1990 civic DX sedan radio wiring issue - D-series.org
Go Back   D-series.org » D-series Knowledge Factory » Audio/Electronics
Old 06-16-2018, 12:20 PM   #1 (permalink)
Rep Power: 0 Brandoni is nobody
Default 1990 civic DX sedan radio wiring issue
Hey guys! So I bought a project civic with the radio out and the wires still had the stock plug to the stock radio on it, I bought a radio and looked for hours to find a wiring diagram and couldnÂ’t every wiring diagram that was supposed to be my car wiring diagram wasnÂ’t and some of the wires were different colors than mine. If thereÂ’s a recent thread to this could you link me or is there any actual wiring diagrams for my EF. Thank you!!!
Brandoni is offline   Reply With Quote Quick reply to this message
Old 06-16-2018, 02:37 PM   #2 (permalink)
autozone has a Honda specific pigtail. put that pig tail and if youre going aftermarket head unit, match the writing on the wires......notthathard
Old 06-16-2018, 03:34 PM   #3 (permalink)
if you have the oem radio plug, then like above stated, buy the adapter harness.
its like 15 bucks or less at walmart or any decent parts store
EDIT the radio plug adapter fits a metric buttload of hondas and acuras
Old 06-16-2018, 03:58 PM   #4 (permalink)
Ok I cut the pigtail off to install the aftermarket radio harness it came with. I donÂ’t know which is the speaker wires, ground, etc.
Old 06-16-2018, 04:09 PM   #5 (permalink)
youre joking right? you cut off the oem harness?
so, what exactly is the adapter going to PLUG into?
the female plug PLUGS INTO the oem male plug, and all you got to do is read the writing on the wires from the pigtail and connect them to the wires on the radio harness........
there are even instructions on the package to walk you through it
Old 06-16-2018, 05:06 PM   #6 (permalink)
So lets make this easier on you, since you probably didnt realize there was an adapter harness. Not everyone does, and not everyone takes the time to look around first.
Grab a ntoebook, and mark off all the wire colors.
Then grab a multimeter, with key out of ignition, find battery votlage. Mark it as 12+ or HOT or BATT.
put key into ignition, turn it one click over. no gauges should light up. Find the wire that now has voltage. This is your ignition 12v+, mark it IGN or switched power.
Now flip the headlight switch on. Find the wire that is now hot. This is your DIMMER or lights wire. mark it down.
Now go to each speaker in teh car, yank the speakers, and find the wires. Match colors to the radio harness.
This should narrow down what you need. If you need help finding a ground in the harness, you should find a friend to help.
Its nice to do things on your own, but next time, take a second to consider your options and parts requirements, rather than going in hot and cutting plugs off.
If you were smart, you cut the plug off while leaving some wire length to identify wire color locations. Then you only need to look online at a radio adapter plug and figure out what wires go to each location, as the radio adapter harness is colored in the universal standard (example yellow battery voltage, red ignition voltage, black ground, etc...)
good luck
Old 06-16-2018, 05:12 PM   #7 (permalink)
Old 06-16-2018, 06:18 PM   #8 (permalink)
I never got the adapter
Old 06-16-2018, 06:34 PM   #9 (permalink)
Meat Popsicle
Paterico's Avatar
Rep Power: 28 Paterico is on a level you can only DREAM about! ! !Paterico is on a level you can only DREAM about! ! !Paterico is on a level you can only DREAM about! ! !
Paterico is on a level you can only DREAM about! ! !Paterico is on a level you can only DREAM about! ! !Paterico is on a level you can only DREAM about! ! !Paterico is on a level you can only DREAM about! ! !Paterico is on a level you can only DREAM about! ! !Paterico is on a level you can only DREAM about! ! !Paterico is on a level you can only DREAM about! ! !Paterico is on a level you can only DREAM about! ! !Paterico is on a level you can only DREAM about! ! !Paterico is on a level you can only DREAM about! ! !
As I’m sure you already know, normally you buy the adapter and then wire that up to the harness supplies with the stereo unit. In any case, you can still make it work it’s jusf going to be more of a pain to wire the stereo harness to the vehicle harness.
I don’t have the answer but I’m sure a google search will show you the pinout/wiring diagram.
Good luck
Edit: damn, looks like slo and matt came through for ya. Nice
R.I.P. Pat Primmer
Paterico is offline   Reply With Quote Quick reply to this message
Old 06-24-2018, 07:06 AM   #10 (permalink)
JoelEspinoza's Avatar
Rep Power: 13 JoelEspinoza is hot as a volcano
JoelEspinoza is hot as a volcanoJoelEspinoza is hot as a volcanoJoelEspinoza is hot as a volcanoJoelEspinoza is hot as a volcanoJoelEspinoza is hot as a volcanoJoelEspinoza is hot as a volcanoJoelEspinoza is hot as a volcanoJoelEspinoza is hot as a volcanoJoelEspinoza is hot as a volcanoJoelEspinoza is hot as a volcanoJoelEspinoza is hot as a volcanoJoelEspinoza is hot as a volcano
Ive probably owned 10-15 hondas, and not one of them still had the OEM stereo plug, clowns like you are the reason why.
As a side note, do second gens have a dimmer wire for the radio? Dont remember ever seeing that, although I have always delt with butchered harnesses.
Give a man a match, you will keep him warm for a minute. Light him on fire, however, and he will be warm the rest of his life....
JoelEspinoza is offline   Reply With Quote Quick reply to this message
Old 06-24-2018, 01:30 PM   #11 (permalink)
EFB055's Avatar
EFB055 It's a JDM Star Bitches....EFB055 It's a JDM Star Bitches....
Old 06-24-2018, 02:10 PM   #12 (permalink)
This was all you needed btw: https://www.amazon.com/Scosche-HA02B...70_&dpSrc=srch
Less than $5
Old 06-24-2018, 02:47 PM   #13 (permalink)
my ej1 had a stock harness. I was so excited when I seen it.
Old 06-24-2018, 03:47 PM   #14 (permalink)
OP has not reported back to say if he still had the bit of factory plug and wires left, or if he threw it out.
Also has not reported back on if he figured the wiring out yet.
Im thinking perhaps hes not interested in updating us at this point.
Old 06-24-2018, 05:21 PM   #15 (permalink)
Meat Popsicle
Paterico's Avatar
One of my biggest annoyances. People come here asking for help, you dig deep inside to resist the urge to tell them to search, you give them gold, and then they never come back to tell you the outcome.
R.I.P. Pat Primmer
Old 06-24-2018, 06:53 PM   #16 (permalink)
EFB055's Avatar
If the outcome is anything like the process update, maybe it's best to just leave it.
iconAll times are GMT -8. The time now is 05:09 PM. | Welcome to Forum, please register to access all of our features.
