hot as a volcano007 is hot as a volcano
Default 3 pin IACV experiment
I gather that if you want to convert from OBD2 to OBD1, you need to change the IACV from 3 pin to 2 pin in addition to some wiring modifications. the reason for this was supposed to be tht the 3 pin IACV is driven off a PWM signal while the 2 pin IACV is operated by a simple voltage differential signal.
being the cheap and lazy bastard that I am, I wanted to see for myself whether or not a 3 pin IACV could be run by a voltage differential signal. I had one lying around so I took that, an AC - DC adapter with a variable output voltage setting, couple of wires, alligator clips and went to work. here is the result [annotations added]:
with this, I am pretty certain that a 3 pin IACV can be run by an OBD1 ECU. all that needs to be done is to use the center terminal and one of the two outermost terminals. the center pin takes a constant positive voltage and the outer pins take varying amounts of negative voltage and the difference between the two voltages determines how far the IACV opens. which one of the two outer pins the voltage is applied to determines the direction in which the shaft rotates. with an OBD2 ECU, it can rotate both ways. with an OBD1 2 pin ECU, it will rotate only one way. my guess is that the ECU should be able to learn to control this valve. will know for sure when I get around to doing my conversion.
@2jzdreamin, @xile6, this should be of particular interest to you guys.
007 is offline   Reply With Quote Quick reply to this message
Old 09-20-2011, 10:45 AM   #2 (permalink)
v8killaz's Avatar
Rep Power: 12 v8killaz is almost there....
v8killaz is almost there....v8killaz is almost there....v8killaz is almost there....v8killaz is almost there....v8killaz is almost there....v8killaz is almost there....v8killaz is almost there....v8killaz is almost there....v8killaz is almost there....v8killaz is almost there....
i just block those off and run a 2 wire iacv. its not that difficult
most epic thread-
v8killaz is offline   Reply With Quote Quick reply to this message
Old 09-20-2011, 10:50 AM   #3 (permalink)
007
007's Avatar
2 pin IACVs are sorta rare to come by here and expensive. they also require intake manifold modification.
this method requires no modification other than wiring. almost plug and play shit.
Old 09-20-2011, 11:29 AM   #4 (permalink)
v8killaz's Avatar
werd. modifying the intake is easy though just need a drill.
most epic thread-
Old 09-20-2011, 11:43 AM   #5 (permalink)
007
007's Avatar
true. but still something I would still like to avoid as this alternative is way simpler. Im getting a 2 pin IACV as a backup though. it the ECU cannot control this, Ill go the conventional way.
Old 09-20-2011, 11:48 AM   #6 (permalink)
snm95ls's Avatar
Rep Power: 26 snm95ls Still a JDM Star....
snm95ls Still a JDM Star....snm95ls Still a JDM Star....snm95ls Still a JDM Star....snm95ls Still a JDM Star....snm95ls Still a JDM Star....snm95ls Still a JDM Star....snm95ls Still a JDM Star....snm95ls Still a JDM Star....snm95ls Still a JDM Star....
iTrader Score: 16 reviews
I have tried it, and it doesn't really work properly. It works, kind of.
06 Legacy GT Spec B DD
2017 Suzuki SV650
snm95ls is offline   Reply With Quote Quick reply to this message
Old 09-20-2011, 12:00 PM   #7 (permalink)
007
007's Avatar
can you describe what happens? and what did you do for the wiring? get rid of the orange IACVN wire and retain the blue / black IACVP?
Old 09-20-2011, 12:32 PM   #8 (permalink)
snm95ls's Avatar
It has been a while ago, but IIRC if had a very limited range of idle control.
Yes, that is how I set it up IIRC.
2017 Suzuki SV650
Old 09-20-2011, 01:07 PM   #9 (permalink)
007
007's Avatar
thanks dude. gotta ask you one more thing... did you try adjusting the plate on the other side of the IACV to give it some range?
here is what I found it could do:
regular setting:
tweaked setting:
ID:	28991   Click image for larger version
Old 09-20-2011, 02:54 PM   #10 (permalink)
snm95ls's Avatar
I didn't bother with it that much because I knew I was going to be switching manifolds and IACVS at some point.
