97 radio relocation - D-series.org
Old 05-22-2010, 01:06 AM   #1 (permalink)
K5trailrunner's Avatar
Rep Power: 10 K5trailrunner will become famous soon enoughK5trailrunner will become famous soon enoughK5trailrunner will become famous soon enough
Default 97 radio relocation
alright i searched and i didn't find anything on how to relocate the radio to behind the cupholder. so i thought i'd go out and post a diy on it so here it is, btw it's my first diy so i hope it passes you're standards
Tool's needed,
6 in 1 screwdriver, that's it!!!!!! lol
(I already had a aftermarket radio installed so i already had everything wired up for the stock wiring location. everything will fit with no modifying
ok, here's a before pic
first (because i drive an auto unfortinially) i removed the shifter knob
Next i removed the trim peice just under the steering wheel
Next i removed the trim peice just above the cup holder
and the arm rest trim peice
K5trailrunner is offline   Reply With Quote Quick reply to this message
Old 05-22-2010, 01:12 AM   #2 (permalink)
Thumbs up
Next to come out was the cup holder trim peice
Followed by the shifter selector plate
then the acutal cup holder/ stash all pocket
remove all the black screws, 2 on the back of the pocket, 4 on the back of the brackets
don't worry about getting the brackets mixed up, there labled
Old 05-22-2010, 01:19 AM   #3 (permalink)
The pocket should now pop out of the housing
so you are now left with a cup holder and a almost perfect radio housing
I reatached the brackets, they only go on one way
Next i removed the radio, with the mounting kit i had it just pulled out
Detached all the wires; Radio harnase, Antanna, and sub out
Old 05-22-2010, 01:27 AM   #4 (permalink)
you should be able to just pull the wirs from there current location down to where the radio will soon be
wires pulled down
you can't slid the radio in from the front
the screw holes won't line up, instead just slid it in from the back of the mounts
there is usually screw size and length deminsions on the side or back of the radio
Old 05-22-2010, 01:32 AM   #5 (permalink)
pic of the radio mounted, you should use all 4 mounting locating on the radio. or it won't be very stable, and they should all line up without any problems
There's even enough room ro compleatly fold the face down all the way
and the cup holder lid goes up 99% of the way
reconnect all the wires for the radio
and mount it back to the car
Old 05-22-2010, 01:40 AM   #6 (permalink)
and now time to reinstall all the trim places
and you're all done, now you just have to cover that hole where the radio was
Next Diy i do will fill that hole just fine
Old 05-22-2010, 02:05 AM   #7 (permalink)
link to the block off plate diy
https://www.d-series.org/forums/diy-f...off-plate.html
Old 05-25-2010, 05:10 AM   #8 (permalink)
EJ6Civic27's Avatar
Rep Power: 14 EJ6Civic27 is a name known to allEJ6Civic27 is a name known to allEJ6Civic27 is a name known to allEJ6Civic27 is a name known to allEJ6Civic27 is a name known to allEJ6Civic27 is a name known to allEJ6Civic27 is a name known to allEJ6Civic27 is a name known to allEJ6Civic27 is a name known to allEJ6Civic27 is a name known to all
iTrader Score: 17 reviews
Send a message via AIM to EJ6Civic27
Good job. Mad easy to do, even if your clueless. lol. + Rep for making the write-up.
I did this to my 00 sedan. After awhile, it got mad annoying to have the radio way down below. Especially if you have drinks in the (useless) cupholders.
You need the 96-98 cupholders to do this in 99-00 Civics, BTW.
a6 Cam/z6 intake manifold/full header back exhaust
Spider RPM tune/3500rpm launch/7200 fuel cut/NGK AFX Wideband
EJ6Civic27 is offline   Reply With Quote Quick reply to this message
Old 05-25-2010, 05:17 AM   #9 (permalink)
jollyroger494's Avatar
Rep Power: 14 jollyroger494 is about to blow upjollyroger494 is about to blow upjollyroger494 is about to blow upjollyroger494 is about to blow upjollyroger494 is about to blow upjollyroger494 is about to blow upjollyroger494 is about to blow upjollyroger494 is about to blow upjollyroger494 is about to blow upjollyroger494 is about to blow upjollyroger494 is about to blow upjollyroger494 is about to blow upjollyroger494 is about to blow upjollyroger494 is about to blow up
iTrader Score: 23 reviews
cool write up. i would use the empty space for gauges if/when you decide to go turbo. =)
New Project: White 87' Supra JDM - 1GTE TT
MR 95 ex coupe- CAF!-R.I.P. put into a wall by work..
MR 94 ex coupe- from the effing canigits eh?
I'd fuck that like she was the economy and I was obama!
Grab her by the throat and fuck that bitch silly. If she tries to fight just whisper in her ear "don't turn this rape into a murder"
jollyroger494 is offline   Reply With Quote Quick reply to this message
Old 05-25-2010, 09:09 AM   #10 (permalink)
EJ6Z's Avatar
Rep Power: 10 EJ6Z is almost a somebodyEJ6Z is almost a somebodyEJ6Z is almost a somebodyEJ6Z is almost a somebody
I did this about 3 months ago. Rep for the DIY.
EJ6Z is offline   Reply With Quote Quick reply to this message
Old 05-25-2010, 09:23 AM   #11 (permalink)
I can't read...
myHonda1's Avatar
Rep Power: 41 myHonda1 is on a level you can only DREAM about! ! !myHonda1 is on a level you can only DREAM about! ! !myHonda1 is on a level you can only DREAM about! ! !myHonda1 is on a level you can only DREAM about! ! !myHonda1 is on a level you can only DREAM about! ! !
myHonda1 is on a level you can only DREAM about! ! !myHonda1 is on a level you can only DREAM about! ! !myHonda1 is on a level you can only DREAM about! ! !myHonda1 is on a level you can only DREAM about! ! !myHonda1 is on a level you can only DREAM about! ! !myHonda1 is on a level you can only DREAM about! ! !myHonda1 is on a level you can only DREAM about! ! !myHonda1 is on a level you can only DREAM about! ! !myHonda1 is on a level you can only DREAM about! ! !myHonda1 is on a level you can only DREAM about! ! !myHonda1 is on a level you can only DREAM about! ! !myHonda1 is on a level you can only DREAM about! ! !
iTrader Score: 48 reviews
"when life gives you lemons, paint that shit gold"
i love to rape kids...*silence*
let me touch you.
myHonda1 is offline   Reply With Quote Quick reply to this message
Old 05-30-2010, 09:28 PM   #12 (permalink)
Thank you all for your input, btw
EJ6, funny enough my remote still works with cups in the holder and the lid up, otherwise i think i would get tired of it too.
JOLLY, I've decided to put 2 or 3 gauges in the block off plate along with a usb charger port and probally a few switches. i'll post pix when i get them
thanks again everyone, i'll be givin rep for the responces
Old 05-31-2010, 09:57 AM   #13 (permalink)
this is how it looks so far, it's only one gauge but you should get the idea of how i'm thinking of going with it lol
Old 06-04-2010, 09:46 PM   #14 (permalink)
GOOSEej's Avatar
Rep Power: 11 GOOSEej smells like BoratGOOSEej smells like BoratGOOSEej smells like BoratGOOSEej smells like BoratGOOSEej smells like Borat
nice..
i did this to my first hatch back in 04 then to my evo in 05 then to my current hatch
all CF block off plates too
Pata Asking a question
Inside your Throttle Body, it's shut tight correct?
Response
yes sir, as tight as the skin on a frogs ass
Classic!
GOOSEej is offline   Reply With Quote Quick reply to this message
Old 06-11-2010, 10:24 AM   #15 (permalink)
maxwellmercer's Avatar
Rep Power: 10 maxwellmercer is learning the way of the Dmaxwellmercer is learning the way of the D
Good write up, I love the look of the block off plate in the stock radio position. You get one yet?
Rareform
maxwellmercer is offline   Reply With Quote Quick reply to this message
Old 06-11-2010, 10:25 AM   #16 (permalink)
Rep Power: 10 ballin92 is nobody
can you do this on a 92 if you use a newer center concel
ballin92 is offline   Reply With Quote Quick reply to this message
Old 06-11-2010, 11:04 AM   #17 (permalink)
Rep Power: 17 lkailburn It's a JDM Star Bitches....
i really don't get the point of this mod. the radio is so far away from your reach now. Are you swapping in boost gauges or something in the gap? Why would you want a giant gap in the console?
Nice DIY writeup though! lol
-Luke
y7 block, deburred Vitaras/FJT Ibeams, Stg4 P&P y8 head, ported and matched y8 IM, ITR tb, wrx urboTurb, ramhorn, jrc 5" fmic, 450's, 2.5" dp, 3" exhaust, clutch specialties stg2, act 12lb, rebuilt y8 tranny, S300. 221whp/201wtq
2005 Legacy GT
My D16 Build
lkailburn is offline   Reply With Quote Quick reply to this message
Old 06-11-2010, 04:05 PM   #18 (permalink)
i would like to put gauges there
Old 06-12-2010, 08:00 AM   #19 (permalink)
Spadedek's Avatar
Rep Power: 10 Spadedek is learning the way of the DSpadedek is learning the way of the D
exactly what i had in my old setup, i really don't mind the radio being low either because I"m usually not messing with it. And since the cup holder are useless anyway i have made the lid permanently shut.
Spadedek is offline   Reply With Quote Quick reply to this message
Old 06-12-2010, 08:09 PM   #20 (permalink)
I just made one the same day, it's my other diy. i don't like buying things if i can help it
sorry i don't have my 95 to screw around with anymore. so i can't really answer your question. i don't know what the underside of the concle looks like off the top of my head. i'd just say tear your's apart and see if it will work or not. either way you should post your results up here
-Luke
Thank you, ya i am using gauges where the radio was at orginially. i made a blockoff plate for it. the radio being that far away isn't that bad, my radio came with a remote that works very well even with the cup holder lid open so it's not really that bad. not to mention my radio plays sd cards so i just use a 8gig sd card to store music on and never really have to open the face or never really need acess to the buttons on the face
iconAll times are GMT -8. The time now is 05:05 AM. | Welcome to Forum, please register to access all of our features.