Interesting though.
2017 Suzuki SV650
Old 09-21-2011, 12:45 AM   #11 (permalink)
Zen Chameleon's Avatar
Rep Power: 11 Zen Chameleon is a name known to allZen Chameleon is a name known to allZen Chameleon is a name known to allZen Chameleon is a name known to allZen Chameleon is a name known to allZen Chameleon is a name known to allZen Chameleon is a name known to allZen Chameleon is a name known to allZen Chameleon is a name known to allZen Chameleon is a name known to all
iTrader Score: 30 reviews
I've always found it slightly entertaining to see lazy people work twice as hard while attempting not to do any work at all. Carry on and good luck
Delilah '97 Del Sol S
grab your rod and shake it, it the piston rattles you are OK!
Don't forget the lube!
Zen Chameleon is offline   Reply With Quote Quick reply to this message
Old 09-21-2011, 12:53 AM   #12 (permalink)
007
007's Avatar
LOL! thanks man.
it is like an investment. if a little bit of work today helps me be lazy tomorrow, I go for it
Old 01-20-2012, 07:34 AM   #13 (permalink)
netpsyche's Avatar
Rep Power: 8 netpsyche will become famous soon enoughnetpsyche will become famous soon enoughnetpsyche will become famous soon enough
good idea lazy boy
netpsyche is offline   Reply With Quote Quick reply to this message
Old 01-20-2012, 07:46 AM   #14 (permalink)
Formally D_Tuned
Tw34k's Avatar
Rep Power: 19 Tw34k is the fucking MAN!!!!Tw34k is the fucking MAN!!!!Tw34k is the fucking MAN!!!!
Tw34k is the fucking MAN!!!!Tw34k is the fucking MAN!!!!Tw34k is the fucking MAN!!!!Tw34k is the fucking MAN!!!!Tw34k is the fucking MAN!!!!Tw34k is the fucking MAN!!!!Tw34k is the fucking MAN!!!!Tw34k is the fucking MAN!!!!Tw34k is the fucking MAN!!!!
Pulse-width modulation - Wikipedia, the free encyclopedia
Stepper motor - Wikipedia, the free encyclopedia
All I ever wanted was to pop vtec...
Tw34k is offline   Reply With Quote Quick reply to this message
Old 02-07-2012, 08:30 PM   #15 (permalink)
Rep Power: 0 babyboichris5 is nobody
can IACV caue idle problem ??
babyboichris5 is offline   Reply With Quote Quick reply to this message
Old 02-08-2012, 12:07 AM   #16 (permalink)
Blackhorn's Avatar
Rep Power: 9 Blackhorn is trying to make new friends
yes it does...
please search the forum before jacking someone's thread, i am sure there's more than enough info on the forum
Blackhorn is offline   Reply With Quote Quick reply to this message
Old 02-08-2012, 05:33 AM   #17 (permalink)
Rep Power: 8 Ekd16turbo is nobody
Just wondering, it's easier to just cut one of the wires and splice them together for the iacv? then just plug it, it seems like this is a lot more work.
Ekd16turbo is offline   Reply With Quote Quick reply to this message
Old 02-08-2012, 09:28 AM   #18 (permalink)
007
007's Avatar
it is easier if you already have a 2 pin IACV. I am simply interested in checking if it is truly impossible to make an OBD2 IACV work with an OBD1 ECU.
Old 02-08-2012, 01:34 PM   #19 (permalink)
Gus
Gus's Avatar
Rep Power: 11 Gus smells like BoratGus smells like BoratGus smells like BoratGus smells like BoratGus smells like Borat
2 - Wire is for Manual trans ecu's and 3 wire is for autos, OBD version has nothing to do with it. Just to let everybody know.
Rock n roll doesn't come from your head. It comes from your crotch!
Gus is offline   Reply With Quote Quick reply to this message
Old 02-08-2012, 01:36 PM   #20 (permalink)
Gus
Gus's Avatar
It works, got a 2000 2 wire being controlled by a P06 Manual trans.
iconAll times are GMT -8. The time now is 10:51 PM. | Welcome to Forum, please register to access all of our features.
